Question about Kenmore HE2 Plus Front Load Washer
F1 erroe code - Kenmore HE2 Plus Front Load Washer
    Problem Solver:
  • 13 Answers
Without knowing the model number (found inside the door) it may mean that the drain pump is clogged.
Posted on May 19, 2014
I need help with the following erro codes.2
those codes ar the code to do the center of the universe xD
Sep 08, 2016 | BMW X3 Series Cars & Trucks
Cmos checksum erroe defaults loaded
press del to enter setup.then choose default bios setup. then save and exit.pc will restart.
Nov 17, 2011 | Gigabyte GA-945GCMX-S2 Motherboard
Erroe code f1e2
locare your model number and post it sometimes its on the frame under a drawer if u ahve a drawer if not check inside the oven for a sticker or tag,, or possibly if you top lifts up for cleaning check their..
this is a generic f1-e2 code listing it lists it as a control board problem and to replace the control board....
control boards vary but can be between usally 200-400 dollars so i would see waht is cost effective whether to just replace the unit depending on how old it is because after service call usually another 100 dolllars and labor to put it in u could be close to the price of a new range hope this helps
Feb 02, 2010 | Whirlpool Ovens
Error on my ps3
google the erro code type ps3 erro code put erro code here_
Dec 15, 2009 | Sony Playstation 3 (PS3) Console
Erro code SC541
Fuser error.
Fix problem (Fuse, lamp, or thermistor), then reset code by entering service mode and powering off/on machine
May 11, 2009 | Ricoh Aficio 450 Copier
Whirlpool washer Cabrio F1 erroe code
HE Top Load Washers
Models:
F1 Error Code
WTW6200S WTW6300S WTW6400S WTW6600S WTW6700T
MTW6300T MTW6400T MTW6500T MTW6600T MTW6700T
Serial Numbers: CT01 - CU52
There are four areas of concern that can cause the F1 Error Code. Each area must be sequentially addressed to ensure
that the diagnosis is correct and the proper repair is completed.
A) Air leaks in the air pressure (switch/sensor) hose.
a. Inspect the hose for cracks, pin-holes or loose connection.
b. Replace the hose and harness assembly (W10058730) if it is compromised.
B) Moisture in the air pressure (switch/sensor) hose.
a. Inspect the hose for evidence of water.
b. Replace the hose and harness assembly (W10058730) if water is detected.
C) Lint or flashing in the air dome hose connection port.
a. Inspect the air dome hose connection port for lint or flashing.
b. Use a small round device (small screwdriver) to ensure that there is nothing blocking the air dome outlet on
the tub.
D) The control needs to be replaced.
a. Replace the control only after you have completed steps A - C above, and verified that there are no issues
with the air pressure system.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 15, 2009 | Whirlpool WTW6400SW Cabrio Washer
CMOS erroe 0193
Remove the CMOS battery and also the jumper on the motherboard to reset the bios.
Oct 12, 2008 | IBM NetVista PC Desktop
Kenmore HE2 Plus Front Load Washer Logo
23 people viewed this question
Sal DeAngelo
fordexpert
Mike Squire
