Question about Fisher and Paykel Refrigerators
Hi. I just bought a Fisher Paykel refrigerator that did not come with connections to the water supply. All that is there is the polyethylene tubing (no connectors or filter). How do I go about connecting the refrigerator tubing to my water supply tubing?
    Problem Solver:
  • 16 Answers
Jan- run down to your local ACE hardware if you have one, or home repair shop ask for a water connector kit for refridgerator, it comes with all the connections and instruction also make sure you have the connection for the hose under your kitchen sink if so then the kit will do it for you, get the kit with the longest tubing just to be safe, not sure but will need a pair of pliars and possibly a sharp knife and screwdriver, you can do it yourself 123- easy peezy, japanesey
Posted on May 14, 2014
    New Friend:
  • 102 Answers
Go to the hardware store and take a piece of tubing with you and ask them about it, they should be able to tell you what you need, also you can get an inline water filter for the unit.
Testimonial: "Yes, that's what I thought. Does this devoid the warranty if I don't use their parts?"
    Top Expert:
  • Fisher and P... Master
  • 34,711 Answers
You may be able to purchase a kit containing all parts and hardware or you can make up what you need from individual parts. Fisher and Paykel should be able to advise you.
aborcass
  • 2651 Answers
SOURCE: water leak where hose meets refrigerator connector
thinkin the line is frozen within the freezer wall leading to ice maker. the white hose from bottom of refrig to top freezer ice maker inlet os where leak is?? try removing it and blowthough the line onto freezer section, if cloged(of frozen) the inlet tube can be removed adn thawed out
Posted on Mar 03, 2008
  • 210 Answers
SOURCE: LG REfrigerator - water line connector
Try closing the water valve slightly to reduce the water pressure to the unit.
Sgt 48
Posted on Jun 03, 2008
ngfam1
  • 639 Answers
SOURCE: LG water filter BL 9808 connections
Dear FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
USUALLY THE FILTER IS PART OF THE FRIDGE!
WHIRLLPOOL DOWN IN THE GRILLE, THE OTHERS INSIDE THE FRIDGE THERE IS A LITTLE DOOR THAT YOU PULL OPEN.
LOOK IN THE OWNERS MANUAL.
OR DOWNLOAD THE MANUAL ONLINE AT LG.COM
UNDER THESE CIRCUMSTANCES YOU WILL NEED TO CALL SERVICE . SORRY!!
Here is a good service that I recommend to my customers,
in our 65 year old appliance business!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS.PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OUT!
Posted on Aug 26, 2008
BIKER T
  • 909 Answers
SOURCE: Filter bypass for lsc26905TT
locate water filter bracket(normally in fridge compartment), then use screwdriver to remove from the frame. You will see two plastic pipes connected to this bracket. one will be water in and the other water out. pull the two off the bracket and join them together. (be inventive). Connect your RO system to the main inlet after original water supply is removed. Remember, your "filter to be replaced" light will still flash after a period as the fridge has its own software, counting depressions for cartridge replacement. (you would painstakingly have to reset.}
Posted on Jan 30, 2009
  • 25 Answers
SOURCE: Water line connectors/tubing? GE Monogram Refrigerator
go to your local appliance parts dealer , they should be able to get the parts you need
Posted on May 21, 2009
Fisher Paykel GWL11- US Washer
- Motor control module fault:
Fisher and Paykel washing machine error 1:
Primary Source: Motor control module.
Action: Replace motor control module.
3 - Motor control module fault:
Fisher and Paykel washing machine error 3:
9 - Size setting fault:
Fisher and Paykel washing machine error 9:
Action: Reset machine size as per service manual instructions. If fault repeats replace Motor control module.
10 - Temperature Sensor (Thermistor) Error:
Fisher and Paykel washing machine error 10:
Primary Source: Thermistor.
Action: Replace Thermistor.
11 - Pressure Sensor Fault:
Fisher and Paykel washing machine error 11:
Primary Source: Pressure Tube.
Action: 1 - Empty all water from the machine. Remove pressure tube from pressure sensor, clear pressure tube of any water and reconnect tube (blow down the tube is necessary). 2 - If fault repeats, replace Motor Control Module.
12 - Flood Protection Error:
Fisher and Paykel washing machine error 12:
Primary Source: Water Valves.
Action: If the water valves are on continuously, check that the water valves turn off mechanically by disconnecting power to the machine.
Secondary Source: Pump System.
Action: Check pump for blockage and drain hose for correct height(end not immersed in water) or kinked.
Tertiary Source: motor control module.
Action: If water valves are been driven on electrically, replace motor control module.
36 - Water Leak Fault:
Fisher and Paykel washing machine error 36:
Motor control module has needed to top up the water level more than 4 times during wash/rinse cycle. Most likely cause is waster siphoning out or the machine has developed a leak.
Primary Source: Drainage system.
Action: Check that the hose is not less than 850mm from the ground
Secondary Source: Pressure tube.
Action: Make sure the pressure tube is fitted correctly and doesnt have any holes.
37 - Blocked pump:
Fisher and Paykel washing machine error 37:
Primary Source: Drain System.
Action:
1. Check that the drain hose has not been kinked.
2. Check the length of the hose. 1m is maximum extension.
3. Check drain pump winding for open circuit.(Note: Pumps are fitted with a thermal cut out and will reset after cooling)
4. Check for physical blockage to pump and hoses.
38 - Pressure Sensor Fault(empty reading during wash cycle):
Fisher and Paykel washing machine error 38:
Primary Source: Pressure tube.
Action: Check if tube is fitted correctly, check for blockages or holes in the pressure tube.
Secondary Source: Motor Control Module
Action: Replace the module.
39 - Pressure Tube Fault:
Fisher and Paykel washing machine error 39:
Same as fault 38.
40 - Bowl Dis-engage Fault:
Fisher and Paykel washing machine error 40:
Primary Source: Mechanical.
Action:
1. Check that there are no clothes or other foreign objects preventing the clutch from re-engaging. Excessive suds can also stop the bowl rotating.
2. Check the clutch splines for physical damage.
3. Check that the pressure tube has not come off, kinked or blocked(blow down the tube.
Secondary Source: Motor Control Board.
Action: Change Board.
43 - Out Of Balance Switch Fault:
Fisher and Paykel washing machine error 43:
Motor control module has found that signal returning from the out of balance switch indicates that the switch is permanently on or the harness to it is disconnected.
Action:
1. Check the level of the machine.
2. Check wiring to the switch.
3. Check switch for continuity and corrosion.
44 - Water in Bowl During Spin:
Fisher and Paykel washing machine error 44:
Primary Source: Drain system.
Action: Check for blockages/kinks in drain hose and function of the drain pump.
48 - Hot and Cold Inlet Valve Incorrect Signal:
Fisher and Paykel washing machine error 48:
Primary Source: Wiring.
Action: Check the wiring.
Secondary Source: Inlet Valves.
Action: Check the resistance of the coils.
Tertiary Source: Motor Control Module.
Action: Change Module.
49 - Cold Water Inlet Valve Faulty:
Fisher and Paykel washing machine error 49:
Action: See fault 48.
50 - Hot Water Inlet Valve Faulty:
Fisher and Paykel washing machine error 50:
51 - Diverter Valve Fault:
Fisher and Paykel washing machine error 51:
Primary Source: Blocked diverter valve.
Action: Check for foreign objects in the valve.
Secondary Source: Motor Control Module & Diverter Valve
Action: Plug the machine into the power point but off at the control panel. Check voltage on the plugs at the diverter valve. If voltage around 230V, change diverter valve and motor control module
Oct 07, 2016 | Fisher and Paykel Washing Machines
How do I disconnect the plumbed water to my Fisher & Paykel fridge?
Shut the water down and disconnect water line behind your fridge and remove your fridge
Jan 11, 2015 | Fisher and Paykel Refrigerators
My 3mth old e522brxu fisher and paykel ice maker has stopped working water is working fine you can manually force a dump and hear the cycle start to turn the tray but no water fills the tray can not hear a...
Hi, For the benefit of anyone doing a Google search for it (which is likely anyone with a Fisher and Paykel fridge w/icemaker) the broken wire is a notorious design flaw, and if you see it dangling from your ice tray - symptom is no ice being made -
You must remove the clip underneath the ice tray, and a little foam pad with it. There you will see the broken wire attached to a little black sensor. It's a little fiddly to do in place, but after unplugging the fridge (unless you like a good electric jolt) you need to splice the wire and reattach it. Your ice maker should resume working as intended.
Hope that helped.
Good luck.
May 26, 2011 | Fisher and Paykel E522BRXU Fisher & Paykel...
Just bought a fisher & Paykel f/f. Filtered water tastes bad. any ideas?
See what happens when you have run a couple of dozen tumblers of water through it to flush it out. It is not a common problem as far as I am aware.
Dec 02, 2010 | Fisher and Paykel Refrigerators
My washing machine is beeping and is full of water, I am trying to wash a load of clothes. Used it yesterday and it worked great.
Water level sensor not sensing. Check the small tube that connected to switch. switch off power. Remove the tube and refix.
Mar 31, 2010 | Fisher and Paykel Fisher & Paykel Washer
U 3 in red on fisher paykel single draw dishwasher
These are the cause of this fault
Drain pump is blocked.
· Drain hose is blocked.
· Sprayarm or rotor not turning
freely.
· Motor electronics have failed.
· Machine set to 'LP' on a high
pressure water supply.
Mar 03, 2009 | Fisher and Paykel Active Smart® E522BR...
Ice maker stopped
is the ice collection bin in the correct position? Is the icon displayed on the control panel to indicate the ice maker is on?
I hope this helps,
Aug 12, 2008 | Fisher and Paykel Active Smart® E522BR...
Fisher and Paykel fridge buttom freezer with water dispenser
Please advise where the dispenser is leaking? If it is dripping out the front of the door, then I suggest you run the water dispenser to flush about 3 liters of water. Does the noise stop when you open the fridge door?
Jul 01, 2008 | Fisher and Paykel Active Smart® E522BR...
Fisher and paykel water leak
Code F1 indicates that Flood switch has been
activated which explain why you feel that it is overfilling.
Water leaking
Drain hose disconnected
from waste pipe.
Reconnect the drain hose to the waste pipe.
Supply inlet hose not
properly connected.
Ensure the inlet hose is connected securely.
Other leaks. Turn water and power supplies to the
Dishwaher off.
Mar 30, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Refrigerators Logo
69 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
John Tripp
John Tripp
Colin Stickland
Colin Stickland
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
