Question about Apple Ipad I-pad
I pad turns off after 3 minutes
Works fine, then shuts off
  • 2 more comments
  • Brian May 14, 2014
    Hi Byron Chapman, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
    Are you or have you ever used a generic (non-Apple) charger?
  • Byron Chapman May 16, 2014
    It works fine for 3-5 minutes, then goes black.
  • Thomas Stauber
    Thomas Stauber May 18, 2014
    How old is the Ipad? Sounds like you have a definite power problem. Do you have the same problem with the charging cord plugged in? If the Ipad is several years old it probably could be the battery. That is a common problem with the Ipod also. It also could be the cord itself.
    If you have an Apple store nearby they could tell you in a couple of minutes if you bring the Ipad with you. If it's an older Ipad and you have another cord try plugging it into the USB port of a computer and see if it charges. If it shows that it is charging then it probably is the battery.
  • Tamara Crawford Jul 01, 2014
    get a new battery put in, it sounds like the on you have has fried (can happen from over charging)
  • Apple Master
  • 3,187 Answers
It could be a spring board problem. some apps have been know to cause problems with the graphics. it would restart its self and remove it from startup would be logged in the crash file. and debug will remove it on next startup but it will do this every time until its fixed. backup on itunes. and do a restore software. then put your stuff back on after restore. you will need to unplug from ituens then re plug it back then the backup will restore
Posted on May 29, 2014
My vehicles shuts off after 3 three minutes of use or when its idling after first initial start but starts perfect when the engine is heated up. Can you help me with this problem?
Car starts then dies in a few seconds - CarGurus
www.cargurus.com > Questions > Ford > Crown Victoria
CarGurusFeb 3, 2014 - Engine turns over fine and starts, but stops in a second or 2. ... Good fuel pressure, starts, runs for about 7 seconds, dies after a sudden drop in fuel pressure. ...starts 15 minutes later, runs fine then stumbles and dies again 3 answers ... I drove carhome shut off and next morning would not start, but will turn ...
94 camry le 4cylinder starts when cold, shuts off .
Nov 23, 2015 | Cars & Trucks
Samsung 46 inch LCD tv problem
AmanStino Mouse Pad with Gel Wrist Pad grey(9.0*7.8)
  • 1.Smooth and precise mouse tracking, Non-Reflective surface.
  • 2.Large round mousing area, Memory Gel Pillow keeps your wrist in natural position.
  • 3.Ergonomic design wrist support - Keep arms, wrists, and hands from getting sore while using the computer, reduce wrist stress and tirednes.
  • 4.Suitable for most optical, trackball, laser, and rollerball mi.
AmanStino Mouse Pad with Gel Wrist Pad black9 0 7 8 AmanStino
Feb 16, 2015 | Samsung LN46D630 46 inch LCD 630 Series TV
My ASUS Transformer will not power on
1. Make sure it is charged. If the battery is dead you may need to leave it plugged in for a few minutes before it will turn on.
2. Hold the power button down for at least 10 seconds. This may bring it back to life if it didn't shut down properly.
3. Make sure no other buttons are stuck down (volume up or down). If another button is stuck down the power button won't work.
Apr 16, 2013 | ASUS Eee Pad Transformer TF101A1 Tablet...
Can't get new mail
Try holding down button at top to turn iPad completely until Apple logo appears on screen. That's a complete shut down. Leave off for two minutes, turn back on. If still not able to download email, contact Apple. Sometimes it's Yahoo or other provider that's holding up the works. If case, Yahoo might suggest creating new account. See if total iPad shut down works first.
Jimmy
Apr 06, 2012 | Apple Ipad I-pad
I have a compaq cq61 laptop , before few days my laptop fan stopped working nd my laptop back side getting verry hot after using 30 minutes ..bt laptop nt getting shuts off bt laptop is getting verry slow...
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit dust causes static to build up in a computer causing it to overheat any many other problems
also you could buy a laptop usb cooling pad 3-LED FAN USB NOTEBOOK LAPTOP COOLING COOLER PAD STAND or something similiar the cooling pads are very cheap and very good thing for your laptop
hope this helps
May 23, 2011 | Compaq Presario Fan
1995 pontiac bonneville was running fine until I parked it. Came back several minutes later and now it wont fire off when I turn it over. After spraying starting fluid in it, it works fine for about 5...
Can you hear the fuel pump hum when you turn the key to on? If it will start on starting fluid, you definitely have a fuel problem. The pump being stuck or bad, or the filter being plugged, or vapor lock (try loosening the fuel cap, does it pull in air?)
Feb 26, 2011 | 1995 Pontiac Bonneville
I have a 46 inch polaroid lcd tv that when you turn it on everything is fine but after about a minute it starts making a loud squealing noise,even if you mute it, but it will stop after about 15-20...
my 46'' inch tv polaroid lcd has been working fine for 3 years. today my wife and I noticed the tv is shutting off the screen will go black and the power light does switch to red. you can here something inside the t.v clicking but you can turn it on and it will start back fine for 20 minutes then shut off again? Does anybody know whats going out on the tv? let me know
Nov 16, 2009 | Polaroid Televison & Video
Electronic touch pad not working on my oven
Hello beachlady80,
Welcome
You said, It was working fine last night but when you woke up this morning the display has 3 vertical lines and none of the electronic touch pads work. The burners on top of the stove still work.
What is the model number and how old is the range ?
Try turning the breaker off for 10 minutes and then on again after this allotted time.
This may reset the system.
Let me know how it works.
Waiting for your answer.
Huuum
Please remember to leave a rating.
Hopefully it will be a solved!
Let me know
Oct 16, 2008 | Maytag MGR6772 Gemini Gas Kitchen Range
Printer trouble
I also have the same problem after checking the Canon web site I found a page which deals with this problem By:
1.) Press the "Of" button to power down the Printer
2.) Remove USB cable.
3.) Remove Power cable.
4.) Waite 3-5 Minutes.
5.) Re-connect USB cable.
6.) Re-cone ct Power cable.
7.) Press "On" Button.
And all should be seet, not in  my case the blasted
red alarm is on and the error message returns again.
Anybody knows how to fix this blusted problem???
Bill Slow
Mar 28, 2007 | Canon PIXMA MP760 All-In-One InkJet...
Apple Ipad I-pad Logo
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
