Question about Vehicle Parts & Accessories
Probable cause code p0219 on my chevy 2000 2500 6.5
  • 641 Answers
What are the probable causes of DTC P0449?
P0449 - OBD-Codes.com
www.obd-codes.com/p0449
Detailed information on diagnosing and repairing a P0449 DTC code which refers ...P0449 Evaporative Emission Control System Vent Valve/Solenoid Circuit ... OBD-IITrouble Code Technical Description ... 2004 Chevrolet Tahoe 4.8L p0449
EVAP Code P0449 - YouTube
? 16:47
https://www.youtube.com/watch?v=AlfOSMmisPg
Mar 13, 2013 - Uploaded by realfixesrealfast
Here is a description and how to diagnose EVAP code P0449. ...Up next. Quick Easy Fix P0449 P0455 Evap Codes on ChevySilverado 2007 ...
Quick Easy Fix P0449 P0455 Evap Codes on Chevy ...
? 7:06
https://www.youtube.com/watch?v=aL5KmV1d26Y
Dec 27, 2013 - Uploaded by wagslick
Quick Easy Fix P0449 P0455 Evap Codes on Chevy Silverado 2007 .... Well clearing the error codes at auto store will not prevent it come ...
Solving a P0449 Engine Code on a 2008 Chevy Impala ...
pressanykey.simplyahobby.com/.../solving-a-p0449-engine-code-on-a-2...
Jan 07, 2016 | 2004 Chevrolet Chevrolet Impala
1998 Chevy Camaro V6 automatic. What are the probable causes for DTC P0422?
Most likely your catalytic converter is worn out. If never changed, that is probably it. The other possibility is the engine is not running at the optimum fuel/air ratio, so a tune-up or engine repair is necessary. Here is a link to that code: http://www.obd-codes.com/p0422
Oct 08, 2015 | Cars & Trucks
Engine runs rough
fix the first two
clear the codes see what is left
P0340 Camshaft Position Sensor Circuit Malfunction
P0171 02 sensor
System Too Lean (Bank 1)
if no better . these are unusual codes
P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
P0304 Cylinder 4 Misfire Detected
P0219 Engine Over Speed Condition
fault code source
Complete List of OBD Codes Generic OBD2 OBDII Manufacturer Car OBD...
Mar 23, 2017 | Cars & Trucks
My 1995 Chevy Tahoe won't shift gears as I'm
Probably the speed sensor on the transmission. It would cause both problems. You should also have a check engine light with a trouble code for the sensor.
Jul 17, 2013 | Cars & Trucks
What is causes of multiple cylinder misfire in chevy lumina 1999
The P0171 co is probably the one that is causing the misfire. It's a lean code meaning the engine is not getting enough fuel. This can cause a condition known as lean misfire and cause the misfire code. A vacuum leak is a possibility as well as a bad MAF sensor or even poor fuel pressure. The p0341 code is a code for the cam sensor. Typically this will not cause any issues other than the code.
Apr 02, 2013 | 1999 Chevrolet Lumina
Reset maintainance light
turn key to run but dont start ,look on dash for reset button and select button (it may be called menu)
use select to get to mileage ,most start at 1000, 2000,2500 ,3000, 3500.
when you get to what you want push reset button, then turn key off ,
with all doors closed start and see if light goes out.
Sep 26, 2012 | 1998 Jeep Grand Cherokee
What is the p1125 code on a chevy avalanch?
EOBD CODE P1125 intake air flap control actuator circuit malfunction
probable cause by the wiring to the intake air flap control actuator ECM Check for any loose wires!
May 02, 2011 | 2004 Chevrolet Silverado 1500 Crew Cab
How can i fix code p0560 on a chevy lumina
    P0560 GM
    System voltage
    - The pcm detects a system voltage out of range for 2 seconds
    Probable Cause[s]
    1. Open or short circuit condition
    2. Poor electrical connection
    3. PCM
    P0560 Generic Definition
    Charging system voltage condition-battery voltage high or low
    - The electrical system voltage level is monitored for intended voltage level
    Probable Cause[s]
    1. Loose or missing drive belt
    2. Alternator defective
    3. Battery defective
    4. Poor electrical connection
    Mar 05, 2011 | Chevrolet Lumina Cars & Trucks
    On a 2006 chevy impala it tells you to tighten the gas cap ,then when you do, we shut the car off. Then check engine light comes on. Where is the sensor located.
    There is no sensor for a loose gas cap. What is happening is that the evaporative emission system is sensing a "Large Leak". Usually code p0455. The computer sees this as the most probable cause is a loose gas cap depending on several factors it looks at. You would need to clear the code(s) and see if that was the problem. If the light comes back on, then you have a problem in the system that will not let it seal. Possible solenoid problem, leaking hose / line, etc.
    Mar 28, 2009 | 2006 Chevrolet Impala
    Vehicle Parts & Accessories Logo
    134 people viewed this question
    Top Vehicle Parts & Accessories Experts
    Thomas Perkins
    Thomas Perkins
    Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
