Question about Vacuums
How do I get the high pressue hose into the wand
    New Friend:
  • 102 Answers
There are fitting that you can buy at the hardware store, havn't seen the connection but you might need a 3/8" x 1/4" bushing, brass preferred. Need Teflon tape to put on the threads or liquid.
Posted on May 14, 2014
Hoover makes a loud noise and does not pick up
Issar 702:
Take the machine to a room that has no carpeting, (this is 'gonna get messy :-) First, make sure that the machine is unplugged from the wall, then remove the wand with the hose and verify that the hose, wand and vacuum head are not clogged up... check carefully, some clogs or items stuck in the hose and wand assembly can be hard to find! Then check the hose from end to end making sure that the hose is clear of debris. Then open the canister and check to see that the gasket around the top of the canister is not damaged, then check the belt coming off of the motor driveshaft is not binding or damaged. You should be able to rotate the belt by hand with the machine off and unplugged.
Jan 06, 2013 | Vacuums
Tip
Extend a Vacuum's Hose "Lifespan"
There are several things that can lead to a fairly short "life span" on a vacuum hose. Hoses need to be replaced periodically anyway, but getting the maximum use means reduced cost for your investment. Common problems are: worn out hose, leaky hose, broken wire, loose connections, and of course, clogs.
Normal wear and tear may seem to be a problem that there's no help for, however anyone can reduce this on their vacuum hose. Some examples include:
Hang hose properly. Improper storage may promote wear on the hose and stress on the wiring. I recommend detaching from vacuum and wands, and hanging across two large hooks or hangars. This places weight upon two areas of hose, instead of just one.
Placing a hose sock on the hose will help reduce wear and tear caused by dragging back and forth on the floor, corners, and other surfaces. The heavier the fabric, the better protection.
Pulling the vacuum behind you while cleaning creates high stress on both the hose material and internal wiring. Indications of problems are loss of airflow/suction at end of hose for the first, and power nozzle not operating or intermittently operating. Avoid pulling vacuum behind you; move vacuum closer to the cleaning area to clean.
Loose connections are pretty much inevitable over time. The connections from hose to wand, wand to wand, and wand to power nozzle all are susceptible to wear and breakage. Replace hose and wand connections that are broken, loose, and/or blackened. Those things can cause bad electrical shock.
Clogs are often caused by a large item being vacuumed, but more often are due to a long, thin object being sucked up, sticking in the hose, and other stuff backing up against it. This will eventually cut off air flow and result in a burned out motor if not remedied.
Maximize your vacuum hose’s use by following the above suggestions.
on Aug 29, 2010 | Vacuums
A Dyson dc 17 Animal and the wand/hose has lost suction
Hi its Darran at Dyson.
From your description of the problem, it sounds as though the wand/hose is blocked. To check this, remove the wand/hose assembly from the machine, switch it on and test the suction from the top of the wand with your hand. If the suction is poor, remove the wand from the hose and test the suction from the top of the hose. If its good here, then you know that the wand handle is blocked.
For the full diagnostics, check out the Support section on our website at www.dyson.com or call our Helpline on 1866MYDYSON.
Kind regards
Darran
Dyson Customer Service
Jan 30, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
No suction on wand of Dyson DC14 Animal
It sounds as though the wand handle is blocked. To check this, remove the wand/hose from the machine as if you were going to use it to vacuum the stairs. Switch the machine on and test the suction at the top of the wand handle with your hand. If the suction from the wand is poor, remove the wand from the hose and test the suction again from the top of the hose. If the suction here is good, then you know the wand handle is blocked. If the suction is poor at the hose, you can remove the hose from the machine and clear any blockages here.
For the full blockage procedure please visit the support section on our website at www.dyson.com.
Kind regards
Darran
Dyson customer Service
Jan 10, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
Hose does not go down into wand
It may be that your hose is twisted - disconnect the wand from the hose and stretch the hose out and put it again. Use some baby powder on the metal rod part of the wand in the future and unwind and stretch the hose out after every use. Call the Dyson helpline if the problem continues.
Jul 25, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
I can't figure out how to hook up hose attachment to dyson 07
You have a reversible wand on the DC07. You have to separate the wand from the hose first, then turn it around and reconnect it. Once that is done you will be able to use the attachments on the end of the wand. You can also connect your attachments to the hose.
To separate the wand:
1) Take the wand off the back of the machine
2) Place one hand on the Handle and one hand on the gray flexible hose.
3) Push the flexible hose down. You will see a long metal rod appearing. Push until the hose clicks into place at the bottom of the metal rod.
4) You'll see a half-moon shape button with a picture of a lock on the solid gray plastic part at the top of the hose - push it, this will separate the wand from the hose.
5) Turn the wand around
6) Push the purple wand cap with the holes in it back, it exposes a short dark gray pipe, about an inch in length
7) Connect the hose to the short pipe
8) Attach your tools to the top of the metal rod and have fun
Jul 08, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson dc25 animal: cannot remove the telescope reach wand.
The hose is getting twisted on the machine and so the wand gets stuck in the hose.
1) Pull the wand out as far as you can - if you can pull it out completely, separate it from the hose and apply baby powder to the
metal rod. Stretch out the hose and unwind it. In the future, separate the wand and unwind/stretch the hose after use.
2) If you can't pull the wand out all the way, remove the canister/dirt bin from the front. Look for a gray button with 7 vertical
lines/grooves on it (it'll be just above the ball on the opposite side of the bottom hook that you wind the cable around).
3) Push the button and at the same time pull the hose out from the bottom by pulling on the hook - this will release the gray hose
from the machine. Take it off of the machine if possible (the bottom of the wand may stop you from doing so - if it does, try to pull
the wand out until you can release the hose from the bottom)
4) Pull and stretch the hose out and pull the wand at the same time - separate the wand from the hose and unwind the gray hose and
stretch it out. Rub baby powder on the metal rod of the wand and in future, disconnect the wand from the hose and stretch/unwind the
hose after every time you use the wand.
Jun 20, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
I have Dyson animla and the wand stop working....no bloc anywhere
The hose is getting twisted on the machine and that makes it difficult to pull it out.
1) Pull the wand out as far as you can - if you can pull it out completely, separate it from the hose and apply baby powder to the metal rod. Stretch out the hose and unwind it. In the future, separate the wand and unwind/stretch the hose after use.
2) If you can't pull the wand out all the way, remove the u-bend from the bottom of the machine - turn that plastic screw at the bottom next to the gray hose 45 degrees anti-clockwise and take the u-bend off.
3) Pull the hose out from the bottom (don't pull it out all the way - just enough to release the wand) and pull the wand at the same time - separate the wand from the hose and unwind the gray hose and stretch it out. Rub baby powder on the metal rod of the wand and in future, disconnect the wand from the hose and stretch/unwind the hose after every time you use the wand.
Jun 17, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
The extension arm of my Dyson Animal no longer has any suction. I can attach it but it has extremely limited power to reach high places or under furniture. Also, when I stand the unit, used as vacuum,...
you have a blockage within the wand or at the u-bend at bottom of the hose....try removing wand and see if u hav esuction at end of hose...if so wand is blocked,if not removed u-bend
Oct 07, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Hose Collapses When I Try to Use Wand
Hi Both.
Ok you have A blockage, Remove flexi hose completly from rear of machine & completly remove wand & handle from the hose.
Now check flexi hose for obstruction if none present move on to the wand & hanndle look down through tha wand for any obstruction look very carefully where the plastic handle meets alloy tube there is A slight bend here often A coin gets stuck here & flips accross to block oppening when you try to use wand.
If you cant see anything coin etc put hose back on machine & switch on there should be good suction from the flexi hose,
Now with machine still switched on push alloy pipe back on if the hose suddenly pulls back & there is poor or no suction you definately have A coin stuck at the bend.
You will need A broom handle or other long solid pole to hit it out.
http://dysonmanuals.llc.nu/
Aug 03, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Open Questions:
Vacuums Logo
19 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
