Question about Lanzar Car Audio & Video
I have a lanzar vct2110 1000 watt amp and 2 vw12d dual 4 ohm voice coil speakers. what is the best way to wire them to get the most bass?
I am recieving these items in the mail and would like to know the best way to hook them up in my truck to get the most bass out of them
2 Suggested Answers
  • 4 Answers
SOURCE: hooking up a sub woofer
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp
take a look there and it should give you everything you need and show you the different options for the different ohm loads. Remember... don't go below 4 ohms on those. Above is ok, below is not.
Posted on Jan 10, 2008
How do you wire a AW1000V to 1 amplifier?
The easiest way to wire this would be to make sure you have a 2 ohm amp, wire both voice coils in parallel to the amp. This means to connect both + terminals on the speaker to the + speaker output on the amp, then wire both - terminals on the speaker to the - speaker terminal on the amp. With the voice coils in parallel like this it makes it into a 2 ohm load at the amplifier. If you are running for example a 1000 watt amp at 2 ohms into this speaker it would give each voice coil the equivalent of 500 watts of power at 4 ohms. The other way would be to run the voice coils in series (voice coil 1 - terminal to - speaker terminal on the amp, voice coil 1 + terminal to the voice coil 2- terminal, voice coil 2 + terminal to the +speaker terminal on the amp.) The series wiring would give you a 8ohm speaker load to your amp so you would need a 8 ohm amp.
Mar 07, 2011 | AudioBahn AW1000V 10" Dual 4-ohm Voice...
Can I hook up 2 lanzar opti1532 subs 2 a kicker kx 1200.1 or do I need a bigger amp, its a 1ohm stable amp an birth sheet says 1390watts but they told me at 14+ volts it will do 1400rms
Based solely on spec sheet information the Lanzars can handle 1300 watts RMS and the KX1200 is rated at 300x1 @ 4 ohms, 600x1 @ 2 ohms, & 1200x1 @ 1 ohm. Even with a 1 ohm load you will still only be providing 600 watts to each sub. While the kicker will provide more power at 14+ volts, no car creates more than 12-13 volts via its alternator. A car battery only provides 12.6 volts. So you will be loking at 1200 watts from 1 channel as a best case scenario.
Additionally, with your 2 subs, they will need to both be Dual 4 ohm voice coils in order to net a 1 ohm final load. Each voice coil will need to be wired in parallel and then each speaker needs to be wired in parallel.
Dec 23, 2010 | Lanzar OPTI1532D Car Subwoofer
How do wire my 15'' to 1ohm
If each voice coil is rated at 2-ohm, then wire it in "parallel". This will make a 1-ohm total load.
amp pos. out to coil 1 pos. to coil 2 pos.
amp neg. out to coil 1 neg. to coil 2 neg.
If the they are dual 4-ohm, the rating would be 2-ohm in parallel.
Mar 16, 2010 | Lanzar (MAXP154D) 15'' 2000 Watt Dual...
To get the most power what is the best way to connect paraelle or
run them straight and dont use the cross over. One speak on right channel and the other on other channel. Then turn up amp settings 7/8 the way up and control the rest from your dvd/cd player. I recommend some monster cable which is very thick. Ground the amp directly to trunk bolts but make sure to scrape the paint off or the connection will be bad. You can also use a cap which will send battery pulses to amp much quicker.
Nov 19, 2009 | Lanzar VIBE286 Car Audio Amplifier
How do you wire up a dual voice coil lanzar 15 for 4 ohm?
Hello dexterchapma,
The only way to wire a single 4ohm DVC sub to present a 4ohm load is to just connect one voice coil. If you wire the coils in parallel, you get a 2ohm load. If you wire them in series, you get an 8ohm load. But it will work great with just one voice coil. Or if you really want to use both voice coils, and your amp isn't stable at 2ohms, wire the voice coils in series and present an 8ohm load to the amp. It'll work fine, it just won't deliver quite as much power.
Hope this helps.
Jun 27, 2009 | Lanzar (MAXP154D) 15'' 2000 Watt Dual...
2 ohm speakers wont work on a lanzar max pro 4000 watt
The 2 ohm stable rating on the amp is PER channel meaning that you could effectively hook up a 2 ohm speaker or a 2 ohm load to each channel without the amp getting f"d up-butin bridged mode it will only be 4 ohm stable. to achieve a 4 ohm load with your sub the type x wire the coils in series that will get you at 4 ohms to run in bridged mono .But you will get the exact same amount of power if you wire each coil to one channel of the amp as bridged mono sees the sum of your 2 ohm channels combined-Hope that helps.
Jun 08, 2009 | Lanzar VIBE266 Car Audio Amplifier
Wiring a sub with duel voice coil
In short yes. And is very common even has its own term called bridged. Taking two channels and making them one. I would hope that you are running a cap. that's going to put out a lot of power and stress on your battery
Feb 10, 2009 | Lanzar (MAXP154D) 15'' 2000 Watt Dual...
Soundstorm amp
SPECS
  • Black P.P. Cone
  • Specially Treated Foam Edge Suspension
  • 2.5' High Temperature Dual Voice Coil
  • Magnet Weight: 95 OZ
  • 1600 Watts Max Power Handling
  • Impedance: 4 Ohm
  • Chromed Back Plate Cover
  • Rubber Magnet Boot Cover
  • Jan 08, 2009 | Lanzar OPTI1222D Car Subwoofer
    How do i wire 10' kicker cvr
    dual 2 or dual 4
    dual 2 wire vc's in series for a 4 ohm load each. Hook each speaker seperate channels on the amp.
    dual 4 wire vc in series for an 8 ohm load each. Hook both + to the right + on the amp and both - to the left - on the amp. or
    dual 4 wire vc in parallel for a 2 ohm load each and hook each speaker to seperate channels on the amp.
    Dec 18, 2008 | Kicker CVR12 Car Subwoofer
    Hooking up a sub woofer
    Jan 10, 2008 | Dual XINBP-210 Car Subwoofer
    Car Audio & Video Logo
    Top Lanzar Car Audio & Video Experts
    Radames Pagan
    Radames Pagan
    Joe Alexander
    Joe Alexander
    Jose Velazquez
    Jose Velazquez
    Are you a Lanzar Car Audio and Video Expert? Answer questions, earn points and help others
