Question about Electrical Supplies
How to fit extra electric socket ?
Want details of how to run off electric socket to produce another
  • 15,645 Answers
On an electrical outlet, the back of the socket has three connections. One is HOT, that is the black one. One is neutral, that is the white one. One is ground, that is the bare copper one. You can see if the connections are made to the screw on the side or inserted into the back of the socket through a hole after the wire is stripped. In either case you just add another set of wires to the socket at the unused connections and feed that wire to where you want it to go. There are several things that you should know though. Wire has a SIZE. You cannot change the size from what is already present. You have to stay white to white and black to black, ground to ground. Wire has a definite length. You cannot go far with slim wire. Lastly the number of outlets on a circuit is limited. Too many causes a potential for overloads. The electrical code is very complex and if you dont know what you are doing, you should pay to have someone that is licensed do it.
Posted on Jun 13, 2014
Dewalt dg6000 runs but will not produce electricity
A problem here to get spareparts fitted on youre engine has hopeful priority in your case. because of the partsdelivery almost are discontinued. beware on the costs of other parts .
Detail Detail
Oct 28, 2016 | Electrical Supplies
Why does generator run and does not produce electricity?
You need to determine if it is a Brushed or Brushless generator and follow the tests on the link below. (You will locate the brushes on the end of the alternator in a 12o'clock position if they are fitted).
http://www.generatorguru.com/help-me-fix-my-generator-repair-advice/
Then contact Generator Guru with the results and they will let you know what needs replacing. This is a free service.
Aug 06, 2015 | Electrical Supplies
The wires come off the pump so i put them back on now i got nothing working
Also,
please note that all electrical wiring and installation details given on diydata.com is for information purposes only. From 1st January 2005, the Building Regulations Part P requires, in England and Wales, that only certified persons can carryout electrical installation work, or the work must be certified upon completion - see this page for more details.
Ring circuit
(1) The ordinary wall sockets around the house are normally connected to a ring circuit (also referred to as a ring main). The ring circuits of a domestic property supply the socket outlets and fixed appliances in the premises.
(2) The 'ring' is formed by the cable going from the consumer unit to the first socket, then on to the second socket and then the next socket etc. until the cable returns to the consumer unit. This means (in simple terms) that every socket on the ring circuit has two cable routes back to the supply. The cable of the ring circuit consists of a red (live) wire, a black (neutral) wire and a bare copper earth wire, all three being enclosed by an outer PVC sheathing. The cable used in domestic ring circuits is either 2.5sq mm or 4.0sq mm twin core and earth, these are rated (in free air) at 24amps or 32amps respectively.
(3) Each ring circuit is protected by a 32 amp fuse or trip fitted in the consumer unit. Modern installations incorporate a Residual Current Device (RCD) before the consumer unit which trips the whole system off if a fault is detected.
(4) In older houses the cabling for ring circuits (and other circuits) may be fed through the wall cavity with the cables coming into the back of the wall mounted socket. This is unacceptable in new premises and extensions. It is now considered that cables within the cavity may become wet causing the insulation of the cable to break down and moisture running down the cable into the socket. When rewiring older houses, new cables should not be run through the cavity, they should be run through new ducting embedded in the inner wall surfaces or under floorboards.
(5) A ring circuit is considered to be rated at 30amps (7200 watts). A ring may serve up to 100 m sq of floor area and, in theory, may have any number of sockets outlets or fused connection units connected to it. With each socket outlet is normally rated at 13 amps, as a 'rule of thumb', they are limited to under twenty outlets, it is unlikely that the variety of domestic appliances being used at any one time will exceed 30amps. The length of cable used in a ring circuit is limited to 50 metres for circuits protected by an MCB. The sockets are normally mounted flush with the wall although surface mounted boxes are often easier to fit when sockets are added to the circuit. .
(6) High power electrical appliances (such as cookers, showers etc.) should not be connected to a ring main even if they use less current that the 30 amp rating of the ring circuit. Connection of such appliances will reduce the number of other appliances that can be use simultaneously and will lead to nuisance trips at the consumer unit.
(7) It is advisable to have at least two ring circuit in all premises, in multi floor houses, one for each floor. The kitchen may have a large number of electrical appliances so a separate ring circuit for the kitchen may also worthwhile, this has the added benefit that a freezer will not be affected if there is a fault elsewhere. A single ring circuit should serve a floor area no greater than 100sq m (or 120sq yd).
(8) In the UK, plugs used on a modern ring circuit have square pins and each plug is fitted with either 3 or 13 amp fuses. The correct fuse should always be fitted to suit the appliance, 3 amp fuses for appliances rated up to 750 watts, (lamps and clock radios etc.) - 13amp fuses for larger appliances up to 3000 watts.
(9) Spur extensions can be connected to the ring circuit. A spur is a socket connected into the ring by a single cable run so the socket does not have the full benefit of two cable routes to the consumer unit. Spurs are often used when a socket is added, it is easier to connect using a single cable rather than extending the ring circuit to include the new socket. A spur extension can be connected to the ring circuit provided that it supplies only 13 amp socket outlet (although that can be a double socket outlet) or one fixed appliance. Over the whole ring, the total number of spurs must not exceed the number of socket outlets directly on the main ring. No more than two separate spurs may be connected from each outlet on the ring.
Removal of the front of a wall socket will give an indication of the circuit connected to it:
A single cable connected to the terminals indicates that it is an existing spur.
Two cables may indicate either that it is on a main ring circuit OR that it is a spur with another spur connected to it. This is not a recognised configuration but possible if both spur sockets are single sockets.
Three or four cables normally indicate a socket on a main ring circuit with one or two spurs running from it.
If the wiring has been changed by a previous diy'er, it may be possible to identify any added cables and then deduce the original circuit.
Ring circuit fused outlet units
Where connection to a fixed appliance is required, a fused outlet unit may be fitted to the wall (rather than a plug socket) and connected into the ring main. These outlets require the correct fuse rating for the appliance and are connected to the appliance by a cable or flex. The outlet may be switched or unswitched and may be fitted with an indicator light to show when the supply is connected.
Where a flex is taken to a heater of any sort (e.g. night store heater) the flex must be of a special 'high temperature' type suitable for the elevated temperatures encountered. Use of ordinary flex will result in the insulation breaking down causing the flex to become dangerous.
A clock outlet is a similar type of unit, but with a small fuse fitted in a special plug connected to the flex. The plug may be retained in the socket by a screw or knurled thumbscrew. Though called a clock outlet, they are also suitable for other small low current appliances such as extractor fan units, door bells.
High Power circuits.
Within domestic premises, there may be a number of high wattage appliances, the most common being an electric cooker, immersion heater and electric shower. Each of these appliances should be connected to the consumer unit using a dedicated fuse/trip and cable run. The installation instructions for the appliance should detail the wattage of the appliance (which will also normally be shown somewhere on the appliance), the amperage of the fuse/trip and the size of cable required. Any switches on these circuits must also be of a suitable current rating. Source(s): http://www.diydata.com/planning/ring_mai...
May 17, 2011 | Hoover Washing Machines
Ubwarcher07 ... No beeps, but there is not a hard drive with an OS hooked up... will it beep without this? Do I really need the eatx12volt plug plugged in to run? I thought this was "extra power"...
The system will not beep without an OS drive, but it will display a message on the screen indicating it cannot find a working operating system. The extra 12volt connector on the motherboard is for the microprocessor or Intel P4 chip. If your video card requires extra power it will have sockets on the card. If your power supply does not have the extra connectors you can purchase adaptors from www.CablesDirect.com, or you can upgrade your power supply. Is it necessary? I would recommend using the extra power connectors since it will help control the current flow producing less heat and damage to your system.
Mar 03, 2011 | ASUS M2N32-SLI Deluxe/Wireless Edition ATX...
The on car computer tells me I have a stoplight out when I indicate and when I brake it says that the indicator is fulty. all bulbs have been changed to no avail.Car is a 407 but did not have that option.
any other electrical faults? any aftermarket electrical equipment been fitted about the same time as the light problems?(phone chargers, Sat nav',  etc.-remove temporarily to make sure they are not interfering with operation of electrics) are you sure all the bulbs fitted are the correct type - a twin filament bulb fitted where a single should be perhaps? maybe remove any bulbs fitted recently and see what happens. poor battery condition/low voltage/dirty connections at battery or earth wires can cause electrical problems like this. give more details of vehicle - year, model, spec etc. and say if problem is intermittent or every time you use the brake +/or the indicator. if you have a tow bar and trailer light socket fitted to it water entry into the socket could be the problem.
Mar 05, 2010 | 2005 Peugeot 405
Require speakers of sony make model no.DVPNS67P
The Sony DVP-N67P is a standalone DVD player which was produced solely for the Indian market with two analogue left and right audio outputs (phono sockets) and coaxial and optical digital outputs.
You cannot fit speakers directly to this unit, instead you must fit an amplifier with suitable matching input sockets and a connecting lead and then fit whatever speakers suit the amplifier. The amplifier and speakers can be of any brand, they do not have to be Sony.
Nov 06, 2009 | Sony Televison & Video
I'm just about to have a towbar fitted on a new car for a caravan. I am unsure whether to have a 13-pin socket fitted, as up till now our old caravan and car had just the 7-pin sort for the tailboard and...
Saves having to use a supplementary socket
01 Yellow Left Indicator
02 Blue Fog light
03 White Earth (35amp)
04 Green Right Indicator
05 Brown Right Side Light
06 Red Brake Lights
07 Black Left Side Light
08 Yellow Reversing Light
09 Green Permanent live
10 Blue Ignition live
11 Red Earth (35amp)
12 Black Coupled Trailers
13 White Earth (35 amp)
Aug 31, 2009 | 2007 Volkswagen Golf
I changed the towing socket for my caravan.
White is usually for earth wire. The fitter may have just used another white wire for reverse light. use a test light or multimeter to see if you have positive power to the extra white wire while in reverse.
Aug 09, 2009 | 1999 Isuzu Trooper
Blowing warm air. Noticed that electric bill the month it stopped working was triple. I assume it was working hard to produce cool air
Yes, the compressor was working extra hard to try and keep the place cool. Freon must be escaping from somewhere. Hopefully, it is just from the schraeder valve stem. If evaporator is iced up, run it on fan to thaw out the ice before applying freon to unit .
Jun 27, 2009 | Heating & Cooling
Electrical Supplies Logo
286 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
