Question about Bosch Nexxt 800 WFMC8401UC
Bosch nexxt dryer WFMC8401UC - wont spin & door stock
Door wouldn't open & drum wasn't spinning during wash (just stained on and in spin mode with no movement of drum). Ran diagnostic: In the last 8 cycles it indicates 1-ER:09, 1-ER:20, 1-dr:11, 1-dr:00, 1-dr:06. Not sure where to proceed from here about checking components other than a manual I have indicates faulty wire harness (which), faulty motor control and NTC too hot or relay stuck closed.
barkencoa
  • 3463 Answers
SOURCE: Bosch WFE 2021
I suggest that you check the brushes in the motor for wear.
Remove rear panel, remove drive belt, undo bolts securing motor, unplug motor lead and earth wire.
Lever motor back, keeping hold of it, and remove.
Check the brushes, they are at the opp end to the motor pulley, if there is less than 8mm left, then replace brushes.
I would also check the pump filter, and clean if req'd.
Please rate my fixya solution.
Thanks.
Posted on Feb 09, 2009
SOURCE: bosch classixx 1200 washing machine stalling mid-cycle
I`ve just spoken with Bosch Product Advice service about this problem. This could be happen when door is open after programme has been started. I didn`t check yet is working.
Thanks, roman
Posted on Jun 04, 2009
nikeananth
  • 267 Answers
SOURCE: Bosch WFF1800 - not spinning
HI,
move the kicking plate on the front-bottom of the machine. You will see o circular lid there, turn it on anti-clockvise to open. All of the water blocked will come from there, be careful. Look carefully that there are some objects blocking the water draining. Then turn on the machine on draining programme, the plastic rotor should turn fastly when the machine is on. If it is not running, change the pump motor. If it is running, but machine is not draining again you can understand that there is an objeck stuck on the hose between drum and pump motor. Lay down the machine on its rear facade, you will see a large and black hose between drum and pump motor. When you remove it, you will see that there is something that blocks water running.
thank you for using fixya,rate my answer,
vijay
Posted on Oct 04, 2009
57 varieties
  • 1653 Answers
SOURCE: Bosch Nexxt 700 won't drain water
Do the following.
  1. Switch off the machine and disconnect the mains power.
  2. Remove the access panel on the lower right front of the machine.
3. Remove the filter and make sure that the filter is not blocked and is clean and clear of all debris. Clean as required. Note that depending on the machine type you may get a lot of water coming out of the filter when you remove it if the machine has not drained successfully. Note that if the machine has stopped and not fully drained then you may be able to drain out the excess water by removing or disconnecting the waste hose and laying it on the ground in a tray. It may take a few minutes to empty but it will save a small flood.
4. Proceed by checking the drain hose for proper connection and kinks and make sure that it is not blocked.
5. Also check that the main waste drain pipe, if you use one, is not blocked and clean if required.
6. Reconnect the power and switch the machine on.
If the problem persists then do the following.
7. Switch off the machine and disconnect the mains power.
8. Check the electrical connections at the pump and make sure it is operational.
9. Remove the connecting hoses, and expect water to drain out and make sure the pipes are not blocked with debris or any object blockage.
10. Makes sure the pump appears clear and that the impeller looks in good condition.
11. Reconnect the hoses and then reconnect power and switch the machine on.
12. If problem has not been corrected, then remove the pump and check that the drive coupling to the motor is OK and that the motor turns OK. If all is well then replace the pump.
Posted on Oct 23, 2009
barkencoa
  • 3463 Answers
SOURCE: NEXXT Premium will not spin or drain
There should be a filter located at the bottom right front of washer behind drop down flap or plastic cover.
Unscrew anti-clockwise to remove and clean.
Posted on Jan 23, 2010
Testimonial: "Thanks. Great advice. We found a sock clogging the drain."
Error E:01
The control board is seeing the door as open even though it may be closed. Here is how to repair it:
http://www.techanswerslive.com/appliances/bosch-nexxt-washer-error-code-er%3a01/1
Mar 13, 2014 | Bosch Nexxt 500 WFMC3301 Front Load Washer
The door is locked and the Finished/Spin and Wash Lights are all flashing alone with a beeping tone. This is in ALL wash modes except off.
my machine did that when stuck on spin cycie all i did was unpluged it for a few seconds and pluged it back in and it let me start all over again and open the door
Aug 31, 2013 | Bosch Nexxt 100 Series WFMC1001UC Front...
RE. Bosch Nexxt 100 series. Does not spin. I have cleaned all hoses, outflow and inflow. Opened the little circle door at bottom right and it is clear. The fan even spins during drain cycle. I do hear...
Check connectors on motor assembly they can become loose due to the high speed and vibration. Motor and drum are tied together. I had similiar problem with mine after spending a few hundred on a control board which made no difference.
Oct 12, 2012 | Bosch Nexxt 100 Series WFMC1001UC Front...
Upon opening the door after the washer beeped finished, I went to remove the clothes and they were still very wet. I set the dial to "Spin" to remove more water before placing in dryer. The...
the very first thing you have to do is to open door, put hand inside washer inner tub and move tub up and down to see if there is "play" in the bearings. if inner tub moves your main bearing is bad dragging and forcing the motor controller to think there is a "unbalance" condition. also make sure you clean the water pump screen. take small round door at the lower right side and remove the screen to clean. then put it back and retest washer. if that dont work then you may have a fulty unbalance switch or motor controller.
good luck to you.
Feb 07, 2011 | Bosch Nexxt 500 WFMC3301 Front Load Washer
The water will not drain out of the machine
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 10, 2010 | Bosch Nexxt 800 WFMC8401UC
Bosch Nexxt 100 series washer stops at 1st spin cycle
take a look at your manual that came with your machine go to problems usually at the back and see what that says,or go to the bosch website and type in your model number its on the inside of the door.i would suspect a program fault.adrian,,,,,
Jun 28, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch nexxt washer is leaking from underneath
I found out why mine leaks. In the Bosh design there is a trap molded into the soap dispenser plastic tray. This tray or trap has a wide open path to the inside of the washing machine. We are using the tide pods as a detergent. Two things are going on here. This trap fills up with water immediately when water is cycled into the machine. The second thing is the pods partially dissolve and leave a gunk that blocks the water pathway to the drum. This blockage eventually allows water to pass however when the pressure is high and this blockage is restricting the water level rises and the trap dumps out into the washer panels. This water immediately leaks down and out the bottom. Observation when I disassembled the machine the trap was moldy and stinky. Water stains were running down the inside. Maybe the engineers at Bosch should look into this.
Feb 05, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch Nexxt 800 WFMC8401UC Logo
54 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
