Question about Ford 8N Tractor
What is the point gap for ford 8n - Ford 8N Tractor
  • 653 Answers
The point gap on the 8N is 0.015".
Posted on Aug 24, 2014
3 Suggested Answers
What is the point gap for a 1948 8n ford tractor
The ignition point gap is 0.015" and the spark plug gap is 0.025". More specs here:
http://www.tractordata.com/farm-tractors/000/2/2/223-ford-8n-engine.html
Jun 08, 2014 | Ford 8N Tractor
What is the point gap ford 8n
.015 for 2N, 8N & 9N
The 8N also had problems with ignition switch causing several troubles, cheap and easy to replace....Below link is an excellent site.
http://www.yesterdaystractors.com/atrp/specs/ford.htm
May 14, 2014 | Ford 8N Tractor
I have fire at coil but no fire through sparkplug wires
The problem sounds like it is your distributor. Replace the ignition points and condenser, make sure the points are gapped properly. If you still don't get fire at the plugs, change the distributor cap, rotor, and wires. Points and condenser kit runs $9.72.
http://www.yesterdaystractors.com/ATK7FA_Ignition-Kit-4-Cylinder_14717.htm?gclid=CJzJscSG47sCFXPNOgod31wAqA
Jan 03, 2014 | Ford 8N Tractor
On a 1949 ford 8n, do you set the gap on the bottom of the lobe or the highpoint of the lobe?
The MOST gap at the high point of the "BUMP" of the lobe should be the most that the points will open.
.016 " Be sure the points CLOSE,also.
Apr 25, 2013 | Toys
Won't start !! converted to 12v ,new starter and solenoid installed along with new coil,points,roto cap now no spark to plugs
Cranks? Check voltage to + side of coil,first. 10 V. OK.
Be sure that points open and close.SEE it as it cranks.
Points gap should be around .016 "
If you open and close the points,key on,engine off,the coil should SPARK!
Use a screwdriver to get a shock. Fun.
Sorry.
The coil will spark when you short the points,when they are open.
Mar 17, 2013 | Ford 8N Tractor
Points gap for 1953 8 n ford tractor
Here's how to do it:
http://www.ehow.com/how_7368031_set-points-ford-8n.html
set the point gap a .025
Jan 13, 2013 | Ford 8N Tractor
Ford 9N problems; Changed plugs, wires, cap, rotor, points, and ignition coil. Point gap at .015, new condensor. 6 V battery fully charged. No voltage drop to ignition coil. Results, no spark.
You might check ground. some of these units were ground positive. did you switch the posts?This would cause problems since the electrons are on the inside of the condinser.
Good luck
Joe
Feb 11, 2011 | Ford 8n,9n,2n, Tractor Starter With Drive
Have new plugs, wires, cap, coil, rotor points, condensor. Still no spark
Check for power getting to the center top connection at the coil.
Are the points opening?
Are they fully closing?
Check for a grounded connection/wire in the dist?
Be very careful how you set the coil onto the dist.
Jul 12, 2009 | Ford 8N Tractor
Ford 8N Tractor Logo
157 people viewed this question
Top Ford Toys Experts
Philip Doherty
Level 1 Expert
D. E. Hev
Are you a Ford Toy Expert? Answer questions, earn points and help others
