Question about Filter Heating & Cooling
Which way should filter face? pleats or flat side to front
    Problem Solver:
  • 11 Answers
Almost all filters will have an arrow printed on a side to show which direction the air flow should be going. Examine all 4 sides of the filter and match slide it into the unit accordingly.
Posted on May 15, 2014
Simplicity Pattern 4597-apron A has missing or vague instructions to make pleats & sew pocket to front of bib apron. Can anyone explain how to make the pleats and secure to the bib apron front.
Search the internet for "pleat" instruction:
Google
Once the pleats are formed on the one piece, the two pieces are stitched together with a regular seam (as though there were no pleats in the second piece).
Apr 08, 2016 | Simplicity Sewing Machines
I am from Goa and have never worn a saree. From where can I learn to drape a saree?
My Personal Favorite is Panash India Indian Wedding Sarees Bridal lehengas Salwar Kameez They have the best designs at great price too, Support is also good.
Mar 11, 2015 | Clothing
Troubleshooting hoover
Hi! Here are some basic trouble shooting steps for the Presto 2-in-1.
1. Remove the dirt cup. Push the release catch on the hand vac and pull the dust container off the motor unit
2. Remove dust container from filter assembly and cyclone separator.
3. Hold the dust container over trash can and tap out debris.
4. Check cyclone separator for additional debris, empty into trash can
5.Check the rinsable filter. If rinsing is needed, remove rinsable filter, rinse with pleated side facing up. Allow filter to completely dry for at least 24 hours.
6. Remove any hair and debris from the brush roll.
7. Remove the floor nozzle from the cleaner by pressing the nozzle release button on the back of the floor nozzle and pulling from cleaner.
8. Check and clear nozzle of any obstructions.
Hope this helps!
Aug 06, 2014 | Hoover Vacuums
In the pictures of the these pants have pleats down the front of the pant leg, are these pleats sewn in or are they just an ironed crease?
The pleat is not sewn in. When I first bought these pants they came with the crease down the leg, but after washing them and steaming the pleat wore out.
Feb 16, 2014 | George Womens Classic Career Pant
How to properly change air-filter which way does
Air filter elements face the dirty air side of the system. That is the paper pleating faces away from the hose /pipe leading to the manifold
Oct 06, 2013 | 1997 Ford F150 Regular Cab
How much do air conditioner filters usually cost?
I will give you my advice on air filters. The filters you should use in your ac system is the old plain filters sold by national companies like Ace Hardware and the like. Most of you big box stores and major stores try to sell the new pleated filters. They actually make more money on the sale of these pleated filters than the old plain flat filters. The new pleated filters block at least 35% of the air in your system and typically result in your system not passing enough air volume to supply the required amount of air flow. The pleated filter cause the rooms at the end of the duct run to not get enough air and will be to hot in the summer and to cold in the winter.
So to answer your question, pleated filters in my area are about 3 to 5 times more expensive than the correct filter flat type filter.
PS Some times these flat filters I am talking about are sometimes referred to as 30 throw away filters. I just changed a 30 day throw away filter after having it in place for 16 months. Every month I take the filter out and vacuum off the fuzz and hair and put it back in the holder. As long as the filter media is clean and the sides are still intact the filter will continue to work for a long time.
SoSHope this helps.
Feb 07, 2013 | Filter Heating & Cooling
How do i wash an air filter
1. APPLY CLEANER
Liberally spray K&N Air Filter Cleaner onto both sides of filter and allow to soak for 10 minutes to loosen the dirt. Do not allow cleaner to dry on air filter.
2. RINSE FILTERRinse off air filter with cool low-pressure water applied to the clean side out in order to flush the dirt out of the filter. Continue to rinse the filter until all traces of cleaner are gone. It may be necessary to repeat steps 1 and 2.
3. DRY FILTERAfter rinsing, gently shake off excess water and only allow filter to dry naturally. Do not oil until the filter is completely dry.
4. OIL FILTER
A.) Squeeze Oil (99-5050)
Apply K&N Air Filter Oil evenly along the crown of each pleat. Allow oil to wick for approximately 20 minutes. Touch up any light areas on either side of filter until there is a uniform red color at all areas.
B.) Aerosol Oil (99-5000)
Spray K&N Air Filter Oil evenly along the crown of each pleat holding nozzle about 3" away. Allow oil to wick for approximately 20 minutes. Touch up any light areas on either side of the filter until there is a uniform red color at all areas.
Thanks
Apr 01, 2012 | Garden
Can not get filters
While you are looking for a new filter, you could do this(as written in the instruction manual):
1. Hold the HEPA filter
by the edges and vigorously
"TapClean" the HEPA Filter
dirty side down on a hard,
flat surface until no more
dust is observed falling out
from between the pleats of
the filter.
2.
We recommend washing the HEPA filter
once a month or when suction
appears to be reduced. Let the HEPA
filter air dry completely for 24 hours.
3. Rinse the non-woven pre-filter and let
it air dry completely for 24 hours.
4. Insert the non-woven pre-filter.
5. Reinstall the HEPA filter in the
vacuum.
Have a good day.
GB
Nov 06, 2010 | Euro-Pro EP602 Bagless Stick Cyclonic...
Hi there, I pulled my air con filters out to clean them and have forgotton which way they go back. On 1 side under the mesh is a foam filter and on the other side there is a funny sort of pleated thing. I...
Hi Carlee,
The first thing you need to do is figure out which way the air flows, if the filter goes in a return grille turn the pleated side away from you if the filter is in the indoor unit however the pleated side of the filter should be facing toward the top of the unit.
Nov 06, 2010 | Heating & Cooling
I have a RUUD Furnace / AC and need pleated 21 x 28 x 4 filters with #10 efficency rating.
http://www.thefilterstore.com/
WITH THIS LINK YOU CAN ORDER CUSTOM MADE PLEATED FILTERS FOR YOUR FURNACE
HOPE THIS WAS HELPFUL
Mar 31, 2010 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
41 people viewed this question
Top Filter Heating & Cooling Experts
Coss
MightyMikeJr
Are you a Filter Heating and Cooling Expert? Answer questions, earn points and help others
