Question about Simrad GPS
Simrad cx34 I am getting 'bearing zero alarm' and 'bearing pulse alarm' although scanner turns. Some adjustment off the place? Radar at mast and does not start properly after the winter. Scanner model RB714. Any idea of where the fault is?
SOURCE: Raymarine SL70 Radar; Unit switches on
I have the same problem. All functions and settings appear to be working OK but no image. After startup time about 3.5 amps are drawm When I turn on power [transmit] amps goes up to 4.5 approx.
I have the scanner head spinning but no target images
Ian
Posted on Jun 17, 2008
SOURCE: radar
Some cable test stuff
Remove the cable from the display, leave the dome connected
I thought the cable end had pin numbers but let me know if it doesn't,
the video pins are 1 and 2 which are located
either side of the key slot
Video pins 1 & 2 resistance 46 Kohms colors 1 white signal, 2
black return
Azimuth 12 &13 resistance 10 Kohms colors 12 purple azimuth +
, 13 grey azimuth -
Trigger 4 & 7 resistance 10 Kohms colors 4 orange trigger
+ ,7 yellow trigger -
Data I/O 6 & 10 resistance 160 Kohms colors 6 green data + , 10
blue data -
Approx. +/- 5 ohms tolerance.
Below is a pin chart of the display connector
key
2 1
5 4 3
8 7 6
11 10 9
13 12
Other pins on display connector
Battery - pins 3 & 5 both black
Battery + pins 9 & 11 both red
Shield pin 8
Dome connections
Video pin 8 white
Video rtn pin 7 black
Trigger + pin 6 orange
Trigger - pin 5 yellow
Data + pin 4 green
Data- pin 3 blue
Azimuth+ pin 2 purple
Azimuth - pin 1 grey
Battery + red
red
Battery - Black
Black
There was a note that some cables only have one set of battery
connections pins 5 & 9
Battery connections on 3 & 11 not present on all cables. You should
have the doubled power wires with the 4KW unit.
If the test results did not have the correct ohms then they said to
check it at the dome
If the dome checked ok, then the cable was bad, and to continuity check
the cable to confirm
a bad cable
Posted on Aug 24, 2008
  • 111 Answers
SOURCE: JRC 1000 MKII bearing pulse error on receiver
Normally the bearing pulse comes from the bearing pulse generator built inside the motor. Every time the motor turns it sends a pulse down the line showing the radar that it is indeed spinning. There is also a Heading pulse that comes from an electric eye elsewhere in the housing. The other thing could be that the wire carrying the bearing pulse is not getting back to the display. More so than often, it's the motor. I would have the display sent out to be checked on a simulator if there is a marine electronicshop nearby.
Posted on Oct 30, 2009
  • 111 Answers
SOURCE: Raymarine 41xx - Message "bearing pulse error"
More than likely your motor is going bad. Inside the motor is your bearing pulse generator. Replace the motor and you should be ok.
Posted on Jan 22, 2010
davidalfredw
  • 37 Answers
SOURCE: my Simrad GPS/sounder won't turn on.
assuming you have checked fuses etc you may have to use it as a lunch hook for your dingy...seriuosly..don't know ow old t is but a replacement is order methinks ...just like laptops they have improved greatly now and features abound screens are bigger and better...price has also dropped?
Posted on May 27, 2012
What is pop radar
When radar detectors proved easily capable of sniffing out radar from miles away, radar gun manufacturers responded by producing instant-on radar or unoffically called "Pulse" radar. In the instant-on mode, the radar's transmitter is placed on hold, ready to fire but not yet producing a signal for detectors to hear. The officer waits until his target is very close (brings a new meaning to "wait till you see the whites of their eyes") then releases the radar from stand by mode and gets a speed reading within a second or so (pulse). In this situation, no detector offers much warning.
There are guns out there that operate just like the instant-on guns of the past but with a very tough twist - POPTM mode! This gun is a normal K and Ka band radar gun detectable by most radar detectors made in the past 30 years, until this gun is placed in POP mode. When the gun is in POP™ Mode and activated, a brief burst of energy, less than 1/15 of a second, is transmitted and the vehicle's speed is quickly acquired. A detector without POP™ Mode detection capability cannot respond to this brief transmission.
TIP - When traveling in unfamiliar highways always try to find a vehicle which is traveling at the same rate or faster than you are and keep several car lengths behind them. This way the other vehicle can "flush out the radar".
Oct 22, 2015 | Vehicle Parts & Accessories
I have radar JRC JMA-9303.and we find a trouble "trigger error"
After black out of ship during audit Radar Model JMA 9303 no work.
Radar start work and after 15 sec. switch off.
Radar not show target and display error "ANTCLK ER" ( Bearing pulses are not
sent to the display unit)and "TRIG ERR" unknown error.
Antena of radar working.
Any body can suggest the solution
Oct 09, 2012 | GPS
JRC Radar Scanner when rotating is noisy inside the scanner base.
There is a seal on the antenna scanner shaft, just below the seal there are two bearings, thou the antenna are enclossed moisture still get inside and get to these bearings. Try and get a small amount of wd40 on the bearings, if not, you will soon begin to see false echoes on the screen because the motor on the scanner or antenna will begin to work harder causing a drag causing these echoes. Good luck.
Jan 17, 2011 | JRC Jma-2343 4kw Crt Radar
Goes off frequently with no radar nearby
False alarms are common with most radar detectors. You may need to adjust your detector's settings to compensate for the interference that sets off the alarm. Check your user's manual for instructions on using the menu.
Jan 04, 2011 | Passport 8500 Radar Detector
I need a wiring diagram for a simrad qx44 sounder
simrad nse 12 with bsm 1 sounder does it need its own power or does it get it from the starter pack thanks richard
May 28, 2010 | Simrad CX33-E WAAS/CP/FF 4012150700 No...
JRC 1000 MKII bearing pulse error on receiver screen. Connections to scanner good and scanner turning. How can I determine if the problem is in the receiver? How can I fix it? louonboard
Oct 27, 2009 | JRC 1000 MKII Radar GPS Receiver
No radar target images
Sounds like your video cable inside your radar cable. Also brings your Gain back to zero, STC back to Zero and rain back to zero. Next increase your gain until you see a picture. If none of that is working, check your cable then finally call a dealer.
Oct 15, 2009 | Furuno 1715 Radar 24nm Range
Error BZ
This is a bearing pulse error. Either the bearing pulse generator inside the motor is bad (Replace the motor) or it's in the radar cable or display.
Jun 15, 2009 | JRC 1000 MKII Radar GPS Receiver
Furuno 1623 Radar reading "no heading pulse"
The messages “NO HEADING PULSE” and “NO BEARING PULSE” means that the display is not communicating with the scanner (antenna). Both of these signals are generated in the scanner if you get this error check that the antenna cable is firmly connected and that the contacts are clean and corrosion free.
If the connection at the display looks good and feels like it’s properly connected, check the cable for any damage If you find damage you could try to repair the wires BUT (because of corrosion and moisture problems) IT IS STRONGLY REMENDED that the cable be replaced, but it’s kind of expensive $275.00.
The Part number is 000-130-034. Depending on the marine shops in your area they may have it in stock (or they can order one) but you can get it directly from Furuno at;
http://www.furunousa.com/Furuno/Rooms/Search/ProductPropertySearchResults?_webrFormIdentity=com.webridge.layout.FormLayoutExImpl%5BOID%5B47F81E95CB197F4C8708859EA0E22F08%5D%5D&_webrFormUniqueID=0&_webrCharacterEncoding=iso-8859-1&_webrLocale=en-us&_webrClusterUpload_2=&ptype=com.webridge.entity.Entity%5BOID%5BE670694808555649838ED263AA4CAB0A%5D%5D&productname=000-130-034&searchOption=normal&searchOption_webrHidden=radio
I hope it’s just a loose connection. Good luck!
Apr 28, 2008 | Furuno 1715 LCD Radar System GPS Receiver
Apr 28, 2008 | JRC 1500 MKII Radar
GPS Logo
67 people viewed this question
Top Simrad GPS Experts
Are you a Simrad GPS Expert? Answer questions, earn points and help others
