Question about Plumbing
I just installed a new Shelton Pfister pull out kitchen faucet that whistles when turned on. How do I remove the flow restrictor?
    New Friend:
  • 102 Answers
At the end of the faucet you should be able to unscrew it to take it off
Posted on May 14, 2014
2 Suggested Answers
  • 409 Answers
SOURCE: I installed a Price Pfister kitchen faucet model low water pressu
yes it should have a flow restrictor in the end of the spout. You might need to clean it out
Posted on Mar 11, 2010
Price pfister ashfield f-529-myp
leave the screen out something is restricting the flow at the screen or take guts out of aerator and keep screen some have flow restrictors that may get clogged usually a plastic disk
Aug 29, 2014 | Pfister F-529-MYPS Ashfield Pullout Spray...
I don't think it is the flow restrictor. I am guessing your water pressure is on too high. That would cause the whistling.
Elisa Jed ' http://www.kookaburrakitchens.com
May 14, 2014 | Plumbing
How to disconnect the quick connect spray hose in a Price Pfister Parisa
I also needed to remove the "hidden" flow restricters from my Price Pfister Parisa Kitchen Pull out faucet. The hot water side had never flowed the same as the cold side. Now both sides are flowing the same as should have been all along.
Nov 30, 2012 | Price Pfister Marielle Kitchen Faucet with...
Faucet dripping
Call Price Pfister at 1-800-PFAUCET and ask them to send you a new hot and cold stem for free. These faucets are easy to repair. Here is the parts breakdown for your faucet. Turn the water supply of to the faucet. Remove the index button from the top of each handle. Unscrew the handle retaining screw. Pull the handle off. Unscrew the stems with an adjustable wrench; turn them counterclockwise. Install the new stems and reinstall the hanldes; it may take a couple of times to get them set in just the right positions. Slowly turn the water back on and open the faucet.
Sep 05, 2010 | Price Pfister Savannah Two-Handle Kitchen...
I installed Series 26 Avalon faucet. The water flow rate is very slow. All fittings to the faucet are new. Could the problem be a faulty valve ?
Remove and clean the Price Pfister aerator. Turn the water on after you remove the aerator and check the flow-rate. Many new Lavatory and kitchen faucets are now equipped with Eco friendly water saver aerators. if the flow is normal without the aerator, the faucet is OK. if you want more water flow from your lavatory faucet, you will need to buy one of the old style high flow aerators from your hardware store. If you remove the aerator and still get low pressure from both hot and cold faucets, you may need to replace the faucet. Call the Price Pfister warranty phone number that came with your faucet.
Aug 28, 2010 | Price Pfister Plumbing
Mar 08, 2010 | Plumbing
Installed a new price pfister two knob kitchen faucet and the cold faucet turns off backwards. How do I make it shut off in the right direction ? Thanks !
you will have to remove the faucets and turn the base around, that is the only way to make it right you installed them backwards
Jun 28, 2009 | Price Pfister Savannah Two-Handle Kitchen...
Kitchen faucet leaking pull down sprayer spout type
try tightening the nut that attaches the flex line to the pull out spout
May 04, 2009 | Price Pfister J103-BC 100 Series Kitchen...
Handle on faucet shuts off on its own
I had the same problem. The Price Pfister web site recommends removing the handle (unscrew the dome cap, then remove the phillips screw to get the handle off) then tightening the retaining ring (I used channel lock pliers on largest setting. It worked. However the retaining ring is plastic on some models, and they recommend replacing it with a brass one. I haven't taken that step yet, we'll see how it goes (mine is plastic).
Dec 01, 2008 | Price Pfister Marielle Kitchen Faucet with...
Plumbing Logo
71 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
