Question about Saws
Why does my blade keep jumping off track on my black and decker 7 1/2 band saw
    Sergeant:
  • 468 Answers
There are few reasons why blade jumps off, you may have a poor weld on the blade. Tension could be too tight or too loose. Make sure that the blade tracks properly. I advise you to watch videos about tuning up a band saw or check some informative blogs on bandsawblog.com. I purchased my blades on sawblade.com , check them out if you need any.
Posted on May 15, 2014
4 Suggested Answers
the recycler
  • 22 Answers
SOURCE: Porta Band saw blade jumps off
I had this problem on a used model 725 that I bought. Apparently the rubber tires on the drive wheels develop a bit of a memory after sitting for a while with tension on the blade. I tried cleaning the tires to no avail. Then I removed both tires, flipped them over and re-installed. Still not fixed. Then I put only one back to the original position and the problem was solved. Other than the frustration of trying several times, I was out nothing and I got quite proficient at taking the blade in and out. The saw has worked fine ever since. I hope this simple (and free) solution works for you.
Posted on Jan 12, 2009
  • 5 Answers
SOURCE: NEED BAND SAW BLADES FOR MY OLD BLACK & DECKER
sometime you can get lucky on ebay. thats one place you check. the best thing about it that it's nation wide. i found alot of odd items in there.
Posted on Jun 24, 2009
  • 87 Answers
SOURCE: need blades for a black and decker band saw 7
You can det it @ www.grainger.com. hope this helps
Posted on Oct 03, 2009
Band saw blade keeps coming off
Set up your band saw properly. There are several reason why band saw blade keeps on coming off on the wheels: loose/wear tire, improper guide adjustment, incorrect tension, over feeding wood stock or the problem could be on the blade itself. Try to change your blade, I got my band saw blades on sawblade.com . I suggest you watch band saw tune up tutorial videos on youtube. Hope that helps.
Aug 13, 2014 | Black & Decker Saws
Length of band saw for 7 1/2 black and decker band saw blade
I get my band saw blades on www.sawblade.com . I cut both wood and metal. I'm using their Carbon and Bi metal blades. Give them a call.
Aug 12, 2014 | Saws
How do i open the motor to a black&decker 71&2 inch band saw ? my saw has started to make a lot more noise when runing
There are many reasons why band saw make noise. Here's are some "few checks" to do
1. Run the band saw without blade.
2. Run with a different blade.
3. Run the motor alone.
4. Check the bearings.
Another thing; incorrect speeds and feeds can cause noise and vibration.
Regarding about opening the motor, I can't help you with that. Try to check any other band saw motor manual reference.
I have Trajan 7x12 band saw, no vibration or noisy at all, I use Haltbar blade from sawblade.com
Jun 15, 2014 | Black & Decker Saws
I can't keep the blade onblack decker 12 inch band saw
There could be a problem with the tension and tracking. Make sure the tires are not worn out. Try to install new blade too, apply the right tension. Also, place the deepest gullet of the blade on the center of the tire. Check sawblade.com for some band saw tips.
Apr 06, 2014 | Saws
Need a band saw blade for an old Black & Decker Model 9422 (1/4" x52 3/4")
Just Google "band saw blades 52 3/4" for more information than you want. Most woodworking supply stores carry them.
Here's one: http://www.toolcenter.com/052_75_Band_saw_Blades.html
Jan 20, 2011 | Black & Decker Saws
Saw blade jumpes off at motor pulley on horizontal band saw
It is probably not tracking. you need to back off the guides, get the blade to track in the center of the tire by hand. Then torque it up a bit till it twangs, Then pull the guides up the blade and just touch it, don't push it at all, the bearings too. This should track and not jump off. If it does, then one of your wheels is out of whack, check them with a straight edge with the blade set. See if they are in line. One of the bearings could be bad. Check it out.
Apr 15, 2010 | Wilton 5" X 8" Dry Horizontal Bandsaw Band...
My black & decker band saw is making a noise behind the table and throwing off the blade. How do I fix this ?
Open the case and look for stray wood pieces. Check the bearings for both wheels. Check the mounting of the lower wheel to it's shaft. Operate the saw by hand until the problem is fixed. Good luck!
Jan 10, 2010 | Black & Decker BDBS100 9-Inch 3.5-Amp Band...
Saws Logo
100 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
