Question about A.O. Smith SQ1102 Pool Pump Motor
I need a thermal overload cet54aeh? - A.O. Smith SQ1102 Pool Pump Motor
I need technical detail as well as dimensional detail of CET54AEH Thermal OVERLOad of KLIXION. if any 2d or 3d dimesion drawing is available then it is much better for me for Analysis.
Posted on May 26, 2014
2 Suggested Answers
SOURCE: I need a thermal overload protector #CET52ABN or ...
we have them 888-794-2365
Posted on Mar 04, 2011
Electric dryer won't heat
Thermal overload cutout tripped or is defective and needs replaced. Look for a red reset button near the heater element on the thermal overload. If no reset button, replace the thermal overload cutout. The timer itself could be defective, which will prevent power going to the heater element.
Sep 14, 2015 | Roper Dryers
3rlsq8033 wont start
The thermal overload (fuse) is found on the motor for this washer. It is a small black box that has 2 wires going to it. Unplug the washer before working on it. If you have a multimeter you can remove the wires going to the thermal overload and check for continuity between the two terminals of the thermal. If your meter shows an open circuit you will need to change the motor.
Sep 27, 2014 | Whirlpool Dryers
Thermal overload protector
Use the first part of the model number to fid who the manufacture of the saw/ motor is. Example: 110.123456- 110 is Whilpool. Then cal the manufacture direct. Also sometimes Grainger has direct replacements.
Jan 25, 2014 | Craftsman Sears 10" Table Saw Motor 62505
Reset thermal
I think the question is thermal overload on a three phase motor. If a motor has a thermal overload that must be manually reset then there should be a button on the motor, often red. While the motor is de-energized (power plug removed) , push the reset button by hand.
Jan 04, 2014 | Dryers
Motor shuts off after 30 seconds looks like it is overheating
More than likely the motor is overheating or at least the thermal overload thinks it is. The thermal overload could be bad but if the motor has burnt windings then it probably is pulling too many amps which will cause the overload. Sounds like you need a service call or take the motor to a motor shop.
Sep 13, 2009 | Emerson Threaded 1.5hp Fullrate 115/230v
Oven not working
I had the same problem. At the back of the stove is a plastic cover with thermal overload written on it.
Switch off your power.Remove the cover, pull out the two luggs and connect the two luggs straight to each other. Make sure the oven knobbs are in the off position. turn on the power. If your oven clock etc. comes on the thermal overload is faulty and needs to be replaced. It is fixed to the stove by a screw from the inside of the oven, so open the door and remove screw to remove thermal overload at the back of oven. Take sample to electrical shop and replace. DO NOT USE OVEN WITHOUT THERMAL OVERLOAD.
Dec 27, 2008 | Ovens
Motor will not start
I had the same problem and the solution was to manually press the thermal overload button. The button is located under the tool box next the motor head. I do not believe I tripped the thermal overload during use, but I suppose anything is possible. I’ve been using the compressor in sub 40 deg F. temperatures. I found the following in the Owner’s Manual, but had to look at the part manual to locate the switch.
MOTOR THERMAL OVERLOAD
PROTECTOR: The electric motor
has a manual thermal overload
protector. If the motor overheats
for any reason, the thermal
overload protector will shut off
the motor. Turn pressure switch
to the “off” position and wait for
unit to cool before pushing the
reset button and restarting the
compressor.
Good Luck!
Dec 14, 2008 | Makita MAC5200 Electric Powered Air...
My whirlpool gold microwave model GH4184XSB-1 stopped working after a paper plate caught fire inside. I replaced the wiring going to the thermal overload and the thermal overload but it still doesn't work...
Your thermal overload (thermostat) is bad if the oven powers up when you jump across it.
Are you sure the thermostat is the correct part for your model?
It should be part # 8183703. You can get that here.
Oct 13, 2008 | Whirlpool Microwave Ovens
Wont heat up
I know that Karchers steam cleaners have had issues with the thermal overload. I have repaired Karcher machines that got turned on with no to little water in the tank and it would heat up really fast and trip the thermal overload. The thermal overload is to reset it self when it cools down but the problem has been the thermal overloads get stuck and dont reset. When they stick, they will give the same signs you have said. In those cases the thermal overload has needed replaced. The thermal overload did its job to trip, but it fails when reseting. I understand you don't want to throw more money into it, but that is the only thing you can do. You can get the part and do it your self, but they are tricky machines to get into and you dont want to break something trying to get in. Hope this helped.
Mar 25, 2008 | Karcher DE4002 Steam Vacuum
A.O. Smith SQ1102 Pool Pump Motor Logo
124 people viewed this question
Top A.O. Smith Plumbing Experts
Donni Steen
Tom Chichester
Are you an A.O. Smith Plumbing Expert? Answer questions, earn points and help others
