Question about LG Dryers
LG 55" LED TV front buttons no longer work, remote OK
nandosnut
  • 112 Answers
SOURCE: push on button dvr says set 2
Press ENTER and number 2 together on the remote control for at least two seconds to restore control.
Posted on Apr 21, 2009
SOURCE: We just bought a 55LH90 LG LED tv. Our directv
I used my directv remote to access the setup and was guided through the steps to make my directv remote the "do everything" remote.
Posted on Nov 03, 2009
  • 4 Answers
SOURCE: LG TV no longer responds to the remote control..
I have had the exact same problem with my 47LG70 after 13 months of use. I changed my remote control sensor but it did not help. Before you do that, try something simple which seems irrelevant. On this website, others have posted success by plugging in any standing set of headphones into the remote control or headphone jack on the rear TV panel. This solved my problem. So I proceeded to thoroughly dust all of the input/output component jacks on the rear and side of the TV with an air-can. This solved my problem and I do not need to have the headphones plugged in. So try these two things before changing the sensor.
Posted on Jan 23, 2010
  • 5 Answers
SOURCE: On my Samsung LED TV Series 6 I can't use my remote to
You should be able to receive a replacment remote under your limited parts warranty. If not, there are several resources on the web.
Posted on Mar 10, 2010
SOURCE: LG 26lx1d tv will not turn on. Power supply is
Have an LG26Lx1D for about 3 years, dropped off by my son.(Figures).Power light just blinking, but went back to red.Removed back panel, and metal cover. Just above antenna/cable input, its a small fan,mine was full of dirt. Blow off dirt, and make sure its turning freely.
Install back the covers, an voila....its a miracle...its working again.
Good luck
Posted on Mar 21, 2010
Remote code for newly tv lg
If your Bell remote is universal, you have to use its code search feature to seek a suitable code for your LG TV. If a search through all codes stored in the remote produces nothing, you may have to try another universal remote.
Feb 11, 2015 | LG 55ls5700 55 Edge Led Smart Tv 120hz...
Master reset lg led 55
hi try this, press menu on the tv and menu on the remote, if this don't work try ok on the tv and ok on the remote hope it works
regards
shaun
Jan 17, 2014 | LG 55LM6200 55 1080p 120Hz 3D WiFi LED...
Standard remote won't work away from tv
If you could not get range from the remote, try by replacing its battecies. Still there is no result, replace the infrared signal emittion diode [LED] at the remote control.
Dec 14, 2013 | LG 55 55LW5600 3D LCD TV
LG tv remote control not working
change crystal on the remote.........to check if remote is ok use ur camera mobile......how--
1. switch on your mobile phone camera.
2. Set mobile so that you see the bulb(LED) of remote on your mobile screen thru mobile camera
3. Now press any button on remote (ensure batteries are installed in remote)
4. If u see a purple light comming out of the remote bulb(LED) then remote is ok......change remote sensor ( also called eye) of your TV
Mar 28, 2013 | LG Televison & Video
I can not get the power lights and standby lights to turn off even when i turn them off in the menu , the remote is sluggish, and if i turn tv on on the tv i get a long beep my tv is a 55 inch led lg...
First thing to try would be to update the firmware. This link should take you to the LG support site where you can find the download and instructions you need to update your television. Look under drivers and software. Good luck.
http://www.lg.com/us/support/product/support-product-profile.jsp?customerModelCode=55LE5500
Apr 28, 2011 | LG 55LE5500 55 in. HDTV LED
The manual buttons and remote no longer work on my LG 42LC2D. The girl at LG said to reset it by holding the on/off button for 40 seconds, wait 15 seconds and try it again. Still does not work.
U got no power LED light on front of the tv?Check power source like unplug,replug.Ur oulet have power, test it with other devices.All still nothing ur power board it dead.
Dec 18, 2009 | LG 42LC2D 42 in. LCD HDTV
Nov 02, 2009 | LG 55LH90 55 in. LCD HDTV
Model ws-55711, remote doesn't work but I don't believe it is the remote control, can only change station up or down manually, cannot adjust volume or others manually...
If you can change channels with remote then TV is OK because it has only one infra red receiver (remote receiver) to catch remote signals.
So TV remote seems bad as it works on channel buttons only.
Here is an easy test for remote, watch remote front through any digital camera or even cellular phone camera will work and press channel button on remote, you will see blinking LED at front of remote while watching it through camera. Now press other buttons of remote and I'm sure that LED wont blink.
Sep 07, 2009 | Mitsubishi Televison & Video
Dryers Logo
11 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
