Question about Geneva Watches
Geneva watches 2813 user manual
How to change date
5 Suggested Answers
  • 14 Answers
SOURCE: Watch has correct day and date only 1/2 each day
The watch thinks at Noon it is really midnite, so you must scroll 12 hours ahead to repair this. There are usually 2 "clicks" on the stem of the watch when you pull it out, 1 will set time, 1 will set the day/date, be careful to pay close attention to which is happening when you pull out the stem, and setting should go well after that.
Posted on Dec 01, 2007
SOURCE: geneva watch bracelet
I Have a Geneva Made Pga Tour Partners Club watch that needs a new band and I have not been able to find one.It is a special band and the PGA partners club says they are no longer available and were not helpful in finding a band.
Posted on Dec 10, 2008
Sebin
  • 712 Answers
SOURCE: I don't know how to
Are you looking for an user's manual?
Posted on Oct 15, 2010
  • 2501 Answers
SOURCE: Hi I'm looking for a
The manufacturer's web site is oriented towards sales (in commercial quantities), so I couldn't find any instructions list.
Since most electronic watches operate in a similar manner, try a little experimenting.
To change the settings on a watch you need to enter the settings menu. This is done by pressing the "mode" button (often on the lower left) and using the buttons on the right to change the setting in the display.
Each time you press the mode button the display will step through the setting menu and when you have finished, keep pressing the mode button until the mormal timekeeping mode is displayed.
E.g. press the mode button until the present time on the watch face is showing and then experint with the other buttons on the watch to adjust it.
Have patience.
Posted on Jun 05, 2011
A Geneva watch model number 10026 water proof to replace battery
I only suggest you have watch service shop do the battery change, if you try to remove the back cover chances are unless you know what is what you will seriously damage the watch finish.
Mar 28, 2017 | Geneva Watches
How do I change the day, date etc on a GENEVA 7391 watch
read the instruction manual, Geneva Watches with Two or Three Hands
  1. Pull the crown out until you feel a click.
  2. Turn the crown counterclockwise until you have the correct time.
  3. Push the crown back in to set the time.
Geneva Watches with Two or Three Hands and a Date Window
  1. Pull the crown out until you feel two clicks. This second click position allows you to set the time.
  2. Turn the crown counter clockwise until you have the correct time. Push the crown all the way in to set the time.
  3. Pull the crown out until you feel one click. This first click position allows you to set the date.
  4. Turn the crown counterclockwise until you have the correct date. Push the crown back in to set the date.
Multi-Function Geneva Watches
  1. Pull the crown out until you feel two clicks. This second click position allows you to set the day.
  2. Rotate the crown counter clockwise until you have the correct day. Push the crown in to set the day.
  3. Pull the crown out until you feel a second click to set the time or the 24-hour hand.
  4. Turn the crown clockwise until you have the correct time, then push the crown in to set it.
  5. Pull the crown out just one click to set the date. Turn the crown clockwise until you have the correct date, then push the crown in to set it.
Geneva Chronograph Watches
  1. Pull the crown out two clicks. This second click position allows you to set the time.
  2. Turn the crown clockwise until you have the correct time, then push the crown in to set it.
  3. Pull the crown out just one click to set the date. Turn the crown clockwise until you have the correct date, then push the crown in to set it.
  4. Stop and start the chronograph by pressing the PA button, located above the crown.
  5. Reset the chronograph by pressing the PB button just below the crown. The PB button returns the chronograph second and minute hands to their original positions of zero.
Automatic Geneva Watches
  1. Wind the mainspring by turning the crown 15 to 20 times clockwise.
  2. Pull the crown out until it clicks.
  3. Turn the crown counterclockwise until you have the correct time, then push the crown in to set the time.
Tips & Warnings
  • Do not set the date or time between 8 p.m. and 3 a.m. to avoid damage to your Geneva watch. The gears sit too close together during these times.
  • If your Geneva watch becomes wet, wipe it dry as soon as possible. Keep your watch away from saunas and hot tubs, as the extreme heat diminishes the watch's water resistance.
Read more : http://www.ehow.com/how_6134550_set-date-time-geneva-watch.html
Jul 13, 2015 | Geneva Watches
How to I set the day on my Geneva watch model on612-m
keep pushing buttons till something changes.Usually you hold a button down for 3 secs then things start flashing,then you forward it to the time section
Feb 17, 2015 | Geneva Watches
How do you get back off betsey johnson watch to change battery
It is just pried off carefully with a thin pocket knife, or using the tool that pops it off. I would let a jeweler do it if I were you. You can buy a tool to remove the watch back on eBay.
Mar 18, 2013 | Geneva Betsey Johnson Silvertone Chain...
Geneva watch 5573
Geneva watches do not have an indention or tab. If they did, it would be a piece of cake to pop them open and change the battery.
Nov 23, 2012 | Geneva Watches
How do i set my Geneva Japan Movt 257 Watch?
You pop the 'crown' out (dial) then turn it till correct time, then push it back in. It's on E-how, depending on the type of watch, or how many dials it has, the directions may change.
Link: http://www.ehow.com/how_6134550_set-date-time-geneva-watch.html
Nov 28, 2010 | Watches
Geneva watch bracelet
Apr 01, 2008 | Geneva J06345 Wrist Watch
Dec 01, 2007 | Watches
Watches Logo
35 people viewed this question
Top Geneva Watches Experts
NOEL
NOEL
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Geneva Watch Expert? Answer questions, earn points and help others
