Question about Vehicle Parts & Accessories
Probable cause chevy 2000 2500 6.5 p0219 - Vehicle Parts & Accessories
  • 641 Answers
I ran the computer on my 2006 Chrysler touring and it said po219, does anyone have a clue as to what I need to fix to get my car going. It won't start at all
P0219 is engine over speed condition. Usually pops when the transmission slips. It doesn't keep the engine from starting though. What happens when you try to start it?
May 01, 2016 | Chrysler Cars & Trucks
Is the instrment panel a computer in itself
It's probably a fuse, did you check all fuses yet?
Have you modified the computer in any way recently? Added a mod chip? If so then yes you may have fried your computer, #1 cause of dead computers, actually probably the only real cause of bad computers in cars.
Aug 03, 2014 | Metra 40-cr10 2007-2008 Chevy Aveo Lt Car...
My chevy s10 pickup 2.2l sputters amd backfires even blew out muffler i have tried everything i can think of whats wrong
The timing chain and gears are probably worn causing late valve timing. This will cause backfires, and flames out the intake. I'm guessing this is a high mileage engine.
Jan 22, 2014 | Metra Chevy S10 t10 Pickup, Gmc Sonoma...
My 1995 Chevy Tahoe won't shift gears as I'm
Probably the speed sensor on the transmission. It would cause both problems. You should also have a check engine light with a trouble code for the sensor.
Jul 17, 2013 | Cars & Trucks
Can cat. Converter cause 97 chevy cavalier to overheat?
Yes.
The cat could restrict the exhaust flow and cause the engine to run hot.
You would also notice a reduction in power and the check engine light would probably be on.
Jan 12, 2013 | 1997 Chevrolet Cavalier
Reset maintainance light
turn key to run but dont start ,look on dash for reset button and select button (it may be called menu)
use select to get to mileage ,most start at 1000, 2000,2500 ,3000, 3500.
when you get to what you want push reset button, then turn key off ,
with all doors closed start and see if light goes out.
Sep 26, 2012 | 1998 Jeep Grand Cherokee
What causes my 2004 chevy trailblazer to overheat? I got the radiator replaced, due to a crack across the top from overheating?..I got the water pump and thermostat replaced too..Also the motor stalls
Well kinda sounds like it has overheated quite a few times, so unfortuanetly it's heads are probably warped and head gskts are blown causing compression from cylinders to enter cooling system which causes high pressure in cooling system which in turn blows coolant out and end result...your enj. probably needs replacing ! Sorry for the Bad news
Feb 13, 2012 | 2004 Chevrolet TrailBlazer
How can i fix code p0560 on a chevy lumina
    P0560 GM
    System voltage
    - The pcm detects a system voltage out of range for 2 seconds
    Probable Cause[s]
    1. Open or short circuit condition
    2. Poor electrical connection
    3. PCM
    P0560 Generic Definition
    Charging system voltage condition-battery voltage high or low
    - The electrical system voltage level is monitored for intended voltage level
    Probable Cause[s]
    1. Loose or missing drive belt
    2. Alternator defective
    3. Battery defective
    4. Poor electrical connection
    Mar 05, 2011 | Chevrolet Lumina Cars & Trucks
    Vehicle Parts & Accessories Logo
    125 people viewed this question
    Top Vehicle Parts & Accessories Experts
    Thomas Perkins
    Thomas Perkins
    Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
