Question about Pentair Intelliflo Vs3050 4speed Pool Pump Ee 011013
Pentair Tagelus 60 sand filter- why is valve always so difficult to install?
  • 2,760 Answers
1st why are you removing the valve so much? you might be proforming a routene task incorrectly . also when i put any valve back in i allways give it a lite coat of waterproof grease on o-rings and ball cock, this stuff can be got from any well stock hardware store in the kitchen sink section (same stuff you use on faucets) so you know it\'s food grade ,dont use car grease !!!!
Posted on Dec 11, 2014
2 Suggested Answers
john224
  • 1378 Answers
SOURCE: I have the Pentair AT 251501 in-ground pool pump.
Yes, but not recommended. If you are going to use it on an above ground pump the system head will drop to a very low number and the pump will operate very high on its pump curve causing a couple of potential problems.
First, your filter will have to be rated for the high flow. I do not have Aqua Tools curves or numbers to give you an exact figure but if you have your horsepower you can look it up on the web. Your filter needs to be rated that high or you will have problems; even a filter failure.
Your pump will exceed the hose flow ratings and may require PVC plumbing to operate.
You should consider plumbing in a throttling valve on the pump discharge to help moderate these problems.
Posted on Dec 14, 2009
I overfilled my pool and need to drain the excess
if you have a sand filter. you can economize and perform a long backwash cycle. this will clean the sand and lower the water level. otherwise, just use the drain/waste option. if you have a cartridge filter, your manufacturer should have installed a three way drain valve between the pump and filter. by turning this valve, the water will be diverted from the filter to waste
Sep 29, 2014 | Pool & Spa
I have sand coming out of the bottom of the davey tagelus 230 sand filter and in the pool. is this repairable with a service or should after over 25 years look at a replacement?
25 years????
That is awesome, and you absolutely got your moneys worth.
Get a new one, but if budgets are slim, as with most of us, then you can repair your filter...
Get a new drain and lateral assembly. (that is what failed)/
You will need to know the size and or model of your filter.
You will need to remove the valve if top mount; shop vac all of the sand out then rinse tank.
Install the new lateral ass\'y then...
Add new filtration media (recommend glass over sand) and reassemble any plumbing removed to access internal of tank.
Good Luck
Sep 05, 2014 | Pool & Spa
How to replace sand in a jandy st24-t
there is a nice big o ring between the valve and the filter body. chances are that it is dried out and holding fast. it will take some muscle to separate the two but it can be done. be prepared to change that o ring on re-assembly.
here is a breakout plan to help you visualize
ST18 ST 20 ST24
Sep 01, 2014 | Pool & Spa
Pentair tagelus t60d filter filtering algae back into pool
Have you backwashed the unit? That would clean out remaining algae.
Jun 18, 2014 | Pentair Tagelus TA 60D Filter
I'm getting a little sand in the discharge during back wash
that is usually caused by damage to the fingers (laterals) on the standpipe. most times this damage comes from improper winterization or when sand is changed by non professional
May 30, 2014 | Hayward SAND FILTER, PRO SERIES
Change sand in tagelus filter
So you have a "TA" filter. Which size?
It does not matter really, otherwise I would have been able to know how much sand you you have to remove and how much to put back in.
Anyway, To change sand you have to remove the MultiPort Dial valve on top.
Then, you can either unplumb the filter and roll it over on its side and using a garden hose, start washing the sand out or use a shop vac, with keeping it upright.
Whatever you do NOT damage the laterals on the bottom of the filter. When refilling with sand you want to make sure all the laterals are undamaged and in the down position. Always fill the filter half full of water, at least over the laterals by a few inches, to keep the sand from damaging the laterals while re-filling the filter with sand. Make sure you use pool filter sand and not play sand! And... cover the stand pipe!!! Use duct tape or some kind of covering (spout cut off a water bottle then covering the pipe). Otherwise you will get sand into the standpipe and into the laterals, then you have another problem.
Apr 23, 2014 | Pool & Spa
Not filtering
too many chemicals will cloud contact the company website or did you maybe its the water change the water
Feb 28, 2017 | Pentair Tagelus TA 60D Filter
GASKET CHANGE: What steps should I follow to change a leaking gasket on the diverter on the valve of my DAVEY TAGELUS 230 sand filter?
make sure the valves on the outside of the pool are closed so when you open up the valve to change the gasket the pool water will not continue to run out of the filter.
Once you are secure about water flowing out of the pool through the filter you can remove the bolts holding the filter body together and change the gasket.
Rod
US Parts Center
Feb 06, 2013 | Pool & Spa
Pentair Quad DE system was installed without multiport valve
This is a DE (Diatomaceous earth) IT doesn't have sand and doesn't backwash. You use the bump handle (with pump off and valves closed and vent open and drain dirty water/earth out) Here is a link to the manual for your filter If isn't the exact model they are all on their web site: http://www.haywardnet.com/products/Manuals/pdfs/manual9.pdf
Jul 20, 2010 | Hayward EC-40 DE Pool Filter with pump
Pentair filter
I am sure that you already have an answer to this, but IF you can not read the valve label sticker, call the Pentair Customer Support 1-800 number. They will send you out a new label, free of charge.
For referrence, the waste position is ALWAYS over the waste port on the valve.
Jun 14, 2009 | Pentair Meteor Above-ground 22" Sand...
Pentair Intelliflo Vs3050 4speed Pool Pump Ee 011013 Logo
35 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
