I have a HEC air conditioner were the tempurature reac is it says E1.and the air conditionoer will not go on?
  • 23 Answers
SOURCE: reset air conditioner
Unplug it. Wait a few minutes. Hold in the Power button while plugging it back in and keep the button held down until a beep is heard (~5 sec). Unplug the air conditioner, then plug it in again.
Note: some units require using the Mode switch, rather than Power.
Posted on Jun 15, 2008
SOURCE: Code E1 on my Samsung AW1204B Air Conditioner
Found this on Samsungs site.Hope it helps a little, at least you know the problem now.
If your air conditioner displays E1 in the display panel and won't turn on, it means that the Room Thermistor (a device connected to the thermostat that detects room temperature) is shorted or defective, and you need to have your air conditioner serviced.
If it displays E2, E3, or any other E error, you also need to have your air conditioner serviced.
To arrange for service, contact Samsung Customer Care at 1-800-Samsung (1-800-726-7864). Have the model number of your air conditioner on hand when you call.
Posted on Jul 09, 2008
Krazytech
  • 725 Answers
SOURCE: E1 code flashing on my air conditioner
E1 indicates that it is time to clean the air
filter hope it helps
Posted on Jul 26, 2008
  • 491 Answers
SOURCE: air conditioner has to be reset --E1
If your a/c unit is portable,and E1 code most always is "air filter cleaning time" or" water level to high ".
To reset air filter interval turn unit off at power switch then unplug.Hold power switch down while plugging in....unit will go through a short self check then beep.Release power button after beep.Unit should now be reset.
To reset water level....just drain some.....not all.
Most portables use water for increase cooling......so leave some in.
Posted on Aug 11, 2009
SOURCE: Have a ge model ASW12ALS1 Air conditioner with error code E1
What does the EP light mean on a GE air conditioner when it. stays on and the unit stpps cooling.
Posted on Aug 25, 2011
My air conditioner showing on the display is E1
The E1 Error Code The most common reason for an E1 error code to be displayed on your air conditioner's front panel is to remind you that the unit's air filter needs to be cleaned. Many models will automatically notify you of this via an E1 error code display after the unit has been operated for a predetermined number of hours. For example, many Sharp models will display an E1 code after 720 hours of use. Alternatively, you could have dirt or moisture in your front button controls, causing them to stick or not function properly. This can be a common problem with many models of Haier air conditioners, but the issue is not restricted to any one manufacturer. Your air conditioner could also have a defective thermistor, which is part of the thermostat.
For Samsung, the room thermistor needs replacing. This is a device that senses the temperature in the room.
How to Fix an Air Conditioner When It Gives You an E1 Code eHow
Jan 24, 2016 | Heating & Cooling
What does E1 code indicate?
Your Air Conditioner Displays E1 (E2, or E3) In The Display ...
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsJul 8, 2010 - Home > Operation? > Your Air Conditioner Displays E1 (E2, or E3) In The Display Panel And Won't Turn On Share on Google+ Share on ...
How To Clear Sharp Air Conditioner E1 "Clean Filter" Error ...
sci.tech-archive.net > Archive > sci.electronics.repair > 2005-08
Aug 5, 2005 - Owners of Sharp air conditioner models ... the error code E1 will appear... following procedure to clear the nefarious E1 indication, and obtain
Oct 27, 2015 | Heating & Cooling
Comfort Control Center 2. Why is E-1 error displayed?
[PDF]Customer assistance for air filters cleaning (E1 code)
www.sharpusa.com/.../air_man_AFS100FX_S120FX_S125F...
Sharp SolarCustomer assistance for air filters cleaning (E1 code) on Sharp Air Conditioners. The display will indicate an E1 code and not allow the unit to operate until the ...
Sep 08, 2015 | Dometic Rooftop RV Air Conditioner
I have mercedes benz 500SL 1991 model and the roof is not opening and closing ...
Sounds like no power or motor. Check the fuse for sunroof fisrt.
Next check for power reacing the switch. Next is power going past the switch to the motor and is the motor grounding?
Sep 28, 2012 | Dometic Rooftop RV Air Conditioner
Turning off code e1 flashing what is e1 code
E1-Automatic filter clean reminder.
Turn the air conditioner OFF and unplug it. NOTE: The air conditioner must be unplugged for the automatic filter clean timer to reset.
Clean the filter. See the Care and Cleaning section in your use&care manual. After cleaning, replace the filter and plug the air conditioner back in.
Jul 28, 2011 | Sharp Comfort Touch AF-R120EX Air...
We have an E1 code on our Sharp energy star model AF-S100FX air conditioner and the unit will shut off. What does the E1 code mean?
Display Codes:
Jul 22, 2011 | Sharp AF-S100FX Comfort Touch Air...
My HEC window airconditioner is displaying an E1 code what is that and what can I do?
Here is a tip that gives a further explanation of that E-1 code. The causes of the E-1 code can be varied depending or the brand of your air conditioner.
Read through this tip... it will help you understand what is happening with your window air conditioning unit and give you some things to try to help you get your problem resolved.
E-1 Code on Window Air Conditioning Units
http://www.fixya.com/support/r5620902-e_1_code_window_air_conditioning_units
heatman101
Aug 23, 2010 | Haier Heating & Cooling
Jul 26, 2008 | Danby DAC8003D Air Conditioner
Heating & Cooling Logo
15 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
