Question about Pioneer VSX-D458 Receiver
Can I hook up this receiver to a Panasonic Viera tv tc-L32C3
The panasonic tv has a digital audio out and I want to use external speakers connected to receiver. The speakers work with DVD,CD but not with tv
  • Pioneer Master
  • 8,014 Answers
U need to get a digital to analog converter for the tv digital outputs on "tv mode." Connect the analog outputs to the audio input of receiver. I had same hassle with my Viera till I got another receiver that would take direct digital input - no more need for converter.
Posted on May 14, 2014
  • richie46 May 14, 2014
techman
  • 3130 Answers
SOURCE: Need help connecting Receiver to TV, DVD, VCR players
Take the audio outputs on the TV set and connect up to the The video 1 inputs to the receiver, BUT use the audio part of the video 1 input and leave the yellow video input blank. Now turn on the TV set, put the TV set on a channel, turn on the receiver and select the video 1 input and you should have the TV audio coming from the receiver. Good Luck.
Posted on Jul 30, 2007
  • 12 Answers
SOURCE: No DTS sound / RESET
Hi I have a Pioneer VSX D908S which is basically the same amplifier as yours with the difference that the one I have has no THX certification, as a matter of fact the service manual is the same, and mine has the same problem. The prblem is located in the DSP board, if you are able to remove the bonett, you will see on the right side a metal cover, remove it, once you have removed it, look for a IC9374 it is located, -looking this board in front to you- almost at the left upper corner, this IC has the PDK042A on it, with a soldering iron resolder this circuit. This is common problem with this pioneer amplifiers, and this procedure not always works, the final solution is to buy the DSP board but it is expensive. Good luck! Miguel
Posted on Oct 06, 2007
petraman7
  • 1175 Answers
SOURCE: No audio output from Pioneer VSX-D608 Receiver
If it's under warranty..get a new one.
It's an internal breakdown ...tech service only.
Posted on Feb 08, 2009
dunnbiker
  • 8546 Answers
SOURCE: Receiver cannot recognize subwoofer
As I implied earlier, take a clue from the physical style of connectors for both parts of the subwoofer function in the old and new receivers:
RCA connections are for Line Level signal between components only.
The input (bare wire) at the speaker is for AMPLIFIED signal.
You can't just modify one to fit the other and expect magic to happen. Be glad you didn't do it the other way around and modify an amplified (speaker level) outout into a Line Level input. You likely would have smoked that component.
Your subwoofer is a passive speaker, that is, like any other speaker it needs an amplifier. Many subs are self-powered (amp built-in) and they would mate well with the RCA sub output of the receiver.
Get yourself an Active (self-amplified) Subwoofer and run UN-MODIFIED RCA cables to it, according to its instructions, from the Sub Out of the receiver. Or get an amplifier between your receiver and the sub you have.
Posted on Feb 21, 2010
Testimonial: "Thank you for your help to an electronics layman!"
dunnbiker
  • 8546 Answers
SOURCE: I have a Pioneer Audio Multi Channel Receiver
DVD audio straight in from its highest quality audio output. Use the stereo audio output to run straight to the TV for casual watching through TV speakers without the Pioneer involved.
A TV is just a glorified night-light, not a sound source - get its related audio from the Cable Box, ditto the highest quality
Posted on Mar 04, 2010
Need to know if Panasonic TC-L32C3 is a smart TV?
The Panasonic TC-L32C3 is not a smart TV. There is no network connection available (wired or wireless). It does have a slot for an SD card to make it a 32" photo viewer. You can also update the firmware by placing the unzipped file (see the site listed below) on the SD card. You can find the specifications and user guide on the product site: http://shop.panasonic.com/support-only/TC-L32C3.html . The direct link to the manual is ftp://ftp.panasonic.com/television/om/tc-l32c3_mul_om.pdf .
I hope this helps.
Dec 06, 2016 | Panasonic Televison & Video
How to plug my external speakers to my viera tv
This television only outputs digital audio called PCM / Dolby Digital, Fiber Optic so you may need an amplifier that has a digital in port (if the speakers are rca red and white cable plugs then the amplifier needs rca output ports). Then you would need to connect the amplifier to the speakers
. Unless the speakers have a digital in port which I am unsure on ,. The digital out audio port on your tv uses a fibre optic digital audio cable..
page 13 of the user manual shows this digital output port.
http://service.us.panasonic.com/OPERMANPDF/TCL42E50.PDF
Oct 28, 2014 | Panasonic Smart Viera E50 Series Tc-l47e50...
Amplifier terminal sound speaker
http://service.us.panasonic.com/OPERMANPDF/TCP42U2.PDF
On page 12 is the instruction on applying speakers, hdmi, and other inputs to the TV.
Dec 15, 2013 | Panasonic Tc-p42u2 Viera 42" Lcd Tv -...
How to hook sound bar to panasonic viera 42 inch model TC-P42X5
The aftermarket audio/video cannot allow you hook your Tv and Dolbys stereos becauses of incompatibility issues.
Jul 24, 2012 | Panasonic Viera Tc-p42x5 42" Inch Flat...
Whats the best way to install a panasonic viera tc-p50x3 to a yamaha home theater receiver rx-v371 to a panasonic blueray dmpbd75 using dishnet work hddvr set top box
connect your blue ray and your dish net with hdmi cables to the amplifier than monitor out hdmi to tv .in your dvd configuration you must make sure that hdmi audio is activated .ps not to be mean but this is a very low quality dvd because it does not have fiber optique audio output but it can still work, for your dis net it all depends on what type of digital audio output
is available , ill be honest with you this is a good job .
Dec 07, 2011 | Panasonic Viera TH-50PZ80U Plasma TV
Panasonic VIERA TC-L32C3 32-Inch 720p LCD HDTV by Panasonic
Hello, welcome to Fixya!
You didn't state any problem concerning this TV. What precisely is the problem with your Panasonic VIERA TC-L32C3 32-Inch 720p LCD HDT?
I look forward to your reply.
Regards.
Sep 27, 2011 | Panasonic Televison & Video
I just bought a Panasonic TV model TC L37E3 and I do not know how to coneect my external speakers. Please help me as I feel very frustrated by now. Carlos
Carlos, I just bought an LCD tv too. To connect external speakers to mine I had to buy some high end 5 channel pc speakers and connect them through the headphone jack(I know how stupid that sounds considering we spend $1000.00 on a TV and thats my only option for external speakers.I looked at your owners manual and didn't see a headphone jack though so you may have to opt for speakers that plug in with through the usb port. Some new tvs won't support external speakers unless you use complete home theater surround sound system which will connect through the rca cables (red,white)
May 22, 2011 | Panasonic Televison & Video
Auxilliary audio connection
I don't expect a 2 channel amp would have a digital input such as optical. More likely you would be able to pull analog stereo (red and white RCAs) off the Panasonic and run to the JVC.
Dec 29, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
Open Questions:
Pioneer VSX-D458 Receiver Logo
102 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
