Question about Whirlpool Washing Machines
A whrilpool accdry that dont dry
It run the full cycle but dont dry cloth check plugs and fuse in the house had it for two and it work just find dont know what else two check
    New Friend:
  • 102 Answers
Maybe your circuit breaker is only using 120 volts, check it by shutting off the breaker then turning it back on. Its a 220 breaker double pole and one side might have tripped. If not that it is possible that the internal fuse shut the heating element because it got too hot. Check to see if the system is clogged with lint by taking the back off the dryer and then the unit that the hose is connected to should be taken apart and cleaned. Then there is an inline fuse if it is blown you have to get a new one
.Always make sure you unplug or turn the breaker off before doing any work on it and if not sure get a professional to fix it.
Posted on May 14, 2014
Frigidaire dryer heating up but not completing cycle.
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Apr 07, 2015 | Frigidaire Dryers
Fuse box location
there are several things to check. cycling thermostat and hi-lo limit fuses, see if full voltage 240 and not just 120 is coming out of house outlet and into the terminal block at machine. because if u only get 120 u have enough to run the motor but not the heater? lastly u will want to check heating element as it may be bad
May 20, 2014 | Samsung Dryers
Why my Whrilpool Drier AWZ 555 is not drying the clothes and power light is blinking?
Check to make sure it's getting full 240vac power. Some or most driers are fed from two breakers in the box. If one is tripped you aren't getting enough power. That could be causing the blinking light. Also check for enough exhaust flow to prevent overheating.
May 18, 2014 | Whirlpool Dryers
My dryer does not dry my clothes completely at one cycle, it takes at least three cycles of drying to get the clothes dry all the way. help
Hi sandygann
Here are a few things to check:
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or inside of the dryer venting system,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the heating element/thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if you do not read continuity you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor/thermal fuse one at a time by removing the two wires and taping them together with electrical tape.
Try to run the dryer, if it runs and heats up then replace the thermal fuse/thermistor/thermostat.
If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse,then you do not have to tape the wires together as described above.
But do not trust the ohm meter all the time, because sometimes it will give a false positive that the fuse is ok when in reality it is faulty.
DO THE FOLLOWING TEST:
To test your thermostat/thermistor/thermal fuse remove the wires from the thermostat/thermistor/thermal fuse and check the fuse/thermostat,thermistor for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST AS THIS COULD CAUSE A FIRE BECAUSE YOU HAVE REMOVED THE SAFETY.
This test of the thermal fuses,thermistor,thermostat, will show if the thermal fuse,thermostat,thermister is really faulty or not.
Check your blower wheel to make sure it is secure to the shaft and not plugged with lint,socks,etc. If you have to replace your blower wheel it will remove clockwise as looking at the blower wheel. You will have to hold the belt end of the motor with a vise grip pliers or maybe the shaft of the motor has a notch cut on it for a wrench to fit.
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset.
You can test it with an Ohm meter or continuity checker, remove both wires from the thermal fuse and put the test probes to each of the ends of the thermal fuse, if no continuity then replace the thermal fuse.
If you do not have a volt/ohm meter then:
DO THE FOLLOWING: Remove the wires and tape them together and try to start the dryer.If the dryer starts then replace the fuse.
A vent clogged with lint can cause it to overheat.
Right after replacing a dryer element, always run the dryer on air fluff/no heat, and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace a generic element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
Please take time to rate me
Bud
Apr 01, 2013 | Whirlpool Dryers
Drier takes several run times to dry clothes
Hello.
When your dryer heats yet gives very poor drying results its usually always poor air flow that's causing it to take forever to dry the clothing.
To check to see why it has poor airflow the first thing to check is for a blocked or restricted vent tube from the back of the dryer all the way to where it exits the house. Also in some case lint is built up in the blower wheel/lint filter housing and that housing would need to taken apart and clean all the lint from it.
GENE
Oct 13, 2011 | Kenmore Elite HE4 Electric Dryer
I have a kenmore dryer 80 series it only makes a lite sound when I push the start button. I won't come on. The power is good.
The Kenmore 80 Series of dryers are consumer grade dryers for home use. As with most home appliances, the Kenmore 80 series dryers will occasionally not work as intended. If a problem occurs with your dryer, however, you do not necessarily need it serviced by a technician. You can attempt to troubleshoot and fix any problems with your dryer before contacting a technician.
  1. Kenmore 80 Series dryers may not run for several reasons. First, make sure that the power cord is plugged into a working power outlet. You may need to plug a different device into the outlet to check that it is receiving power. If the second device does not run on the power outlet, you may have blown a fuse or tripped a circuit breaker. Check your fuse box or circuit breaker box and make the change as needed.
    Next, make sure that the dryer door is fully shut. The dryer will not run with the door ajar.
    Finally, check that the "Start" button was fully pressed and that a cycle was chosen on the machine. If you do not choose a cycle for the dryer, it will not run.
  2. If your Kenmore 80 Series dryer does not heat up during use, check that a heat cycle has been chosen for the load. There are several different dryer cycles you can choose, some of which do not use heat. Make sure that you have chosen a heated cycle.
    As above, check that you have not blown a fuse or tripped a circuit breaker. The dryer may use more than one fuse or breaker: one is used to power the drum, and the other for the heating element. Make sure that both fuses or breakers are in working order.
  3. There may be times when Kenmore Series 80 dryers do not fully dry your clothes. When this occurs, check the lint screen and clear out any lint. The air may not flow as well if the lint screen is clogged.
    Next, check to see if the exhaust vent is clogged. Lint and other particles may clog the exhaust vent over time, restricting air flow and making it more difficult to dry your clothes. To check the vent, run the dryer and hold your hand under the vent. If you do not feel any air flow, clean or replace the vent.
    If you used cold water to rinse the clothes it may take longer than normal to dry. The same is true if the load of laundry is very wet or is filled with items that are very absorbent.
    Finally, check the load size. The more clothes in the load the longer it will take to dry. If you want to reduce drying time, separate the clothes into piles of light and heavy items and dry them separately.
  4. please comment on these solution by saying how helpful.
Dec 22, 2010 | Kenmore Dryers
Whirlpool dryer, it takes 2 or 3 cycles to dry a full load, the clothes are warm and when I disconnect the rear exhaust and turn it on it blows pretty good, it never took so long to dry the clothes
check the vent hose to the outside,especially if there's been siding installed on the house and the vent has one of those plastic guards by the outside exhaust,for keeping birds out,this can plug around the vent and build up with wet lint,run it without the hose on and see if drying time comes down to normal again,then you know the outside vent is the problem
Jan 26, 2010 | Dryers
My electric dryer is becoming extremely hot during the drying cycle. I replaced a blown thermal fuse several weeks ago and the dryer was extremely hot at that time. The dryer runs but becomes so hot you...
Clothes will get very hot in the dry cycle, especially when the dryer is set to the warmest or hottest setting.
There are controls built into the unit to prevent it from overheating to the point of causing a fire. The thermal fuse you replaced is one of them (and I assume you replaced a perfectly good fuse with a new one as you said it was very hot.).
You might want to check the following if you feel the unit is getting too hot -
1) Make sure the lint screen is clean.
2) Make sure the hose between the back of the dryer and the exhaust duct at the wall wall is not kinked or full of lint.
3) Make sure the exhaust duct leading to outside of the house is clear and not full of lint.
Let me know what you find.
Dec 14, 2009 | Kenmore 62602 Electric Dryer
2 to 3 cycles to fully dry clothes
if the clothes are warm after the cycle then you need to make sure the vent to the outside of the house is not plugged if they are not warm then it is in the heating circuit of the dryer wether it be the element or a fuse will have to be tested. to dry clothes it takes heat and air flow if you dont have one of the two they will not dry correctly
May 18, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
Clothes Arent Drying
Try running a load without the venting connected. Your venting may be plugged. If that isn't it, check the heat element. Inspect it for a break. It may heat partially if it is broken and touching the housing. Hope this helps!
Feb 08, 2009 | Kenmore Dryers
Washing Machines Logo
Dan Webster
Dan Webster
Sal DeAngelo
