Question about Saeco Magic Comfort Plus Espresso Machine
Maker will not work instead the message says to empty grounds container
2 Suggested Answers
dutchman05
  • 487 Answers
SOURCE: saeco italia
ok turn the machine on and wait till warmed up. Open door while machine is on and remove the dreg drawer. This you always need to do when the machine is on otherwise it will not reset.
flashing means dreg drawer steady means coffee beans
Posted on Apr 16, 2008
Coffee grounds in bottom, using Bunn coffee filters
only time I have had this problem with BUNN filters is when I got 2 instead of just one .then I refiltered it thru a clean empty filter into another container .
Apr 09, 2016 | Bunn 10 Cup Home Coffee Brewer
We get the message Unit Cal.Fied - what to do?
You need to run the Decalcyfying program. Push and hold the button with the symbol that looks like a tube with small dots inside. You will get the message empty tray and empty grounds. Do so, and put everything back. The message Solvent or Agent in tank will be displayed. Meassure up 700ml water in a container, put 3 Descaling tablets in the water and let it be completly desolved before you pour this into the empty watertank. It`s very important that you don`t use more liquid, this will make the program run forever. When the solvent is in the tank, push the buttoun again, and the program starts. After a while (20 minutes or so) you will be asked to empty tray/grounds again and to fill the watertank. At this point you can fill up the watertank, this will not affect the running of the program. In the end, you must empty tray/grounds again, and after this the machine is heating up and ready to use. Good luck!
Aug 17, 2009 | Jura Capresso Impressa X90 Espresso...
'Grinder Blocked' error message
The grounds chamber is clogged, you will have to open the machine and clean out the chamber on the side of the grinder, it is the one covered with the little door, you might be able to get to it if you dremove the brew unit.
May 03, 2009 | Gaggia Titanium Espresso Machine
Delonghi EAM 3400 keeps saying "Empty Grounds Container"
I think the microswitch that sensors the front door is not activated. Try to find it and "give it a massage" The machine resets the counter for the grounds container every time the door switch is activated.
Rgds
Michael
Dec 19, 2008 | DeLonghi Esclusivo Magnifica ESAM3300...
I can't get the coffee grounds plastic dispenser back into the
remove the used grounds container and place a folded piece of paper where the grounds container touches the micro switch ( that is in a slot in the left side where the container enters approx 8cm inside) and then restart the machine and the grounds container will now be able to enter, remember to remove the folded paper before inserting the container
Nov 18, 2008 | Saeco Vienna Deluxe
Descaling?
With the selector buttons find Descaling and press OK
This process takes about 35 minutes
1. Empty the water tank, drip tray and grounds container.
2. Insert tray and grounds container, refill tank with with 0.5 Lt. of water and add descaling agent (not the pill or powder used for clean cycle) to tank. Make sure its completely dissolved.
3. Place a container or cup under the steam wand large enough to hold 0.5 lt.
Display says Descaling and press OK
4. Press the water button
Display says Descaling in Progress
after the descaling agent is exhausted
Display says Empty Drip Tray and Spent Grounds
5 Also remove rinse and refill the water tank to Max line
6. Press the water button again
after the machine stops
7. Empty the drip tray and spent. ground container and replace
Display says Rinse Press OK
Display says Appliance Ready
In essence go to Descaling Press OK and follow the directions as they are displayed.
Sep 07, 2008 | Krups Orchestro Dialog FNF2 Espresso...
Missing tray error
Insert the tray-all of it except the grounds container.  The message disappears and you can wait until the machine continues it's cycle and then asks to empty the tray.  Empty the tray and place the grounds container back inside.  Whew, I've done this a few times over the years when I am rushing but it fixes it every time.
Jan 24, 2008 | Jura Capresso Impressa F9 Espresso Machine
Saeco Magic Comfort Plus Espresso Machine Logo
27 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
