Question about Little Giant APCP-1700 Swimming Pool Cover Pump Automatic
There is power to the pump, but the pump will not come on. It has a pressure switch, the contacts are making contact, but the motor doesn't run. what should i check for?
    Problem Solver:
  • 11 Answers
Some of these pumps are designed to shut off when there is no water. It will either sense the water or the pressure against the impeller when it tries to pump. Make sure that you aren't running it dry.
Posted on Aug 03, 2009
  • 28 Answers
Sometimes around the area of the motor there is a little button that is usually red that is made to "trip" if the pump got hot or overloaded. Push this button back in to reset if it has on. Most pumps have this button to keep them from burning up if overloaded.
Posted on Jun 24, 2009
Well pump won't come on
If there is power to the pressure switch and the motor is not warm from trying to run its Most likely the contact points on the pressure switch are not making contact, make sure power is off and use 400 grit sand paper folded and lift the contact point and insert the paper and allow the Spring pressure to clamp down and pull the sand paper out, do this several times to all the contact points. Hope this helps
Dec 13, 2017 | Refrigerators
WHY DOES MY BOILER PUMP CONSTANTLY RUN
there is usually a pressure switch this may be an indication of the relay switch not opening and closing properly....shut off power then remove the protective cover (usually on top of motor) inspect the relay contacts they may have some burn marks take an emerey cloth or fine sand paper and slide between contacts hope that works
Aug 02, 2014 | Grundfos Pumps Grunfos UP15-42F 1/25 HP...
Why top loader washing machine drain motor spins all the time?
the problem is in the program board still supplying power to the pump motor
Dec 15, 2017 | Washing Machines
Pressure switch no longer making contact
First try to clean the contact points, maybe it's help
Mar 26, 2013 | Flotec Pressure Switch 40/60 TC2153
Motor doesn't shut off once it reaches its maximum pressure level. It continues to run until it is unplugged, whether it needs to refill or not.
Does this unit have a magnetic starter or just the pressure switch?Here are a few items I would check. Make sure power is unplugged. 1 - If it has a magnetic starter remove the box cover. you are checking the starter to see it has stuck closed. In the center of the starter should be what appears to be an indentation. use a screwdriver and push in on it. If it moves in and out freely it's OK. If it will not move you've found your problem.replace starter. 2 - Check the wiring to the starter. Black wire from motor should be on left bottom on overload. White motor wire should be on right bottom of starter. Incoming power should be located on top of starter left and right side. NO Starter, pressure switch only. 1 - Remove pressure switch cover. Inspect pressure switch contacts to see if they are open or closed. If contacts are open move on to wiring inspection.If closed drain all air out of tank. while draining air watch pressure switch contacts depending on pressure switch setting contacts should open around 130 - 135 psi. if all air drains out of tank and contacts do not open use a small screw driver and gently open contacts. They probably welded themselves together. If this is your problem I would get some new contacts. 2 - inspect wiring, left side of switch should have one wire from incoming power on top screw and motor wire on bottom screw. Right side of switch should have one wire from incoming power on top screw and motor wire on bottom screw. Good luck.
Sep 09, 2011 | Ingersoll Rand - Rand Type - 30...
I have a Craftsman compressor Model # 919-15292 2. The compressor stopped building pressure because air was continually being released through the unloader valve. I have replaced the unloader valve,...
you must have wired the new pressure switch incorrectly .when the pressure switch opens it will release the head pressure so your compressor must be running with the pressure switch contacts open should be 4 connections 2 marked motor which is from your compressor and 2 marked line which is your power coming in
Jun 15, 2011 | Craftsman 33 gal Air Compressor 6 hp...
Air compresor Craftsman 921.153101 it spound like is one but it wont run at all. It sounds like the motor is stuck
if its belt driven ,unplug it(safety first)remove the belt and try to turn the pump by hand.if the pump turn plug it back without the belt. and try it .if the motor doesnt run.check the contacts on your pressure switch.if they are ok and try again.if not you need a new motor.if the motor ,the pressure switch contacts,and the pump are fine.put the belt back back on bleed your tank to zero with an air gun and try to run it.if it work well till it cuts of check if your bleeder release air.you might have pressure stuck in your pump.the compressor needs to release pressure for a soft start.hope this help!
Apr 17, 2011 | Craftsman 3 gal. Air Compressor, 1 hp,...
I just installed a new booster pump for Polaris 280. It runs hot and it doesn;t seem to have enough pressure to make the sweep run. Any suggestions
Thank you for posting your question here on Fixya.com.
When you installed it were you careful to set the motor to the correct incoming line voltage? If not and you are powering it with 115V you probably didn't reset the motor for 115 from 230...factory set motors come out for 230 V. A motor set for 230 but running on 115 will be very hot and over time will begin to cycle its overload. The performance will be poor until corrected. Look for a dial in the terminal area or wires to be reconfigured. Directions for how to set the motor voltage should be found on the motor nameplate.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
Mar 06, 2011 | Polaris Pb4 - 60 Booster Pump
Hayward Pump Motor low pressure...
The "points" you are talking about sound like the contacts. These are closed for starting and open when the shaft turns at a set rate to change to "run" mode. They are not adjustable. Underneath the contacts is a small part with 2 springs that moved when the motor starts turning. This whole assembly is a centrifugal switch. I would take the assembly apart and re-install it. Make sure the "bracket" is seated correctly on the shaft. The motor shaft end is grooved so the "bracket fits tight. When installing the contact assembly, make sure the contacts rest DIRECLTY centered over the tab in the middle of the "bracket". Its a bit of a job, but if you are mecanically inclined, should be no problem.... Good luck...
Jul 17, 2010 | Hayward 1hp Power Flo Matrix Above Ground...
Little Giant APCP-1700 Swimming Pool Cover Pump Automatic Logo
835 people viewed this question
Top Little Giant Garden Experts
Jim Goldsmith
Jim Goldsmith
Mike Squire
john h
Are you a Little Giant Garden Expert? Answer questions, earn points and help others
