Question about Whirlpool RBS275PD Electric Single Oven
Electric oven will only heat 100 degrees - Whirlpool RBS275PD Electric Single Oven
2 Suggested Answers
hotuna
  • 288 Answers
SOURCE: Oven Temp
After it drops temperature, how do you get it back to the desired degrees? It sounds like the thermostat isn't keeping up.
Posted on Nov 15, 2007
How do you reset the frigidaire wall oven?
Good Afternoon Friend,
I understand you are trying to reset your Frigidaire wall oven, model# FEB27S5A, due to it not heating above 100 degrees. I suggest resetting at your homes circuit breaker for 3-5 minutes. When you restore power, you will first need to set the clock. After setting the clock, preheat your oven. If you are still noticing that the temperatures are still not going above 100 degrees, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine what is causing it to not reach the desired temperatures. Hope this is helpful.
-Best regards-
WP
May 11, 2014 | Frigidaire FEB27S5A Electric Single Oven
Oven won't heat above 100 degrees
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Apr 23, 2011 | Electrolux Ovens
Maytag gemini wiont go over 100 degrees
heatman101
Apr 03, 2011 | Ovens
Turn the oven on to preheat, it beeps says that it is preheated but heats at about 100 degrees less than what I have set it for. This just started.
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
heatman101
Jan 20, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
Broiler work but oven wont go passed 100 degrees
heatman101
Jan 19, 2011 | GE Ovens
Oven wount go above 100 degrees or get hot
heatman101
Jan 11, 2011 | Ovens
Both upper and lower oven elements won't heat beyond warm (100 degrees) Jenn-Air Model# SVD48600P
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 15, 2010 | Ovens
Fan works, but Oven stays at 100 degrees. Tried
I had the same problem in December - I had to replace the circuit breaker and that solved the problem. My oven wouldn't go above 100 degrees in convection, bake and roast modes. Each of these modes are on a separate circuit so when one is bad, the others should work.
Jan 25, 2010 | Thermador C301U Electric Single Oven
I am attempting to pre-heat oven to 400 degrees but oven heat will not raise above 100 degrees
Hi, Upon reading your post I immediately thought of a bad ignitor for the oven, but I am not sure whether you have a gas oven or a conventional electric range. So...If it is gas, I'd suggest replacing the ignitor for the hot surface ignition. If it's electric the bake element may be at fault although most range's use the broil in the preheat, so it should still climb up to 400, it would just take a really long time. Maybe you can clarify if it's electric or gas and I can try to move you forward from there. Macmarkus :)
Dec 09, 2009 | GE Ovens
Oven will not heat past 100 degrees
More of a clarification request:
Is the oven remaining on all the time(oven light stays on)and the temp not going above 100 ,or is it going to 100 then switching off?
Aug 10, 2009 | Belling XOU270 / XOU271 Electric Single...
Whirlpool RBS275PD Electric Single Oven Logo
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
