Question about Whirlpool Heating & Cooling
What is the voltage requirement for a Whirlpool ACE184XDO unit?
  • Malcolm Montgomery
    Malcolm Montgomery May 15, 2014
    Hi Mike Noles, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? Please confirm that model number. Is it a window or portable or fixed unit? If fixed, is it commercial or residential?
Can you use a navman in truck with 24 volt supply
You need to meet the voltage requirements of the unit. The power charger will provide the voltage for the unit (normally around 5 - 12 volts). You will need to drop the voltage to the required operating voltage from 24 VDC. Perhaps you can use an inverter, and then just use the AC charger.
Mar 25, 2015 | Navman GPS
How do I know if the timer module is bad
confirming the timer requires you to test the output and input voltages on the unit and so requires a mulitmeter to test the voltage and also the continuity of the controller switching.
Jun 09, 2012 | Whirlpool Washing Machines
Whirlpool Cabrio washing machine button does not work.
Possible that the main controller unit is faulty. You need to confirm the voltage on the controller unit and the connectors to the panel.
If there is no support from the controller then it can be faulty.
This requires testing the board for the processor and the set voltages for the board to function which must be measured..
Jun 05, 2012 | Whirlpool Washing Machines
Good evening. I have a Whirlpool freestanding electric range GFE461LV that I bought in 2009 and for the first time I will install it. This is because I am from Brazil and since 2009 we were expecting our...
It is 220 V with a neutral conductor. If you are installing it in the United States, local electrical codes may require using a 4-wire cord (two wires for the 220 Volt connection, the neutral and the cabinet ground); otherwise you can use the neutral for grounding with a 3-wire cord. The cord and two-pole circuit breaker in your electrical service panel should be rated for 50 Amperes.
You can download complete installation instructions from Whirlpool. You can also find the Owner's manual and other documentation at the Whirlpool site.
Jun 20, 2011 | Whirlpool GFE461LV Electric Range
Washer is plug in dont get no power
  1. Check the line voltage, make sure the outlet is given you the required 120v. If not, then check for blown fuses.
  2. Check for voltage going to the CENTRAL CONTROL UNIT by listening for a click when unit is plugged in. If no voltage you may need to replace the CENTRAL CONTROL UNIT
  3. Unplug the unit before continuing
  4. Check continuity of line cord and line filter
  5. Check harness connections to CENTRAL CONTROL UNIT
  6. Check touch pad/ Led assembly
Feb 09, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The water heater does not react to lowering the temperature...water is above 130 degrees... This is a whirlpool energy smart residential water heater that was bought and installed in Mar of this year. It...
Product features show on link below
http://waterheatertimer.org/Whirlpool-Energy-Smart-electric.html
Energy smart manual shows troubleshooting chart on page 14
http://waterheatertimer.org/pdf/Whirlpool-energy-smart-electric-manual.pdf
Initially I would guess the temperature sensor is bad.
However indicator light would flash 3 times.
And since both elements have a temperature sensor, it's unlikely that both would go bad at same time.
That suggests the Self-diagnostic Control Box located on top of heater is defective.
Turn off power at the circuit breaker and see if unit resets correctly.
Manual shows 1-877-817-6750 number for Whirlpool parts and warranty.
Your unit is still under warranty, so control box and other parts should be free.
Keep in mind this water heater requires 10 gauge wire and 30 amp breaker.
If you are running smaller wire or smaller breaker, that could affect long term operation of electronics.
I guess this requirement is so voltage drop from element turning ON doesn't starve electronics in control box
On the control panel, the Red and Black wires connect to 240V from circuit breaker.
Wires appear to pull out of socket using needle nose pliers. It will be important to keep wires in same order.
Take photo of your wiring before disconnecting anything.
To order parts, you must give serial number located on label on side of tank.
Serial number will identify your specific heater to person answering phone at Whirlpool.
Installation part should come with instructions, but ask the person at Whirlpool what steps they took during training. Whirlpool rep might have helpful tip they learned during training.
Add a comment and let me know about your transaction with Whirlpool so I can pass it along.
Dec 19, 2010 | Whirlpool Water Heaters
Power Button will not turn on.
Verify proper line voltage is present at the outlet. This will require the use of a voltage meter. If not properly trained, I would consult an electrician to verify the voltage.
Part of the troubleshooting proceedure requires the technician to verify that the applience is receiving the required supply power.
This has to be verified at the outlet to eliminate the possibility of a bad breaker or bad connection inside the breaker panel or outlet box.
Hope this helps in finding the solution to your problem..
Thanks and good luck..
Jul 26, 2010 | Whirlpool LEW0050P Electric Dryer
Dryer runs but does not heat
if electrical check house fuses or breaker its best to take a voltage reading , if fused don't trust the blown looking some won't show burnt if got proper voltage the door switch is not making or the thermal fuse open and this requires disassembly of unit
Aug 20, 2009 | Whirlpool WED6400S Electric Dryer
No heat in whirlpool duet dryer replaced the thermistor still won't heat what next?
You have this listed under "Front Load Washer" and don't explain which type of of dryer you have (Gas or Electric). I'm assuming this is an ELECTRIC dryer, since you mentioned a thermistor. The following link will explain how to troubleshoot your dryer no heat problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
The symptoms of a dryer no heat problem are, the dryer drum will still spin, the blower fan runs, and all indicators function, but the dryer does no heat. If this is the problem you are encountering, then the link I provided for you should help you find your cause.
The first step to troubleshooting this problem is to check the voltage at the wall receptacle across the two hot leads (the two large slots in the receptacle - each leg to neutral reads 110-120VAC). A reading across the two hot leads should yield 220-224 VAC. If the voltage is incorrect, this can cause the heating circuits to fail, but allow everything else to work. I have seen where one leg of the 220VAC circuit is tripped or not working at all and causes the wall receptacle to read 1/2 the normal voltage that is required. This could be a problem with the circuit breaker panel or wiring in the wall receptacle. The heating circuits require 220VAC to operate, while the controls and drive motor only use 110-120VAC. If the voltage is correct at the wall, check the voltage at the terminal block in the back of the dryer. This is where the power cord attaches. If the voltage is correct at the terminal block, the problem is in the heating circuits. If the voltage is not correct at the terminal block, you may have a bad power cord.
NOTE: Please ensure you UNPLUG the dryer when replacing any internal components. Dangerous voltages are still present with the unit turned off.
Now...what controls the heating circuit in a Whirlpool manufactured dryer is the Thermal Cut-Out (TCO), the Hi-Limit Thermostat and the Heating Element. I'm assuming you replaced the TCO(?). If you did, it is recommended that you replace the TCO along with the Hi-Limit Thermostat. Failure to do so can result in premature failure of components you may have already replaced.
The link I provided explains all this. Please read through the information I provided and let me know if you have questions. If you require further assistance, please let me know before you rate the solution. I hope this helps you resolve your problem.
Feb 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Heating & Cooling Logo
Top Whirlpool Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
