Maytage la610 - Newton - old style counterweight transmission (mfgd.1981)
On starting agitation cycle after sitting idle for 24 hours, machine struggles to turn agitator and a low pitch growl can be heard near base of agitator. After manually helping turn agitator a few times, growling stops and agitator turns without hesitation. No further hesitation occurs unless machine is left idle for 24 hours or more, then same struggle to start agitation happens again. Drive belts and tension adjustment tested OK. Brake package and drive lug tested and working/adjusted correctly. Machine spin cycle functions properly and noiselessly suggesting that tub and radial bearings are OK. Is this likely a transmission starting to fail or could there be another cause? Thanks in advance for your help. Reply to: "krischler@q.com"
    New Friend:
  • 23 Answers
It is possible that the motor may be on it's way out. You might check to see if it has a start capacitor on it that may be getting weak and possibly by pushing the agitator takes the initial load off of the motor. Just a thought.
Posted on May 16, 2014
  • 11 Answers
SOURCE: Agitator not working on Maytag PAV2300
Sorry to be the bearer of bad news, but the transmission in your unit is bad,it has internal gears and the ones involved in the agitation are broke or bad, to replace the transmision is a lengthy process, your best bet is to just scrap it and get a new washer. I don't know if you know this but maytag company is no longer in business. They were purchased by Whirlpool back in November of 2006. One of the reasons is all the poor quality of their appliances. I am a technician that has been doing this for 15 years. The best unit I have seen to date is the Whirlpool Duet. I hardly ever have to work on them. Sorry for the bad news. Hope this helps.
Posted on May 20, 2007
SOURCE: Maytag won't spin or agitate
I have had the same problem and found that the teeth on the under side of the agitator had been worn down to nothing... I assume this is from years of over loading (not from me) and so the agitator could not spin any more... i would tighten the bolt that holds th agitator on and it would come loose after a few loads. So my solution was to get a little bit longer bolt and newer plastic washer and tighten it as tight as i could and it seemed to work. Versus buying a new agitator base that would cost about $20-$30 and would have to wait for the part to be ordered. hope this helps
Posted on Oct 23, 2007
  • 530 Answers
SOURCE: How to adjust new belt on maytag washing
sounds like you have a bad transmission. can you lift the top up so you can see what it is doing when it is trying to spin. does it adgetate and spin at the same time? If yes you have a bad transmission. also if you get 2 people one looking inside of the drum and the other turning the big pulley in one direction it should turn the whole drum in the other the agetator should go back and forth. Tell me what happens thanks.
Posted on Jun 10, 2009
TheMobilian
  • 8220 Answers
SOURCE: Kenmore 90 tub spins excessively clockwise during wash cycle.
Improperly installed thrust bearing kit. Too many washers cause the basket to spin during agitation.
Posted on Jan 04, 2010
Testimonial: "Where is the "thrust bearing kit" and how can it be installed properly?"
  • 6 Answers
SOURCE: agitator doesn't move and machine makes a loud
I think washer transmission GONE!
Posted on May 17, 2010
Maytag Model LA610 - Newton - old style counterweight transmission (mfgd.1981)
check motor coupler, agitator spindle, drive block and shaft, cam dogs and motor windings
Mar 23, 2017 | Washing Machines
Maytag Washing Machine Model SAV205DAWW not agitating
The transmission is broken on the inside due to Maytag using plastic gears. Designed to break with age and overloading abuse.
It's a pain to replace and expensive, too. Average repair cost $300. and 2 hours + labor
Feb 07, 2014 | Washing Machines
No agitation on extra rinse cycle on Maytag Washing Machine MAV8557AWW
The manufacturer may have found there was little or no advantage to having agitation in the second rinse cycle so omitted it.
Jan 08, 2014 | Maytag Ensignia MAV2757AWW Top Load Washer
Need info about extra rinse cycye
there should be agitation..dont know unless its not making the connection in the control head..
Maytag washer will not agitate
A Maytag A412 is well over 20 years old....
Best guess is a corroded upper drive shaft, the one that the agitator is mounted on. Certainly it can be called a transmission problem.
Jun 28, 2017 | Maytag Washing Machines
Maytag washer mavt546eww..will not get up to full speed
Hi, this is transmission failure. the clutch has been damaged. I recommend replacing the transmission and agitator assembly as well.
Jun 24, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Washer fills and agitates will start to pump and spin then stops let sit for a few minutes and it will try to spin again replaced both belts this is a maytag top loading about 8 yrs old
Either the program switch or the transmission has failed. The transmission is probably a lousy Whirlpool part and have had them fail in only a few years of light service. To eliminate the program switch, use a different cycle setting to see if it can complete any of those available. If not, then it's probably the transmission.
Jun 13, 2009 | Maytag PAV2300 Top Load Washer
Agatator problem
being a maytag about 30 years old i would say the belt is broke or transmission is locked up ,,,, if it was a newer style you may have difference problem that could be easier repaired
Dec 08, 2008 | Maytag Atlantis MAV6000 Top Load Washer
I own a Maytag Performa 4 Speed/24 cycle Washing machine. it is 4 years old. Problem: A very LOUD grinding sound when washer engages into wash, rinse, spin cycles. The Tub does agitate - but I don't...
sounds like you have a tub seal problem, which took out the bearings, I take it one buzy mom does lots of laundry! Maybe time for a new washer.
Jul 11, 2008 | Maytag Washing Machines
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
