Question about Apple LaserWriter 8500 Printer
Stop paper test apple laserwriter 8500
Paper test
4 Suggested Answers
SOURCE: Apple LaserWriter 8500 not turning on
There is a glass-tube fuse inside, near the power switch that blew on mine a couple of years ago. Being the curious type, I popped off the side cover to see if there was any obvious reason, loose connectors, burned resistors, etc., and found the blown fuse. Can't remember where I got the replacement, but think it was Radio Shack. It's a common type.
Posted on Jan 04, 2008
  • 50 Answers
SOURCE: Laserwriter 8500 jammed printing large
Look again and make sure NOTHING was left in the printer. Also make sure all access panels are completely closed.
Posted on Jul 18, 2011
bronk50
  • 27725 Answers
SOURCE: Apple Laserwriter 8500 paper light out, when there
make sure the usb lead connection is secure
click start control panel administrative tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow? ! question exclamation mark or a red X
this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options also you can troubleshoot the device
hope this helps you
Posted on Oct 06, 2011
Apple Laserwriter 8500 paper light out, when there is paper in the cassette. Not blinking. Solid yellow.
hope this helps you
Oct 06, 2011 | Apple LaserWriter 8500 Printer
12/640 PS wont feed from tray
I found the owners manual for your model, and it has detailed explanations of how to turn off the printing of the Startup page: This is where the owners manual is available online in .pdf format, at this URL: http://download.info.apple.com/Apple_Support_Area/Manuals/printers/0340211ALW12640UM.PDF Startup Page Info From your Owners Manual: (Yes, I've been reading the Manual for your printer. I have no life. :P ) From page 25 of the manual: "The printer takes a minute or two to warm up, and then it automatically prints a startup page. It prints the startup page every time you restart unless you turn the startup page off using either the Apple Printer Utility for the Mac OS or the Apple LaserWriter Utility for Windows. See Appendix A for details on these utilities." From page 249 of the manual: "Appendix A - Setting the Printer Default Settings" "Though the printer itself has no control panel, you can configure it by using programs on computers connected to the printer: - On Mac OS?based computers, use the Apple Printer Utility and the desktop printer?s setup function." So the answer is YES, you CAN setup the printer to not print the test page, but you have to use the setup utility on your computer to do so. Opening the Apple Printer Utility (From page 251) "The Apple Printer Utility has two windows: the Printer Selector window, which is similar to the Chooser, and the printer features window, which you use to view or change the printer?s settings." 1. Double-click the Apple Printer Utility. - The Installer puts the Apple Printer Utility in the Apple LaserWriter Software folder. You can move it wherever you like. 2. In the Printer Selector window, select and open the printer you want. - If the network has zones, click the zone where the printer is located. - Click the name of the printer you want. 3. Click Open Printer. - The printer feature window appears with the Printer Information category displayed. 4. To view or change settings under a category, click the arrow beside the category name to open the category and display its information and options. - Additional options may appear that you can also open and work with. When you are finished changing options in a particular category, you can click the arrow again to collapse the options. (NOTE: The option you want is "Startup Page".) 5. After viewing the information and making changes, click the Send button to send your changes to the printer. 6. Click the Close box to close the window. Turning the startup page on or off (From page 257) "The LaserWriter 12/640 PS normally prints a sample page when you turn the printer on. This page shows the printer?s name, the total number of pages printed, the amount of memory, installed options, and communication settings. You can turn this feature off if you wish. 1. Open the Startup Page category. - The Startup Page panel appears. 2. Click the checkbox to turn the startup page on or off. - When an X appears in the checkbox, the printer is set to print the startup page. 3. Click Send to send the startup page setting to the printer. That should remove the default printing of your startup page. HOWEVER, there is another possibility to affect a repair to your problem... As the paper-feed rollers get older, the rubber on the rollers gets slick and won't grip the paper anymore. Try buffing the rubber rollers with some fine sandpaper and see if that allows the machine to pick the paper up once again. If this is your problem, then you might make the lower-feed paper tray work again. Hope this helps, but let us know if you need more information to solve this problem. ;)
Aug 07, 2007 | Apple LaserWriter 12/640 PS Plus Printer
Laserwriter 8500 prints splotches all over the page.
Toner bubbles are characterized by large blotches of color toner on
printed pages caused by color toner leaking from cartridges directly
onto the transfer drum.
Solve the problem of toner bubbles by checking the manufacturing
codes on the toner cartridges and replacing cartridges as needed. Compatible carts are notoroius for this so don't use them.
Heat-stamped on the toner cartridge, opposite the label-end of the
cartridge, is a manufacturing code. If a portion of the code does not
match the list below, replace the toner cartridge.
Use toner cartridges that contain any of the following manufacturing
codes:
 9I
 9J
 9K
 9L
 and any cartridge that begins with the numbers 0 through 6 in place of
the 9
Jun 08, 2009 | Apple LaserWriter 8500 Printer
Apple 16/600 Laserwriter reports out of paper but its not
It's the sensor from tray fault. Try to blow with air spray to sensor, maybe is dirt with paper dust and need clean.
All the best and Happy New Year !
Dec 29, 2017 | Apple LaserWriter 12/640 PS Plus Printer
Laserwriter 8500 "dirty" print outs
onto the transfer drum. Solve the problem of toner bubbles by checking the manufacturing codes on the toner cartridges and replacing cartridges as needed. Compatible carts are notorious for this so don't use them.
codes:
 9I
 9J
 9K
 9L
the 9
Oct 09, 2008 | Apple LaserWriter 8500 Printer
Turns on and sends out test page
This means I believe that the thermistor, or possibly the fuser, has failed. Our 8500 is in exactly this state at present. It occasionally works for a few pages after it is turned on, then it stops when the two rear LEDs turn on.
We had a new thermistor fitted but this has not resolved the issue. Not currently clear whether the new thermistor was incorrectly fitted, the base had to be filed to fit and it may not be close enough to the hot roller, or whether we have a more fundimental problem.
Any other views on this?
Thanks
Apr 09, 2008 | Apple LaserWriter 8500 Printer
A slight burning smell from the fuser region ...
Although a faulty thermistor could be to blame for the fuser running above target temperature, the usual explanation for a slight burning smell is a bit of paper debris stuck inside the fuser, slowly scorching away to nothing.
A.
Mar 31, 2008 | Apple LaserWriter 8500 Printer
Dec 12, 2007 | Apple LaserWriter 8500 Printer
Won't print tabloid paper
I had this problem a couple of years back and took the printer to a service company. They replaced the paper pickup rollers and I have not had the problem since. Other problems, yes, but not that problem.
Aug 16, 2007 | Apple LaserWriter 8500 Printer
Apple LaserWriter 8500 Printer Logo
15 people viewed this question
Top Apple Office Equipment & Supplies Experts
jasbo
jasbo
Don  Farrell
Don Farrell
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you an Apple Office Equipment and Supply Expert? Answer questions, earn points and help others
