Question about Acer Aspire One PC Notebook
My Acer Netbook 10.1 touch pad stopped working. I can still use a usb mouse but the pad seems to be dead. I checked the settings in the Win XP SP3 control panel and they appear to be correct. Any suggestions?
  • 390 Answers
Hi
you might have accidentally pressed teh touchpad togle button try the fn+f7 key or some other function key with the rectangle and a hand figure on it
hope it might have helped
cheers
Posted on Jun 23, 2009
  • delbrownd12 Jan 09, 2011
    Yes this really helped .... thank you.
I had the same issue, but tried the FN-F7 and bam it worked, thank you all for sharing the solution on this post,, this was driving me nuts, and I was thinking i was going to have to search for a driver for this issue
Posted on Nov 24, 2009
HP retractable mouse in Acer notebook stopped working.
maybe your mouse has gone bad, i've had that happen before
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Feb 15, 2012 | Acer Aspire One D255E13438 Netbook
Acer one mouse problems
The easiest thing for you to do is get a usb mouse. Something happened to the wiring underneath the touch pad or the motherboard is failing.
Dec 04, 2011 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire One Netbook Touch pad mouse not working
There is a small ribbon cable that connects the touchpad to the motherboard. If there was any dramatic jostling of the system or it was disassembled for any reason it may have come undone. I have heard of this happening in the past.
If your lucky, someone just turned it off. The toggle for the mouse pad is Fn+F7 simultaneously.
Good Luck,
NOLA Tech
Feb 06, 2010 | Acer Aspire One Netbook
Touch pad and mouse butons don't work at all.
On laptops, sometimes your TouchPad is disabled for no apparent reason. To reactivate it, first try restarting your PC. If there’s no good change just try:
We need the software driver and your mouse are installed
This trick works in Windows XP and Vista
Go to Control Panel> Mouse> Settings tab of the device
Click <Enable> (or <Disable> to disable)
Please go through this image, will help you..
Notes:
On some models, there is a keyboard shortcut to activate or deactivate the touchpad. For example, a ACER, just do Fn + F7.
You can click Reset device if neither of those solutions will work. ..
Please revert for further clarification....
Jan 16, 2010 | Acer Aspire One PC Notebook
Touch pad mouse will not move
There will be a button above the touch pad or using function key to disable it. try both and find out which is the prob. Some drivers may not installed properly. Run the touchpad driver in administrator mode and if you are having the xp driver set to xp sp3 compatible mode.
Jan 13, 2010 | Computers & Internet
Touchpad does not work
in such case you can restore your program to old date...such as 5 days before.. hope your touhpad will work like before..
restore your program to the early date from when your touchpad was working...
reinstall touchpad driver....
otherwise you have to reinstall your Operating System...
Jun 23, 2009 | Acer Aspire One Netbook 8.9" Notebook
Netbook touch pad quit working after attaching a USB mouse
Go into the mouse options in the control panel and make sure that the touch pad is not disabled.
May 31, 2009 | ASUS Eee PC 900 Notebook
Acer aspire one touchpad right button not working
you can try using the function key ( fn ) and the touch pad key on my acer it is the F7 key hold the fn key and press and release the touch pad key that will turn the touch pad mouse off and on also goto control panel / mouse and try switch primary and secondary see if that will make the right button work if not its probly hardware related and your best bet is to keep the external mouse going rather than fixing that one
Mar 24, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire One  PC Notebook Logo
2,475 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
