Question about Dometic Refrigerators
Fridge does not cool on either gas or electric. There is power and gas available and the lights work in the fridge and the motorhome is level. This has just started It tried to keep things cold, however it just kept thawing whatever was in the freezer
  • 11,896 Answers
Either the thermometer is bad, the thermostat is bad, or your coils need dusting. Is your compressor running?
Also clean the condenser assembly. Also check the evaporator tray to see if it is wet. It should be.
You also can remove the rear cover inside the freezer. Now, after the compressor has been running for about 25 minutes...You may have to leave the doors open to accomplish this, wet your finger and touch the silver evaporator coils from top to bottom and front to back. Does your finger tip lightly stick to these coils all over? It should be.
Next thing is to check the air diffuser assembly.....This one should have you nearing the end of this diagnosis. Good Job so far. Basically you have a electronic damper control which they are calling an air diffuser. It is located between the walls of the freezer and the refrigerator at the top rear. It is a vent that has a little motor controlled by the main control board according to the readings the thermistor relays to the electronic control. What happens is the little plastic door hinge breaks and the motor turns but the door does not open or close as programmed anymore. You may have to gain access from both the freezer and refrigerator side to remove this to inspect it for a break. If I remember correctly, there are little tabs on the freezer side that must be depressed to remove it into the refrigerator side. If this is broken, open the door manually about 1/2 of the way and reinstall.
Posted on Jun 23, 2009
Domitec fridge will not cool
Have you tried it on electric?
If the fridge is level, and the rear coils of the fridge are warm and the fridge does not cool, you will more then likely require a cooling unit. Arcticold refrigeration manufactures brand new replacement cooling units that are available throughout north america Visit ArctiCold Refrigeration We keep it cold
Feb 16, 2014 | Dometic Refrigerators
It was working fine it was unplugged to be moved now it wont work on electric or gas its a rm 760 gas or electric domestic
When operating on Electric, if the rear of the cooling coils get warm and the fridge is level, but the refrigerator does not get cold then it is more then likely your cooling unit that has failed. Visit ArctiCold Refrigeration We keep it cold for info on replacement cooling units.... I have also attached a video with tips on diagnosing the RV fridge,
Arcticold New replacement cooling units can be purchased from Ebay Dometic RM760 Brand New Manufactured Cooling Units LIFETIME WARRANTY
Sep 16, 2013 | Dometic Refrigerators
Dometic RM 4224 won't cool on gas or electric. The stack in the back gets super hot, the fridge is not cool at all.
First ensure that the fridge is level. If the fridge is level and still not cooling while there is heat on the rear of the fridge, then you will require a replacement cooling unit. Give Arcticold a call 1-888-782-6665 Web site: ArctiCold Refrigeration We keep it cold
Online Store: http://www.rvfridgerepair.com/
Aug 22, 2013 | Dometic Refrigerators
Fridge worked fine last camping season, this year light comes on in the fridge in AC mode, but won't get cold. It is a 3 way fridge in our motorhome, and we have always used it in electric mode only. I...
Also keep in mind that these units are very sensitive to being leveled; even a minor tilt will cause them to quit cooling. These units are not equipped with compressors as are home refrigerators which are not quite as fussy as the evaporative type.
Aug 04, 2011 | Thetford Norcold RV Cooler/Freezer
Refrigerator wouldn't cool
Hi!!
Is there any light coming on on the board?? If not, ckeck for Tripped Breaker or blown fuse, if OK, check propane tank.
Take the grill under the fridge or to the left of it, (4 screws), that's where the refrigerator's power outlet is, check for 120v or use an extension cord and plug fridge to it. If fridge works, check for short or loose wire from outlet to breaker panel..
Don't forget to rate this post. Good Luck!!
May 23, 2010 | Refrigerators
Any info on electrolux RA1300 gas fridge. Freezer works well but fridge compartment doesn't chill
If you had an electric fridge the problem is usually the evaporator fan motor ($30).
I suspect that you may have the same problem. Generally, freezers are cooled only, when the fridge needs cooling, the evaporator fan comes on and blows cold air from the freezer to the fridge compartment. The advice below is for an electric fridge but may also work for you, it's worth a try I suppose.
Check to be sure you can get a replacement fan first, they last about 4 - 5 years. Available from a parts supplier or electric motor company.
Unplug fridge, or disconnect gas etc. Fan should be located usually in top of freezer behind a vented cover plate. Remove cover, remove screws holding fan in, may have to cut wires. Replace with new motor, make sure the fan spins the same direction (CW OR CCW) as your old one, if you don't know which way it should spin then be sure it pushes air into the freezer area and doesn't spin backward drawing air from the freezer area.
Nov 10, 2009 | Electronics - Others
Motorhome fridge works on gas but not electric
I thik that whoever advised you of an underlying problem is very muich correct. It sounds like you are getting quite a bad short somewere in your system. I would strongly advise not turning things on as you may fry your entire electrical system. I would also get it checked by a qualified electrician. I hope this is helpful.
Nov 04, 2009 | Refrigerators
Our Dometic RM2193 cools on gas but does not work on electric
It could be as simple as a blown fuse at the fridge. Also check to make sure you have turned on the electric switch that allows the fridge to run on AC. Note, you can only operate the fridge on EITHER gas OR electric, but not both sources at the same time, thus, you have to turn off the gas switch before you can run on electric.
When this unit is running on electricity, it has to have the thermostat set for it to run.
Here's a link to the Dometic manual for your model.
http://www.alcovr.com/DATA/MANUEL/DometicRefrigeratorModelsRM2191&RM2193.pdf
Just follow the steps for running on electric and you should be OK.
Hope this helps.
Jul 30, 2009 | Dometic RM2193 Compact Refrigerator With...
I have a Dometic fridg in my 2005 motorhome and when I start my f
You need to unpush the gas button on the front control. If the gas button is pushed in, then it is trying to run on gas and with the tank empty, it is unable to light. That is why the check light is coming on. If you turn the gas side off and have it on auto, it should switch to the AC side and work fine.
Hope this helps,
Jeff
Jul 05, 2009 | Dometic RM2652 Refrigerator
Refrigerators Logo
103 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
