Question about GE WSXH208A Front Load Washer
The rubber in front of the machine has come out so has the metal spring that goes around it
    President:
  • 1,185 Answers
Two things
(1)
You need a new door gasket and retaining spring , The old ones are worn and will keep flipping off if you replace them
(2)
The only hope you have is that you pull clothes out of the machine in large lumps instead of a couple of things at a time and in doing so have caught the lip of the gasket and pulled it away from its seat.
It needs a man that knows to fix it, you can take the top off and feed the gasket and spring on your self if you have the required mechanical gumption
Posted on Jun 23, 2009
  • 57 Answers
Take lid off put rubber back in place and put the metal holder around the rubber with screw loose try have the clip connection to the top as this helps with tightening. tighten screw and jobs a good un
    Problem Solver:
  • 5 Answers
I just changed that rubber boot seal myself and it wasn't much fun but it is done thank God. Mine was torn and only a little over a year old.
Posted on Jun 27, 2009
Loose rubber seal and a circular metal bit has come off it has a spring at the bottom
That is your door seal with a spring that goes all the way around it and has a screw that holds the spring tight together.
Jul 09, 2015 | Washing Machines
I have a samsung front loader 7.0 model
The metal ring goes around boot/seal to hold it to front panel / frame
Nov 11, 2017 | Washing Machines
Front seal came off
Sometimes when the load get tangled during the cycle and you try to pull all the load out in one go, you can dislodge the seal and retaining spring. Remove the wire around the door seal, repositioned the seal around the edge of front panel porthole. There is a folded metal edge around the metal frame and the grey rubber gasket lips over this, once in position, offer up the metal retaining band and use a pair of long nosed pliers to stretch the spring so you can get it to sit around the seal. Sorry this a little long winded but very difficult to articulate properly, so I hope you get the gist. Cheers
Mar 26, 2013 | Bosch Washing Machines
The rubber ring inside the washing machine came out and a metal ring was under it, i dont know how to fix it?
that rubber is called the bellow. snap the bellow back to the machine. place plastic ring over it into the grove and work it all the way around. that metal ring should have a spring on it. use a needle nose pliers and pull the spring so it stretches, metal ring should snap right in place.
Feb 05, 2011 | Whirlpool WFW9200S Front Load Washer
Rubber seal inside door came off-how do I replace it and where does the retaining wire/cable go?
Reinstalling that rubber seal is a lesson in patients. There is a metal lip on the machine opening and a cooresponding groove in the rubber seal. These two need to be mated together. That's the easy part. Once together, the retaining wire and spring go around the rubber seal just on top of where the rubber seal goes over the matching lip. It will take several tries, the spring may be small but it's very strong and difficult to stretch. Good luck.
Jan 12, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Rubber around the washer has come off - there is a thin mental wire but it does not seem to fit well. I have also lost the manual which may have a picture in it.
The thin metal wire should have a loop on either end. Connecting the two loops is a spring, that wire/spring combination holds the rubber seal around the tub opening. Putting the wire back on is a lesson in patience. The rubber fits in a slot on the back and the wire holds it in in the front. Good luck.
Nov 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The rubber gasket around the tub fell off on front loader
Open the door and reinstall the bellows (door gasket) onto the door lip. The metal ring clamps the bellows to the door lip. Start in the groove at the top and work your way down the sides. The spring part goes on the bottom (be careful not to stretch it too much). An extra pair of hands could help.
Let me know if you need more assistance.
Apr 02, 2009 | GE Washing Machines
Kenmore elite duet 410 metal wire for gasket came off
is it a metal wire connected at bottom with a 2-3inch spring???? is so it secures the "bellow to the front lip of the machine. youlll need to stretch it over the front "bellow lip after installing the "bellow"
Jan 27, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore HE 110.4751 front load
soild metal part fits in groove around door boot spring goes in at bottom they can be tough to get back on after inserting in groove around seal you'll have to stretch the spring and pop it under at the same time band will try to come back out and roll seal back off lip..good luck
Jul 16, 2008 | Kenmore Elite 45986 Front Load Washer
Metal ring aroound rubber seal fell off.
Start with the spring at the bottom, work the retainer around until the seal starts to pull away from the washer. Now grip the loop that the spring attaches to on the side that isn't in place and open the retainer. Push the retainer in place and release the spring.
Jan 09, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
GE WSXH208A Front Load Washer Logo
435 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Marvin
Marvin
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
