Question about Datacard SP35 Plus Printer
Wont print bleed - Datacard SP35 Plus Printer
7500 dt to print full-bleed
This printer is not capable of printing full bleed. You will have to print on oversized paper and trim it to get dull bleed.
Jan 10, 2014 | Xerox Phaser 7750 Laser Printer
How can I print full bleed on konica Minolta C451
Hi, unfortunatley you cannot print full bleed on any printer that uses toner. The way to do it is to print them on A4 Wide or A3 Wide paper and them trim them like you mentioned.
Sep 13, 2012 | Konica Minolta Bizhub C451...
Brakes wont bleed
bleed it with key on
Jun 28, 2012 | 2005 Hyundai Tucson
Words bleed when printing on vellum
my suggestion is, try printing in a laserjet. because in inkjet the ink will bleed or spread out because the ink is not yet dry. while if you use the laserjet, no bleeding of toners. because in laserjet they use powder.
Jul 02, 2010 | HP Photosmart D7360 All-In-One InkJet...
Printer sat a year without ink cartidges, now wont print
Leaving inkjet printers alone for a long time generally results in the print heads getting clogged. Try cleaning them by following the steps on this page. If this does not work, you may need to replace them.
Good luck! :)
Feb 19, 2010 | HP Officejet 7130 All-In-One InkJet...
I can't print full bleed from CS3 to a Phaser 7750DN
You didn't mention paper size, so my apologies if you are using a sheet that will accommodate bleeds and just didn't mention it. This is the simple answer.
If you printing on 8.5 x 11 paper, you can't get a full bleed. You'll need to print on a larger paper size, like tabloid, and trim your 8.5 x 11 size out of that. There are no printers, even commercial offset printers, that can bleed an 8.5 x 11 design on an 8.5 x 11 sheet. There must be trim in order to get the bleed. it 'bleeds' off the edges of the design.
Nov 11, 2008 | Xerox Phaser 7750DN Laser Printer
Full bleed printing
feed the stock thru the Multi prupose tray. Set a custom size in the PDD to 5 mm larger diamension for W and H. this fools the machine to thing larger stock is being printed. feed your original stock. do not scale to fit....and presto, you can print to full bleed...
Sep 10, 2008 | Xante Ilumina Digital Color Press Printer
Printing bleeds
This machine, like almost every other laser based device on the market does not print bleeds.
The spec for the image masking at the edge is probably in the 3 to 4 mm range. When the sales person tells you that you can do "full bleed" what they are saying (even if they do not realize it) is that you can print an image larger than 11x17 onto a 12x18 sheet of paper and then trim the page back to 11x17 so that the final product bleeds over the edge.
Mar 03, 2008 | Canon imageRUNNER C3200 Color Printer
Full bleed
sure, first you need to use 12x18 paper in the bypass tray. The using your application select to print 11x17. you then cut the paper to 11x17, thats the only way to print full bleed on this system.
http://www.websitetoolbox.com/mb/copierquestions
Jan 07, 2008 | Ricoh Aficio CL7000 Laser Printer
Pictures wont print properly
What quality paper are you using ? , the "wrong" paper will cause bleeding of the colours.
Dec 11, 2007 | Canon PIXMA iP1500 InkJet Photo Printer
Datacard SP35 Plus Printer Logo
21 people viewed this question
Top Datacard Office Equipment & Supplies Experts
Safe-Card ID...
jason
Don  Farrell
Don Farrell
Are you a Datacard Office Equipment and Supply Expert? Answer questions, earn points and help others
