Question about LG Televison & Video
Why there is no video in my lg TV but with sound?
When I turn on the power the lg logo will appear then the screen will turn black. I can hear the sound mean the program is running.
  • 2 more comments
  • Aries
    Aries May 19, 2014
    Dear experts. Attached is the video of the issue. Please have a look and confirm if the problem is the BackLight LED panel or the Inverter board or the driver or just the energy saving mode. Thanks. Aries
  • Aries
    Aries Jun 01, 2014
    Hi Hector. I upload the video again. The LG technician explain me that this is a symptom of a busted bulb inside the backlight panel. When there is a busted bulb the control switch it off to avoid overcurrent. ANd it is not repairable and needs to replace the whole panel which is 1/3 of the original price. I'm still hoping it's just the inverter. THanks.
  • Aries
    Aries Jun 01, 2014
    Youtube link
  • hector62
    hector62 Jun 03, 2014
    way to know the cause, raising the overcurrent sensor pin pwm controller IC as it is protecting the Tv for failure. Send me the reference model or tv, LCD CCFL LCD or LED? to send you a diagram of how to isolate the fault.
  • 3 Answers
If the TV will not be turned off, then you have a problem with the card or inverter circuit, but prior check filter capacitors of the source (which are not embombados, loss of capacity), if you see well, now check the Inverter (there may be loose solder if the TV is new, especially in transformers high, a defective MOSFET, transformer and test compares the lamps)
Posted on May 15, 2014
  • 4 more comments
  • Aries
    Aries May 15, 2014
    Hello Hector. I can be able to turn off the TV. The unit is not new. This problem start happening after 3 years. I
  • Aries
    Aries May 15, 2014
    I checked all the components and the solder joints but I don't see any damaged part. I check the 3.5volts power for inverter and the power is ok. The LG technician come to visit the unit but didn't open the it. We just turn the power "on" and "off". Then he diagnose to have deffective LED back light. I was not convinced so i start checking online solutions. It looks like the LED is fine because when the I turn on the unit i can see the LG logo come out then black screen will proceed after that. I'm guessing that it could be a damaged controller(IC) or just the driver of the inverter board is corrupted if the IC is still ok.
  • Aries
    Aries May 15, 2014
    Model: 32LE5500. I was looking for schematic diagram to check component level but there was no luck for me.
  • hector62
    hector62 May 16, 2014
    Within the same source is the "smart module" that is responsible for controlling the power MOSFET to regulate LED HIGH GLOSS, which provide the light necessary and appropriate in the images received.
  • hector62
    The LED's need to operate a common voltage is around 195V, which as mentioned earlier anger with each and every one of the rows.
  • hector62
    As the control line, the voltage is about 2.5V has and this will be monitored by the mosfet.
SOURCE: LG LCD TV 32LC4R BLACK SCREEN
same here How do you change the Power regulator?
Posted on Jan 28, 2008
SOURCE: at power up tv displays Acer logo then goes to black
will not turn off power with out unplugin it
Posted on Mar 01, 2009
KingDWS
  • 1606 Answers
SOURCE: no picture
It sounds like the backlight is out. If you can see a faint image that changes then this is the case. You either need to send in for repair or replace. It can if you are lucky be a connection. You can try removing the video cable and try another source or cable.
Posted on Jul 09, 2009
SOURCE: LG RU-42PX11 42 plasma TV has black bar
it seems to be a bad connection somewhere but I disconnected the ribbon cable and got a verticle line of snow instead of a blank line. the line is about 34 mm wide and starts 285 mm from the left edge starts on the Blue and goes to the Red pixels. so if they are 1mm wide that would be 34 bands of color.
I would sure like to figure out the solution to this one or I got a TV I need to throw away cause the o'lady is gonna bust my balls if I can't fix this!
Posted on Sep 28, 2009
  • 13 Answers
SOURCE: VIZIO TV Black screen. Cannot turn off TV without unplugging.
I had a similar problem after having a Vizio for 2 and a half years. I left the room for a minute, i came back and the screen went black. I didnt hear an arcing sound though. There was still power to the unit and you could see that the back light was working, just no picture, no sound, and you couldn't use any of the buttons. The only way to turn it off was to unplug it. It would then start up, with the Vizio logo going from orange to white, and then do the same thing all over, no pic or sound. I would check the ceramic fuse first on the board that gets power from the plug.
HOW I FIXED MINE: I ordered a new "main PCB" from tigerdirectparts.com (you can also use searspartsdirect.com). This is the circuit board with all of the inputs on it (hdmi, cable, etc.) I opened it up, disconnected the old one, put in a new one and now it works fine.I used both serial numbers on the board to search for it online. It cost me $144 to do it, but that's better than $450 for a new TV. My tv is the vx32l hdtv10a. I hope that helps.
Posted on Jan 22, 2010
I have a lg 60 in flat screen smart tv. When powered on, the screen flashes the LG logo then turns black. I can still hear the audio but no video.. any idea how I can fix this.
hi in a dark room shine a flashlight on the screen see if you can still an image if you can, the led or leds has shorted in the panel thanks
shaun
Mar 08, 2017 | LG Televison & Video
Sound no picture
inverter board issue.
Feb 22, 2017 | LG Televison & Video
My tv powers on displays the LG logo then makes a high pitched squeal sound from speakers and then flashes on screen (strobe light effect) does not display picture or sound.
LCD TV Repair Tutorial - LCD TV Parts Overview, Common ...
? 11:05
https://www.youtube.com/watch?v=tS4sIpdajVw
Aug 23, 2013 - Uploaded by ShopJimmy.com
Repair review of common LCD TV Problems and Repair Solutions ... input the tv is set to it begins making a high pitched whiningsound. .... I have a LG 47LN5750 that powers on, flashes a good picture for about 1/2 second, then goes dark. ... hi my samsung tvis not turning on is black. and I just replace the ...
#Treat At Home high pitched whine from plasma tv Tinnitus ...
www.aspenridgerentals.com/tinnituscure/?...high%20pitched%20whine%...
LG 50PK540 plasma TV Repair power supply EAY60968801 Part 1-2 ... Sanyo DP42849 with high pitched squeal after replacing power supply. ... In my second daily fix video, I solve a mystery that was making me having to turn off my speakers before I went to be ... The flash is accompanied by an high pitched sound.
TV not turning on; making high-pitched sounds - Tom's ...
Dec 16, 2015 | LG 55LE5400 TV
LG Plasma has no video or sound...power works
go to Samsung.com and look at your serial number to see if they have a rollback code
Dec 11, 2015 | LG 60PM6700 60" 3D 1080p Plasma TV - 16:9...
47" Vizio LCD
Sounds like incompatibility of video settings or loose cable. It is also possible that you have a bad power cable. Is it hooked up to anything else or is it just plugged into the wall only?
Nov 15, 2013 | Televison & Video
Sound but No Picture
Perhaps your remote is set to video recorder?  Try that first, and if no response, try calling up a menu on your TV and look for the Picture Settings.
Good Luck.
Nov 03, 2007 | LG 37LP1D 37 in. LCD Television
Televison & Video Logo
64 people viewed this question
Computer Repairing
Computer Repairing
