Question about Norcold Inc Refrigerators
Norcold refrigerator I have a 2007 Jayco Jay Flight 27BH. Have Fridge set on warmest setting, but still freezes everything. Have not tried on gas, just electric. Any suggestions?
HVACRH20
  • 237 Answers
SOURCE: Refrigerator freezes everything even on the lowest setting
Is everything really frozen or just the top shelf stuff? You may have a thermistor (temp sensor) problem if the compressor just runs and runs and runs all the time. Take a glass of water and place a thermometer in it for about 3 hours then take a temp. reading. That will let you know what the real temps are. See if you can cause the compressor to kick off and on by changing the temp settings (go to real low for about 5 minutes then back up to high). Let us know what happens.
Posted on Dec 26, 2006
  • 51 Answers
SOURCE: norcold rv refrigerator freezer
Make sure the thermister is attached firmly to the fins in the back. The boards on a Norcold can be reset a service center familiar with this process is your best bet. It takes disconecting the board and then shorting it out best to leave it to some one who is familiar.
Posted on Sep 08, 2008
bobicehouse
  • 1524 Answers
SOURCE: My refrigerator freezes my food solid
Replace cold control
Posted on May 03, 2009
  • 15 Answers
SOURCE: my norcold frig(RV) freezes food in lower level
in your refridgerator there is an internal thermostat on the cooling fan u can move up or down it should be placed on the last finn to the right looking at the fridge
thanks
cruz
cruz's mobile rv repair
Posted on Jun 17, 2009
SOURCE: RV freezer cools, but fridge section doesn't
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Posted on Sep 12, 2009
I have a Norcold n611 fridge gets too cold and freezes even on lowest setting.
The temperature control thermostat, alson known as the colds control thermostat has gone bad and basically isn't converting electrical/temperature signal properly and needs to be replaced.
May 10, 2012 | Thetford Norcold RV Cooler/Freezer
The refridgerator side is too cold- i have it set to the warmest setting and everything is still freezing in the fridge. Any help would be great thanks.
try to adjust on a warmest setting then observe unit if not replace your thermostat means the sensor is deffective iinstall new thermostat.
Feb 05, 2011 | GE 23.1 Cu. Ft. Side-by-Side Refrigerator...
Fridge of my Hotpoint FFA90 fridge-freezer freezes
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Mar 11, 2010 | Hotpoint FFA90 Bottom Freezer Refrigerator
My GE side by side has started freezing everything in the refrigerator on the warmest setting and the freezer will not maintain less than 10 degrees on the coldest setting. Any ideas?
on the left side of the crisper drawer there may be a air return hole that you can adjust, if not try some duct tape where the air comes into the fridge, cover it by 1/4 then 1/2 till it is the right temperature
Aug 04, 2009 | GE Refrigerators
My norcold frig(RV) freezes food in lower level
thanks
cruz
Dec 16, 2008 | Thetford Norcold RV Cooler/Freezer
There are vents that allow the cold air to flow from the freezer to the fridge. If those vents become clogged with ice or fail mechanically, they can become stuck open or closed. The temp adjustment should move the damper in the vents. But if they are frozen open, then the fridge will become too cold.
Thank you for contacting us.Please do rate fixya if you like the solution.
Dec 10, 2008 | Samsung RB2155 Bottom Freezer Refrigerator
Norcold RV Refrigerator
It sounds like the relay could be stuck closed on the electric side of the board. This would not allow the element to stop working. Sometimes resetting the board will fix this problem if it is still under warranty they will cover both the board or the resetting.
Aug 07, 2008 | Refrigerators
Refrigerators Logo
47 people viewed this question
Top Norcold Inc Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
Are you a Norcold Inc Refrigerator Expert? Answer questions, earn points and help others
