Question about Refrigerators
How do you cycle an icemaker in a Bosch B36IB70NSP refrigerator?
Is it OK for ice thickener sensor touch water on ice maker
Yes, it has to touch the water. As the ice builds up the thickness sensor moves up and turns of the refrigeration and turns the heater on.
  • How Icemakers Work ' HowStuffWorks home.howstuffworks.com/icemaker.htm How Icemakers Work. ... we'll look at the cycle an icemaker goes through to make ice. ... Get the best of HowStuffWorks by email. Keep up to date on:
  • How Does The Ice Maker On A Refrigerator Work ... - YouTube www.youtube.com/watch?v=x4YDWUK0jv8
    • BY REPAIRCLINIC.COM
    • 4 MIN
    • 347K VIEWS
    2012-05-15 · Video embedded · This video provides information on how a refrigerator icemaker works and offers troubleshooting tips ... How Does a Refrigerator Water and Ice Dispenser Work?
  • How Ice makers Work - ApplianceAssistant.com applianceassistant.com/.../Ice-Makers/How-Ice-Makers-Work.php How Ice Makers Work! Learn How Ice Makers Work, ... How Ice makers Work. The Ice Maker Cycle ' Ice Maker Components ' Cube Size Replacement Ice Makers . They Don't Make
  • How Does an Ice Maker Work? - Reviewed.com Refrigerators refrigerators.reviewed.com/features/how-does-an-ice-maker-work Here's how your ice maker works. BACK TO . Best Right Now; How To s; Award Winners; How We Test; ... How Does an Ice Maker Work? It's more complicated than ...
  • Refrigerator Icemaker Repair How It Works
    May 12, 2016 | Refrigerators
    I have tested the valve and it's is opening and closing but the icemaker keeps putting power on the valve everytime it cycles and never stops. The valve is shutting off water each time. What in the...
    Yes, every time the icemaker cycles, it will switch in power to the icemaker water valve. the icemaker is pretty much a standalone device. All it needs is power and water supply, and valve. If it has both, and is not working properly, then the icemaker is bad.
    Oct 01, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
    No ice
    Remove the back of the unit, remove the water valve from under the unit without damaging the water line. trade the wires that connect the valves. depress the water selector at the dispencer. if you hear water flowing, replace the dual water valve. You have to achive 15 degrees to cycle the icemaker but in most cases you can lift the bar on the icemaker for 3 minutes and then lower it to cycle the icemaker. If you remove the front white cover from the icemaker , then force clockwise movement on the large cam, the icemaker will then cycle. It requires only a very small amount of force to start the movement. If it doesnt cycle, replace the icemaker. If both the icemaker cycles and the water valve operates,you will need to call a qualified tech to correct the temperature problem if 15 degrees is not achived.
    Jul 21, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
    Icemaker rakes not moving, though it is in the cycle and making a lound humm, grinding type sound (similar to when it does its normal ice rake cycle.
    Normally, icemakers make very little noise. If it is in the middle of a harvest cycle and will not complete the cycle, remove the icemaker and look to see if an object some how fell into the ice cube mold area, preventing the rake from turning. If there is no obstuction, you will have to buy a replacement icemaker, as there are no replacement parts available. NOTE: Do not leave the icemaker in your freezer in the middle of a cycle for extended periods, as the mold heater would be "on" and adding heat to your freezer section the entire time, causing your refrigerator to work harder than normal, and costing more to run.
    Apr 10, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
    No power going to water solinoid that services ice maker
    you will only get power there briefly when the icemaker nears the end of its cycle.you can initiate the cycle on this icemaker by rotating the fingers in the mold manualy you should get power at solenoid for 3-5 secnds as the icemaker nears the end of cycle if not the swich is part of the icemaker and should be serviced by qualified technician
    Jan 17, 2010 | Frigidaire FRS23R4A Side by Side...
    Noisy refrigeration without a icemaker.
    Lift the arm up on the icemaker to shut it off some models have a switch on the side of the ice maker you can turn off as well a green indcator light
    May 10, 2008 | Refrigerators
    Ice machine not making ice
    Hi, everak11,
    Three possible solutions for you.
    1: No water coming in from inlet valve. Check voltage on inlet if you have voltage and no water then replace valve.
    2:Icemaker not cycleing. Lift the arm on the icemaker to shut it off and leave it for about an hour. Come back in and turn the icemake back on by lowering the arm. If the icemaker does not begin a new cycle and the arm start rising then the problem is most likely an icemaker. Replace Icemaker
    3:Refrigerator not cold enough. If the freezer is not getting cold enough the icemaker will not cycle. Check the temperature in the freezer and make sure it is getting down to 0 degrees. If not then you may have another problem with your refrigerator. I hope this helps you, Let me know if you have any other questions or symptoms. Mike
    May 08, 2008 | Refrigerators
    I have a Whirlpool side by side refrigerator with a new ice maker. The ice maker works fine but will not drop the ice. If I cycle the arm off/on (up/down) then it dumps the ice a few minutes later. ...
    Humm thats a good one, but I will try to help you out. First off you say the icemaker is new, so does that mean you bought the icemaker and installed it on the refrigerator. Or is the refrigerator new and it has an icemaker. If you installed the icemaker new on an older refrigerator you can have a few problems. Most likely the freezer is not getting cold enough for the icemaker to cycle on its own. Especially if you are peaking in every few minutes like I would be doing. The icemaker will start a new cycle when the temperatur hits 0 degrees. If the freezer is only getting to 5 degrees the icemaker will not cycle. In that case the problem would be with the refrigerator not the icemaker. If the freezer is getting to 0 degrees then you may want to take that icemaker back and get a replacement. Good luck and I hope I helped. mca0824@aol.com
    May 02, 2008 | Refrigerators
    Kenmore Coldspot w/Ice Maker Not Making Ice
    hi LOP7,
    In most cases you can easily solve this problem.
    step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
    Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
    If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
    If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
    Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck mca0824@aol.com
    Apr 30, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
    Refrigerators Logo
    24 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
