Question about Microwave Ovens
How do I make sure that my fire alarm doesn't go off when I'm cooking
    Problem Solver:
  • 16 Answers
Take the battery out... just remember to put it back in. if it connected to your cuircut breaker box, you'll need to flip the switch to off\orange depending on what type of CB box you have.
Posted on May 14, 2014
Kenmore microwave recall
Call Sears and complain. Visit the Consumer product Safety Commission website. Between the two you should get all the info you need.
Jul 16, 2014 | Kenmore Elite Microwave, Model...
Microwave not working
see this causes and fix it. God bless you
If the microwave will not work at all, make sure power is on at the outlet and test the electrical cord. Test the fuse and replace it if it is faulty. Also check the door to make sure it closes properly. Test and, if needed, replace the fan.
If the oven doesn't cook or cooks only intermittently but the display is on, check the door interlock switch, the thermal cutout , and the fan replacing parts that don't pass the test.
Oct 16, 2012 | Kenmore Microwave Ovens
Micrwave not working
If the oven doesn't cook or cooks only intermittently but the display is on, check the door interlock switch, the thermal cutout and the fan, replacing parts that don't pass the test.
Oct 16, 2012 | Microwave Ovens
Advantium 120 not working
If the oven doesn't cook or cooks only intermittently but the display is on, check the door interlock switch, the thermal cutout, and the fan, replacing parts that don't pass the test.
Oct 15, 2012 | Maytag MMV1153A Microwave Oven
Sharp convection microwave oven model R1875F. It's cooking on the left side faster then the rest of the oven. It seems to burn on the left side and not cook in the middle.
see the next causes. God bless you
Diode The high voltage diode converts the A/C power output of the transformer to D/C, doubling the voltage to nearly 5,000 volts. This high voltage powers the magnetron which emits the energy that cooks the food. If the diode burns out, a lower A/C voltage reaches the magnetron, which is not sufficient to power the magnetron. When the diode fails it is often visibly burned out. If it appears to be good, it can be tested with a volt-Ohm meter capable of testing diodes. High voltage diodes frequently fail and are one of the most common points of failure in a microwave oven.
Door Switch If the microwave does not heat, one of the door switches might be defective. Microwave ovens normally have three door switches, if any of them fail the microwave does not turn on and does not heat. Check the switches for continuity with an Ohm meter.
Magnetron If the microwave oven doesn't heat the magnetron tube might have burned out. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. If the microwave oven is turned on when it is empty this can cause the magnetron to burn out. Once it is burned out it has to be replaced, it's not repairable.
High Voltage Capacitor If the microwave doesn't heat the high voltage capacitor might be defective. The high voltage capacitor works with the high voltage diode to convert the output of the transformer to DC voltage and to double the output voltage. If the capacitor is burned out the entire high voltage circuit stops working properly. The high voltage capacitor can be checked with a special VOM meter which has a capacitance testing capability. Be aware that the high voltage capacitor can retain a charge of more than 3,000 volts and can injure or kill a person if not handled properly. Only trained technicians should perform this type of testing.
High Voltage Transformer If the microwave does not heat, the high voltage transformer might be burned out. Microwave ovens produce a very high voltage in order to power the magnetron antenna, which emits the energy that cooks the food.
Thermal Fuse If the microwave doesn't heat the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Thermoprotector If the microwave doesn't heat the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.
Main Control Board If the microwave doesn't heat the main control board may be defective. This is not common. When a microwave doesn't heat the problem is usually within the high voltage circuit; either the high voltage capacitor, diode, transformer or magnetron.
Oct 03, 2012 | Sharp R-1870 Convection/Microwave Oven
Why it's not functioning?
God bless you
f the microwave will not work at all, make sure power is on at the outlet and test the electrical cord. Test the fuse and replace it if it is faulty. Also check the door to make sure it closes properly. Test and, if needed, replace the fan. If the oven doesn't cook or cooks only intermittently but the display is on, check the door interlock switch, the thermal cutout (see the Applaince Controls Fix-It Guide), and the fan, replacing parts that don't pass the test.
If the oven keeps blowing fuses, check for a faulty door interlock or monitor switch.
Oct 02, 2012 | Microwave Ovens
R-820js wont heat
see this causes and fix it .God bless you
Oct 02, 2012 | Sharp R820JS 900 Watts Convection ...
Last 2 times food cooked in microwave caught fire why?
Make sure the oven is clean and that the wave guide is not damaged or dirty. It's a heavy paper like thing on the wall that can deteriorate or get dirty and cause fire.
Dec 16, 2010 | GE Microwave Ovens
Potato caught fire during cooking. Microwave has
Hello, inside most microwaves, there is a thermal fuse, that if something in the cooking cavity is on fire, it will melt the thermal fuse, if it gets hot enough, thus breaking the power to the unit shutting it off. This sounds like what has happened to yours, simply replacing it will correct the problem. It is usually located near a cavity exhaust point. If you aren't comfortable doing this, as it requires removing the outer cover, while unplugged, and locating/replacing it, take it to a appliance service co. This will of course cost more, if you do it yourself, make sure you provide all of your make/model/serial/anything else, that will identify your unit, and call/go online to a parts retailer, and you should be able to get it done fairly cheap.
Hope this helps, and thank you.
Mar 01, 2009 | Microwave Ovens
Decor DMO2420 Microwave caught on fire
Please write back with more details if this reply doesn't solve it.
(Such as, Was the fire inside the cooking cavity? Has the inside been cleaned since?)
There is a cavity temperature fuse located under the outer cover, on the top left side of the cooking cavity. It is rated at 150 degrees centigrade.
If there is a fire, that will open, killing all power to the unit.
A replacement can be found at a local appliance parts company.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 29, 2008 | Microwave Ovens
Microwave Ovens Logo
22 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
