Question about Yard Machines 13AC762F000 38-Inch 344cc 12.5 HP Powerbuilt 7-Speed Riding Lawn Mower
I have a riddeing lawn tractor and on its highest setting cuts grass too short how do i raise the deck to get a taller grass
Mowing grass too short how can i raise the deck to cut the grass taller how do i get the deck set higher than it is now any help would help
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Yard Machines Master
  • 1,917 Answers
If you look under lawn mower were the deck attachs you will see the adjustment rods unhook one at a time to adjust ether screw the rod in or out do this on a driveway so you can measure with the tape measure how for you or lifting deck and can match hight on both sides
Posted on Jun 07, 2014
3 Suggested Answers
  • 203 Answers
SOURCE: My engine cuts in and out.
Basically, sounds like a dirty carburetor. You might be able to cure this with some carb cleaner put into the gas tank and run, but more than likely it will need taken off and cleaned. This is not a hard job, but you have to be careful to connect all springs/wires back to the original position.
The surging you hear is the governor trying to keep the engine running as it starves for fuel. When it starts to die, the governor automatically opens the throttle up more and gives it more gas, thus the speeding up of the engine.
If you do feel like you'd like to tear into the carb, it isn't a real hard job. You should be able to do it with a phillips screw driver, a basic homeowner tool kit, and needle nose pliers. Be careful, take your time, and make a mental note of where everything attaches. You should take the engine and/or the mower ID number to a repair shop and get a carb rebuild kit. It more than likely will only include several gaskets and a few other minor items to accomplish the job. Oh, and get a can of spray carb cleaner as well. Look for any holes in the part of the carb that sits in the gas and make sure to give them a good spraying out.
Posted on Oct 28, 2009
  • 688 Answers
SOURCE: My MTD 14hp lawn tractor (38", 6 speed) shuts of
You have a short somewhere . A cut or stripped wire that , at the time of lowering your deck, touches the body. It's like turning off your key. Look around under your deck and you will find what I'm talking about. Fix wire and tie up to prevent future problems. GOOD LUCK.
Posted on Jun 17, 2011
How to raise cutting hiegth
wow, and you think we know what kind of mower you have ?!?!?!
May 14, 2014 | Yard Machines Garden
At the highest setting, I still cut the grass to short
The deck may be installed in the incorrect position on your tractor (if this is a tractor). If you have the owner's manual, check the information for installing the cutting deck. If not, then check the action of the lever and deck when raising it and lowering it, to verify it is working properly.
Jun 08, 2011 | Garden
I want the length of my grass taller. How do I adjust the blade to achieve this? Or is it the wheels?
Hi, are you saying that you want it taller than the highest blade setting? Meaning the highest notch on the blade height setting lever?
May 06, 2011 | Yard Machines MTD Gold 20 HP Lawn Tractor...
Even on the highest setting, it still cuts too low. can i adjust it to cut higher?
When you put it in the highest setting can you see the deck actually moving in an upward direction? If not the linkage might be broken or damaged. When you raise the deck up or down with the lever it should move, a deck setting in the full up position is a pretty high setting you have to have some long grass to be cutting in the full up position and still think its to short. You might be able to reposition the deck, if when you look under the unit you see a bracket that controls the deck height setting that has a number of holes in it(maybe even 2 brackets), there should be a pin(s) in one of the holes this could be set in a low position and therefore you can change position to change height of deck.
Oct 15, 2009 | Craftsman 42 in. Precision Cut Plus 24hp...
Leaving streaks of grass in middle of mower
Your forward speed may be too fast for the mower blades to cut every blade of grass. It may be new, but check the deck to see if there are any dents pushing the quill assemblies up making the deck cut uneven. Or it may have the wrong blades on it.
I have seen this problem in the past with a Gravely mower. The person was trying to cut grass to fast. He sold the unit and the new onwer did not noticed any the problems the old owner described.
Sep 25, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
48 inch deck problems
a lot of problems here.try this.[grass buildup]. usually cause by damp grass or blades not going fast enough to throw into box.engine cutout is then caused by grass jamming blade[s]. backfire is usually too much choke or wrong petrol/air mixture.re bent grass.try cutting driving in reverse[if strip is wide cos of back tyre then blade is uneven.]
Jul 21, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna YTH20K46
Is this the first time cutting grass with a lawn tractor?
How tall of grass?
Use the grass cutting heigth adjustments on the tractor to a higher setting when cutting tall grass. Cut again to a lower height setting on the second pass. Grass higher than your tractor is not good for your tractor. Follow the manual instructions for best results.
Jun 27, 2009 | Husqvarna 23 Hp 48" Deck Yard Tractor
The highest deck setting cuts my grass down to one inch.
leveling bolts hang from each side deck by frame...tightened up and level...will give you some more room....be sure the blades are not bent.
Jun 14, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Mower bogs down in medium high gras
what is happening is there is tomuch grass in deck & not discharging as fast as it cuts it if deck is ajustable put it on high setting then try if it works then got back over it with a lower setting this is most likely the case to much grass in deck while mowing blade gets cought up alot with alot of grass in deck
Jun 05, 2009 | Toro Lawn Mower With Toro Power Tools
Yard Machines 13AC762F000 38-Inch 344cc 12.5 HP Powerbuilt 7-Speed Riding Lawn Mower Logo
126 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
