Question about Troy Bilt 5.5hp Self Propelled Mower
12a-562q711 replaced the belt but transmission does not engage. Belt turns but do does not turn the transmission. I have replace the Belt tension spring also. should the cable be replace or is it the transmission?
    Novelist:
    Scholar:
  • 197 Answers
Based on your description, it really sounds like a transmission problem. I would check the linkage between the engage bar and the transmission to be sure that it has not come loose and there is not engaging. if the linkage is intact and when you grip it to engage it and the belt still turns then the problem would appear to be internal to the transmission. If the mower is still under warranty, I'd take it to an authorized repair shop and have them fix it. If it's out of warranty, you have nothing to lose by taking the transmission apart to see if it is something you can repair such as a loose gear that can be tightened with a set screw or something simple like that. If you find a stripped gear, it still may be fixable with a part order from the manufacturer. Or, you can simply replace the whole transmission but that won't be a cheap or quick fix.
Before making a final decision on any of this, it also might be well worth you while to contact Troybilt to see what they advise. In fact, you probably would have been a bit wiser to have contacted them before posting here because it's extremely difficult to diagnose a problem without having a "hands-on" look at the machine, itself.
I am not a mechanic but I'm an experienced do-it-yourselfer and I was able, years ago, to repair the transmission on a John Deere riding lawnmower, first by replacing a stripped gear and then a few months later replacing the entire transmission. I did not find either job terribly difficult but I had nothing to lose because I bought the mower used for very little money so I had some tinkering room.
After replacing the transmission I was able to sell the mower for enough to cover its original cost and the cost of the parts. Obviously, I did not recover the cost of my time or the frustration of dealing with a bad machine from the start.
Posted on May 14, 2014
Testimonial: "Thanks for the advice. It is very helpful."
    New Friend:
  • 13 Answers
If you have taken all the slack out of the cable to engage the trans, then it very well may be the trans..I do not believe it is the spring.But the springs are cheaper than the trans. First: make sure it is the correct size belt. 2nd The cable is shifting the lever the full distance (Kind of like making the shifter go into 1st gear on a car) If it does not move fully ,it will not engage. Best of luck. One more thing to test, When you have it ready to go Cable is pulled back..pull on the cable to see if there is any slack...if it starts to move ,you found your problem.
Posted on May 15, 2014
Belt tension troy bilt horse xp 46 lawn tractor
if you just replaced the bearings and now the belt is to loose tells me the belt wasn't put back on correctly. replacing the bearings don't have anything to do with the adjustment of the belt. double check to be sure is is on right Lisa. something isn't right. the tension should come from a spring loaded arm that when engaged it will apply a certain amount of pressure to turn the blades. if disengaged it will seam loose but that is ok. it has to be loose to let the belt slip on the pulleys.
Jun 26, 2016 | Troy Garden
What will cause blades on J.Deere G100 mower to Freely turn by hand without causing Spindles or belt to turn even though Bolts are still tight and when installed Blade turned only if spindle turned
Do Ray:
If the blade engagement lever is in the disengaged position, the belt will be loose, allowing you to turn the blades by hand. If you place the blade engagement lever in the engaged position (with the motor off) it will be hard to turn the blades because of the tension on the belt. If the blades are still easy to turn with the blade engagement lever in the engaged position, you need to replace the blade drive belt!
Jun 15, 2015 | Garden
After replacing rollers on a LG TROMM DRYER. it won't spin
I would check to see if I put belt on right. There is a belt switch the must engaged. Also is the door switch plugged back in?
Feb 07, 2015 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
How to adjust a loose mower deck drive belt?
check your pulleys to make sure they haven't split as this does happen. Adjust the belt tensioner to tighten the belt when you engage the clutch to drive the mower. You should be able to see the belt tensioner by dropping the cutting deck to its lowest point and looking underneath the mower to see which pulley actually puts the tension on the belt to make it drive. there is no need to start the mower to find which pulley needs to be adjusted, it should be obvious when you look at the belt and the pulleys.
Hope this helps you
May 17, 2014 | Garden
Ac not working right
Your A/C clutch is at fault and it is wearing your belt to get broken! Open the hood, have someone start your engine with out starting your A/C. Check your serpentine belt pulley and tensioner for wear. Then have someone turn A/C on high and watch the cluch engage or disengage. If clutch engages but do not turn you need to get it replaced or repaired.
Feb 19, 2014 | 1995 Ford Windstar
The drive belt on my Honda HRT broke. I replaced it and within a few seconds the new belt broke. I know the blades are turning, but I'm wondering if the wheel on the transmission is not turning thus the...
could be rear end is locked up you will have to get another belt try turning wheels by hand if loose see if there are broken bearings anywhere on the drive usally thats the case with the belt bearing goes out and shreds thr belt try those ideals
Jul 30, 2013 | Garden
The belt that drives the blades for cutting has broken and I need to replace it. I have a Craftsman LTX1000 lawn tractor and I've misplaced the manual. The belt is 96" long. Not sure where to...
With the mower off.
Look on top of the deck.Find the pulleys for the blades then find the engine pulley.There should be one more pulley that is the tension pulley.Watch that pulley as you pull the engage blade lever,while still turned off.The belt will go on the blade pulleys,and the engine pulley,it needs the tension pulley to push it tight.So you need to make sure it goes on the inside of the tension pulley.If you get the belt on and it does not engage,just remove it and replace it on the opposite side of the tension pulley.
May 12, 2011 | Craftsman 42 in. Precision Cut Plus 24hp...
How do you adjust the drive cable on a troybilt self pro pelled md# 12A-446A711?????
Unfortunately, you cannot adjust it. If you have an extra space to move it lower than it was on the handle you can do that. You might have to get a new cable. Or the belt may need to be replaced. Do you hear a grinding noise when you try to engage the self propel? If so the transmission may have gone out. The most common problem is that the belt has jumped off from where it needs to be and it is no longer turning. To check to see if the belt is off, you will need to put the mower on its' side, the side with the oil level check is the correct one. You will need to loosen the cover over the drive belt. This is done by loosening one or two bolts that hold it in place.The bolts should have 3/8 hex heads. You may have to maneuver the cover a bit to see if the belt is in place. If the belt has jumped above the pulley for the self propel then you will have to install a new belt.
Mar 26, 2011 | Troy Bilt 5.5hp Self Propelled Mower
Install belt on toro mower model 70041
For removing/replacing the deck belt, the general method is:
  1. turn off engine, remove key and set parking brake
  2. disengage blade by putting blade engage lever into off (disengaged) position
  3. lower the cutting deck to the lowest position (closest to the ground)
  4. relieve the belt tension (depending on the model, use a 3/8 inch ratchet set to tighten in the square hole of the idler bracket)
  5. remove and replace the belt
NOTE: it's not necessary to completely remove the cutting deck.
Useful diagrams for removing the cutting deck, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14794
For deck belt diagrams, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14796
If the transmission drive belt needs to be replaced, several components must be removed and special tools (i.e. air/impact wrench) used in order to change the tractor's transmission drive belt. See an Authorized Toro Service Dealer to have your drive belt replaced.
Sep 09, 2009 | Toro Lawn Mower With Toro Power Tools
Troy Bilt 5.5hp Self Propelled Mower Logo
184 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
