Question about Elna Heirloom Edition 6005
Repair Manual stop for safety purpose
2 Suggested Answers
SOURCE: Stop for Safety Purposes ?
I have had this happen to me many times. It really does feel as though the problem is in the bobbin, but it's not. After much aggrivation I took it into the repair shop and found out the thred was comming unhooked on the top not in the bobbin. It still happens all the time but I know what it is now so I just rethred the top.
Posted on Sep 17, 2008
How do I fix this problem on Elna 6003 which stops working after about 1 min and the computer say stopped for safety.
Hi Gary, I'm Julie. It sounds as though your motor is heating up and then cutting out. Something to try. Clean the machine following the instructions in the user manual. Ensure that the bobbin area is clean. If the motor continues to cut out take your machine to a service centre. One or more parts may need replacing.
Good luck. Kind regards, Julie
Mar 26, 2015 | Elna Sewing Machines
Janome 6600 bobbin will not wind error "stop for safety purposes"
I have a feeling the sensor has been jolted just enough to make it stop. Pretty sure this can be adjusted by the dealer quickly. Worse case scenario, you'll have to replace a sensor.
Feb 25, 2015 | Janome Sewing Machines
Kenmore electronic sewing machine
it's possible that a sensor or computer part of the machine is going bad if the machine has a electronic part to it.
Apr 18, 2014 | Kenmore Sewing Machines
Machine stopped sewing, needle shuddered and quivered, display screen said to stop could be safety issues, looked at manual, said thread jam or needed new needle, i changed needle there were no jams,
then they didn't not fix the machine,, I suggest to take the machine back to them
& tell them how much you don't appricate it's still doing the same thing.
I've heard of this happening before.
Apr 02, 2012 | Janome Memory Craft 3000
My 6003 Elna machine stop and says stop for safety purposes How do I get it unlock from that It wont do anything
This is usually what happens if the bobbin case gets dislodged, its just held in place by a magnet but if you have a jam up, often gets moved out of position. Remove top metal plate, take out bobbin, and have a look at the bobbin case, should be two metal markers or red dotsmfront side that align. Lift the case out by grasping edge and lifting up and towards you, clean underneath with the little brush, remove any jammed up threads, then return case to position, aligning the marks.
Feb 24, 2012 | Elna Sewing Machines
My elna 6005 keeps on stopping ande I get the message stop for safety purposes. I have just had my machine serviced and I really don't know what to do.
Something is not quite right. Double check everything...loose needle, plug ins, threading, bobbin area for loose threads, etc.
Keep in mind that you've jostled the machine moving it from the service to your home. It could be as simple as the bobbin race being out of alignment. If nothing you do works... take it back and give the the person who serviced it the "look." and make him/her fix it.
Mar 13, 2011 | Elna Heirloom Edition 6005
Sep 16, 2008 | Elna Heirloom Edition 6005
Machine will not run
When I have this problem, I turn the knob back and forth (gently) to try to get the needle to release and lift. I get this error message when the needle has shifted (either in the fabric or from using the machine alot at the needle placement shifts).
check your needle, it probably has shifted a bit.
Jun 09, 2008 | Kenmore 19233 Computerized Sewing Machine
Sewing Machines Logo
35 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Derek Massey
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
