Question about WYSE S10 (90210501) Network Terminal
Getting a message about shadowing my session
I am Getting the following message, "Someone is trying to shadow your session. Allow this?" The wyse device is standalone. There is no server. We use a product calle Retina. It scans for predetermined vulnerabilities. Whenever we scan, we get the above message. How do I change the setting so this doesn't pop up?
  • 25 Answers
The program you are using is telling the terminal to accept a VNC request, as it will send date on the port open for VNC. So the terminal is asking you to accept the prompt to allow a remote machine to control your session.
You can set the program to ignore the VNC ports, so it wont get prompted. Failing that you should be able to change the terminals behavior to the requests by editing the wnos.ini to not allow VNC connections. I think that can be done from there. Check on the config generator for wyse terminals on technicalhelp.de to find the correct syntax.
Posted on Jul 07, 2009
A shadow on the picture
The shadow could be caused by a dust partical that is trapped. You could try to dislodge it with an air duster or a vacuum with a soft brissel attachment
Feb 07, 2014 | BenQ W100 DLP Projector
When i try to transffer data to the sandisk sd 2gb card im getting 0x8007045d error help please
it is because your card is formated as FAT ( this means that you can only store small files on it ). To fix this do the following 1. open my computer 2. right click on th sd card 3. press format 4. in format select fat32 instead of fat 5. click format (you will lose all data currently on the card) 6. when it is finished you should be able to copy files onto it
Mar 16, 2011 | SanDisk 2GB microSD Memory Card
2003 Honda VT 125 Shadow valve clearances
Hi, Moviemake210 for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
2003 Honda VT 125 Shadow valve clearances Google Search
2006 Honda VT 125 Shadow valve adjust Questions
Honda VT 125 Shadow Motowiki
https://www.partsfish.com/page/oem-parts-for-honda
https://www.ebay.ie/sch/Books/21672/i.html?_sop=2&_oac=1&_nkw=honda+shadow+vt125
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 23, 2010 | 2003 Honda VT 125 Shadow
How can i reduce my reduce my shadows
There are several things that you might try to reduce shadows. Be aware that you're not going to eliminate shadows completely, unless you're photographing a flat wall.
1. Move the flash off camera. This will require either a sync cord or some method of triggering it wirelessly.
2. If your primary concern is shadows on a wall, try to move your subject further from the wall. Obviously, the size of the room and the furniture may not allow this.
3. Diffuse the flash to soften it. You can buy a dedicated diffuser, or you can try draping a single thickness of a white napkin or tissue over your flash unit.
4. Use multiple light sources. If you want to use multiple flash units, again you'll need sync cords or a wireless system.
Hope this helps.
Dec 20, 2009 | Quantaray QDC-900WA TTL Flash
Need to tighten the timing chain
It has an automatic cam chain tensioner. If you are getting cam chain rattle, I would look at worn guides/chain.
Jul 22, 2009 | 1996 Honda VT 1100 C2 Shadow Sabre
2005 honda shadow spirit 1100. runs with choke on
Have you tried to adjust the tickover screw on the carbs?
Mar 18, 2009 | 2005 Honda VT 1100 C Shadow Spirit
I am receiving the following message when I attempt to access my Western Digital My Book 500 GB: "Ox8007045D I/O Device error" I can see that my photos are still there but cannot open them or copy into the...
Happened to me too in both file backup and computer backup. I supposed MS will address in the future. For now, go to the system settings and unchecked the drives so they no longer create shadow copies . Apply the new settings to erase all existing shadow copies. Then reset by checking the boxes you unchecked. Now try to backup the whole computer again. It appears a shadow copy error is conflicting with the backup process. Once you delete all shadow copies (restore points) it will work.
Jan 05, 2009 | Western Digital My Book Essential Edition...
Red shadow
bad connections on the converganc ics just solder them this will fix the problem if not replace them
Nov 03, 2007 | Sony KP-46WT500 46" Rear Projection...
WYSE S10 (90210501) Network Terminal Logo
1,256 people viewed this question
Top WYSE Computers & Internet Experts
Sunday Ojelabi
Sunday Ojelabi
Edward Greene
Are you a WYSE Computer and Internet Expert? Answer questions, earn points and help others
