Question about Craftsman 29cc 4Cycle Straight Shaft Weedwacker Gas Trimmer ()
How do you rebuild carberater on a 4 cycle 29cc weed trimmer
    Sergeant:
  • 415 Answers
There is not much to it. There should be information stamped or printed on the side of the carb - maker and model#s. Take this information and do an internet search with it. You should find a rebuild kit for around $10. The kit should come with a diagram and directions. Take the carb apart, clean as necessary, reassemble with the new parts and you are good to go.
Posted on Jun 04, 2014
5 Suggested Answers
SOURCE: what oil do you use in the four cycle motor/ 29cc
Generally speaking, if there is a place on a gas-powered device that is labeled "gas" & a separate location labeled "oil" than you will need to use a 4-cycle oil for that machine. If there is just a place to put gas, you would use a 2-cycle oil; however, you would need to read the directions/manual to find out the correct proportion of oil to use, because you will have to MIX the appropriate amount of oil with the correct amount of gas, making a oil/gas solution that you would use for that specific device.
Posted on Jun 01, 2010
  • 6 Answers
SOURCE: How to fix a loose put out starter on a Craftsman
replace it with a new
Posted on Feb 27, 2011
  • 407 Answers
SOURCE: my 29cc 4 cycle craftsman
While Holding the Engine at Full Throttle, Adjust the High Air Mixture Screw In Until the Engine Revs Properly.
Posted on Jul 01, 2011
#1 Taper
  • 1040 Answers
SOURCE: i lost my manual for
SAE 30 during the warm months, and 5w-30 during the cold months.
Jim
Posted on Aug 15, 2011
Craftsman weedwacker model 316711970
If you go to searsparts.com and put in your model number it will show you a drawing of your weed wacker. Not sure of what you are looking for. Hope this helps.
Jul 09, 2015 | Craftsman 29cc 4Cycle Straight Shaft...
Craftmans 4 cycle weed trimmer air filter part and air filter housing model number 21032 order part please show diagram part
Go to searspartsdirect.com and put in your model number and it will give you a drawing showing the parts you are looking for. Hope this helps.
Jun 22, 2014 | Craftsman 29cc 4Cycle Straight Shaft...
What oil weight is used in the TB 575
If it is a 2 cycle motor, then use an appropriate 2 cycle oil. I use a synthetic oil that 1 bottle is mixed with 1 gallon of fresh gas.
May 09, 2014 | Troy-Bilt 29cc 4-Cycle Straight-Shaft Gas...
Air filter replacement weed eater
on your weed eater there should be a lil bubble looking thing called the primer somewhere around tht should be a black box with a screw of some sort on it take the lid to the black box of and theres your air filter
Aug 17, 2012 | Craftsman WeedWacker Gas Trimmer 29cc...
Craftsman 4 cycle weed wacker throwing oil
check the oil and see if its over full the carb might be leaking fuel into the crankcase
Aug 08, 2012 | Craftsman WeedWacker Gas Trimmer 29cc...
I have a troy bilt string weed cutter 27cc TB21Ec and need to know the oil gas ratio. I just read that it takes straight gas but my cap on the weed cutter where you put the gas says gas/oil mixture
Don't know that exact trimmer, but I always run 40:1 in all my trimmers, chainsaws, etc. That is 3.2 oz. of 2 cycle oil to one gallon of gasoline. I rebuild these machines daily and run that mix in everyting, except when it's actually specified on the machine.
Aug 11, 2011 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
My 29cc 4 cycle craftsman gas trimmer loses power when I increase the throttle
Jul 01, 2011 | Craftsman 29cc 4Cycle Straight Shaft...
What oil do you use in the four cycle motor/ 29cc
May 31, 2010 | Craftsman 29cc 4Cycle Straight Shaft...
Trot Bilt 4 cycle weed eater catches, but wont run.
rebuild carb to fix problem.let me know if this help you.ok
Jul 12, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Craftsman 29cc 4Cycle Straight Shaft Weedwacker Gas Trimmer () Logo
139 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
