SOURCE: Azpen a840 won't get WiFi & other tablets do
Go to WiFi setting gs n empty all n take a look at you at the restrictions n fix it
SOURCE: I have Azpen A720 I been having problems with
Failure to charge is due to 1 of 3 problems. The charger, the connector or the battery. Try changing the charger or use your computer's USB port. If that doesn't solve your problem, it can only be a bad connector or the battery. Since both of these are not user replaceable without voiding the warranty, you will need service. Batteries age and wear down. How old is your tablet and is it still under warranty?
Hard Reset
Press Vol-up&Vol-Down button at same time, Then press the power button.
This starts your devices Recovery Mode.You can do a Wipe/Factory Reset from there. Use the Vol Up&Down buttons to navigate and the power button to select.
Be Careful and DONT MESS with the Other options or you may Brick your phone.
SOURCE: Problems with Azpen A727 tablet.
Ya it does work but the pattern is not off yet I want it off so it can open without one plz clear it of the computer here r the details.
Model:A727
FCC ID: 2ABKRA727
