Whirlpool ACQ158XP Thru-Wall/Window Air Conditioner
Problem for Whirlpool ACQ158XP Thru-Wall/Window Air Conditioner
Water not draining out the back
By unodogg22 on Jun 23, 2009
Window AC works fine....nice & cool. Used to drain water out the back(to the outside) of the unit. Not draining outside or inside.
Solution #1
posted on Jun 23, 2009
Somewhat Helpful)
cj2176
Rank: Guru
Rating: 91%, 201 votes
Check the weep holes in the bottom of unit. It is holding water and when it does flood itself it will be inside with you.
Was this helpful?
Yes
No
Solution #2
Not Rated)
co7196
Rank: Wiz  Air Conditioners  Expert
Rating: 84%, 1147 votes
Humidity is where the water comes from. If humidity is low, very little if any, water.
Comments:
Jun 23, 2009
- Humidity is where the water comes from. If humidity is low, very little if any, water.
Was this helpful?
Yes
No
Popular Solutions for Whirlpool ACQ158XP
Questions and Unsolved Problems for Whirlpool ACQ158XP
Do you recommend Whirlpool ACQ158XP Thru-Wall/Window Air Conditioner?
Answer
Answer
the passenger floorboard on my daughters Saturn Vue is wet. Could it be a plugged air conditioner... (More)
Answer
I am attempting to remove the front cover so I can clean my unit. I have already removed the screws,... (More)
Answer
The air fan does not work. Can I replace it myself? The compressor turns on but the air does not... (More)
Answer
i have a whirlpool ac it has leaked from somewhere my floor and everything around it is soaking wet... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Air Conditioner Experts
Top Air Conditioner Repairmen
in , OH
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
