Question about Zebra Stripe S600 Thermal Label Printer
Feeds backwards. tried another main board. same thing
    Scholar:
  • 122 Answers
Check your backfeed settings on the device, should be between 0 and +10
Posted on Jun 23, 2009
Will a bad power supply board damage a new main board in an led TV?
You can try that without any repercussions except the cost. You need to remember that the LED board has a feedback from the main board that controls the brightness. It would be a good idea to get a schematic and other things before you try this,
Nov 27, 2017 | Samsung Televison & Video
Tip
ERROR codes Canon 8570
Canon 8570 E000 Fuser problem. Temperature too low. Heat lamp, thermal fuse or thermoswitch, thermistor, triac etc E001 Fuser problem. Temperature too high. Probably triac E005 Fuser web finished E005 Fuser cleaner belt user up E010 Drive E010 Main drive problem E011 Drive problem. Could be main motor, scan motor, cleaning web motor or duplex motor E011 Main motor, scan motor, cleaner belt motor, duplex motor, toner motor, lens motor or driver bd. for any of these E020 Toner sensor problem or lack of toner feed. This occurs if toner feed signal is present for 3 min E020 Toner empty sensor sees no toner added for 3 min probably toner feed problem E050 Duplex problem E050 Duplex problem E203 Scan motor problem E203 Scan motor E210 Lens motor problem E210 Lens home sensor or lens won't leave home E240 DC controller board E240, E241, E242 Control board (main board) E241 DC controller board E242 DC controller board E243 Operation panel board E243 Operation panel E400 DC controller, ADF board or 24V E400 DC controller or document feed board E500 DC controller or sorter board E500 DC controller, sorter board or 24V E510 Finisher; feed motor, pulse sensor, finisher board E510 Finisher E520 Finisher; stack motor, stack tray sensor, finisher board E520 Finisher
on Jan 19, 2010 | Office Equipment & Supplies
Tip
ERROR codes Canon 8070
Canon 8070 E000 Fuser problem. Temperature too low. Heat lamp, thermal fuse or thermoswitch, thermistor, triac etc E001 Fuser problem. Temperature too high. Probably triac E005 Fuser web finished E005 Fuser cleaner belt user up E010 Drive E010 Main drive problem E011 Drive problem. Could be main motor, scan motor, cleaning web motor or duplex motor E011 Main motor, scan motor, cleaner belt motor, duplex motor, toner motor, lens motor or driver bd. for any of these E020 Toner sensor problem or lack of toner feed. This occurs if toner feed signal is present for 3 min E020 Toner empty sensor sees no toner added for 3 min probably toner feed problem E050 Duplex problem E050 Duplex problem E203 Scan motor problem E203 Scan motor E210 Lens motor problem E210 Lens home sensor or lens won't leave home E240 DC controller board E240, E241, E242 Control board (main board) E241 DC controller board E242 DC controller board E243 Operation panel board E243 Operation panel E400 DC controller, ADF board or 24V E400 DC controller or document feed board E500 DC controller or sorter board E500 DC controller, sorter board or 24V E510 Finisher; feed motor, pulse sensor, finisher board E510 Finisher E520 Finisher; stack motor, stack tray sensor, finisher board E520 Finisher
New to me (used) Ambition 1.0 skipping stitches when in free motion with feed dogs down and sewing in a backwards direction (stitches fine when going forward or even sideways).
You have to be more slow and even speed. The main thing is to not pull on the thread. The top and bottom thread have to work together in order to sew. Try to practice in a forward motion and then backwards. Make sure that you have the right pressure foot being used.
Aug 02, 2016 | Sewing Machines
ESP Office 2150 all-in-one
Shows paper jam. no paper in machine
Apr 11, 2016 | Kodak Office Equipment & Supplies
Feed dogs pushing fabric in reverse
Check that the quick reverse button is not jammed-in, first. If not, check a pattern that uses forward and backward feed, such as the honeycomb stitch and check if varying the stitch length makes any difference - if its still only feeding in a reverse direction, you're probably going to have to get it checked-out by a Bernina service agent, because this could be one of a number of problems, ranging from the simplest - the plug carrying the wiring to the stitch length stepper motor might have dropped-off the main 'S'-print control board - to the worst - the main control board might be faulty. The stepper motor could also be faulty or, indeed, there might be a jammed stitch-length mechanism in the free-arm, if it hasn't been serviced for a while. Good Luck
Nov 07, 2011 | Bernina Virtuosa 150
Will only Sew in reverse.
Could be several things -- motor hooked up backwards, reverse is stuck, etc. Is there a Reverse on the machine? If so, what happens when you activate the reverse. If it then sews forward I would say someone hooked the motor backwards. If there is no change, it would be a problem with the feeding motor or the circuit board. Suggest taking to a reputable service center for analysis. Good luck.
Feb 01, 2010 | Husqvarna Viking 1
Ford 1990 capri headlights won't go up or down any suggestions
you and your relays ???their isnt a relay so get the test light out and work your way backwards ,test for a feed to the motor unit first ,then go backwards ,the feed comes from the dip /main side of the light switch
Mar 08, 2009 | 1990 Ford Escort
Troubleshooting main board.
Three things to look for in service with LCD monitors,
1 bad capacitors
2 Bad transistors for the back light feeds
3 bad ic pulse chips for the Non function circuit
you will not find schematics unless you peruse the patent office records, reverse engineer the circuits and you will have a schematic
when the main chip fails on the vga board its time to buy a new vga video board,
sounds like your board may be suffering a bad IC telling the main chip the power is OK
let me know how it goes.
Dec 29, 2008 | HP w19 19" LCD Monitor
Zebra Stripe S600 Thermal Label Printer Logo
187 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Marvin
Marvin
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
