Question about HP LaserJet P4014n Printer
What is the setting to have the printer prompt to load media in Tray 1?
Windows 2008 SR2 print server Universal Print Driver PCL 6 (v5.70) HPLJ4014n printer Tray1 Size/Type = Any/Any Tray2 Size/Type = Letter/Plain When submitting a job to print on Legal it pulls letter from tray 2 without any prompting. A few weeks ago we were prompted. This is happening with only are P4014n
4 Suggested Answers
SOURCE: tray output
You should configure TRAY 1 as Legal only.
and Tray 2 as plain letter.
Specially when you specify from what tray/paper type to print.
This can be easily configured from the Printer Properties within the Printers and Faxes section of the Control Panel.
Posted on Jan 26, 2008
shawn38
  • 200 Answers
SOURCE: HP laserjet p4014n
Check the media settings for your paper trays. Make sure they are set properly, also check the diver media settings. Is the problem happening with a specific print job? If it is check the page setup for that document.
Posted on Mar 06, 2010
  • 217 Answers
SOURCE: Configure HP 4050 printer to prompt 'load paper'
You'll have to change the paper TYPE of tray 3 to a different type as in tray 2.
Posted on Jul 29, 2010
What is the setting and/or fix for no prompt at tray 1 for special media?
Set tray 1 paper size to "any size/any type". print out a configuration page to make sure that this setting took. set manual feed prompt to " unless loaded". That should work. Good luck !
May 14, 2014 | HP LaserJet P4014n Printer
My hp color laserjet cp2025 has the pcl xl error subsystem: Kernel error: Illelgaloperatorsequence operator beginpage position: 14 What can I do to fix this?
A Hewlett-Packard LaserJet printing language, PCL 6 is optimized for printing from graphical user interfaces (GUIs) like Microsoft Windows.
The Enhanced PCL XL, or PCL 6, driver that is included with the HP LaserJet printers provides enhanced WYSIWYG and enhanced performance with application support over the Standard (PCL5e) driver. PCL XL is a new page description language by HP, that is part of PCL 6 and is closer to GDI, which many applications use. Less translation takes place by the driver, which means increased WYSIWYG capabilities, and better performance with applications that support escapes implemented by the Enhanced driver.
While printing using the PCL 6 driver it is possible to encounter a PCL XL error. This error will print out at the LaserJet device, and will look like something similar to the following:
PCL XL error
Subsystem: KERNEL
Error: IllegalOperatorSequence
Operator: EndSession
Position: 15
These type of errors can be PCL interpreter errors, firmware related, tied to communication, driver, driver dependency, and application specific. Additional troubleshooting will be required to further isolate to root cause.
Troubleshooting:
I. Verify printer functionality
To verify printer functionality, perform the following:
1.Power the printer Off.
2.Disconnect the parallel, USB, or network cable.
3.Power the printer On.
4.Once the printer display reports Ready, verify device functionality by printing a Configuration Page from the device.
Note: should the internal printer test not print as expected, and/or a PCL XL error occur, you have then isolated the issue to the printer device, and any network connectivity or driver / application troubleshooting can be ruled out.
II. Verify communication w/ the device
To verify communication with the device, perform the following:
2.Reconnect any communication device cable previously removed
4.Once the printer display reports Ready, perform the following:
a.From the client machine or print server that had previously encountered the PCL XL error open the Printers and Faxes folder.
b.Right click the PCL 6 driver in question and select Properties.
c.From the General Tab select Print Test Page
d.Verify the driver test page successfully printed
Should the test page successfully print, continue with the next troubleshooting section entitled Isolate user, application and/or file.
Should the PCL XL error manifest itself as a result of the driver test page, perform the following:
1.At the print server, or client machine, open the Printers and Faxes folder
2.Click on Add Printer
3.Go through the Window’s driver install process installing the appropriate PCL 6 driver for the device in question, with the following characteristics: printing directly to the device (IP_Address, USB, Parallel, etc), creating a new print queue, selecting to Replace Existing Driver.
4.If the issue persists see section entitled: Microsoft Unidrv driver dependencies.
Note: If using an HP LaserJet PCL 6 device specific driver (discrete), try installing the latest HP Universal Print Driver PCL 6. Available at the hp.com website under support & drivers. Select product cb534a and also select your operating system, download a universal print driver Post Script would be the best selection.
You can also adjust a few settings under printing preferences:
under the advanced tab:
Raster compression:
Set it to max
III. Isolate user, application and/or file
If in fact the printers internal test pages and driver test page have printed successfully, further fault isolation must be performed to correlate the PCL XL error with a specific user, application, and or file. This information is most often easily gathered by speaking with the customer, investigating which user is printing when the PCL XL error manifests itself. Once the user is identified, the application the client was printing from can be isolated, and quite possibly the application file itself.
If an application file consistently causes a PCL XL error when sent to the device, it could be a problem only with the file.
IV. Microsoft Unidrv driver dependencies
The issue was identified to be related to Microsoft unicore files: unidrv.dll, unires.dll, and unidrvui.dll, that were not compatible with the available PCL 6 drivers at that time. Microsoft has developed a hotfix to address the symptomatic PCL XL errors – the Microsoft Hotfix can be reviewed here:
Microsoft Windows 2003 and XP: http://support.microsoft.com/kb/948046/en-us
Microsoft Windows 2008 and Vista: http://support.microsoft.com/kb/948349/en-us
Microsoft Windows 2000: NA
HP LaserJet – PCL XL Error
If anything else let me know,
Al
eliteprintersolutions@gmail.com
May 27, 2010 | HP Laserjet Cp2025n Printer
How do I tell the printer to take from the top tray?
Page 63 of your HP LaserJet 4600dn printer manual:
Controlling print jobs: (condensed version) MS Windows
Three settings affect how the printer driver tries to pull paper when you send a print job. The "Source," "Type," and "Size" settings appear in the Page Setup, Print, or Print Properties dialog boxes in most software programs.
Your question indicates that you wish to configure your printer to take from the top tray. That is a "Source" setting. So in the print Setup or Print Properties dialog box, change the "Source" to Tray 1.
Printing by Source means you choose a specific tray
from which you want the printer to pull paper. The printer tries to print from this tray, no matter what type or size is loaded in it. If you choose a tray that is configured from the embedded Web server for a type or size that does not match your print job, the
printer does not print automatically. Instead, it waits for you to load the tray you chose with the type or size of print media for your print job. If you load the tray, the printer begins printing. If you press the printer tries to print from another tray that has the correct type or size.
Kindly vote for my solution if this info was helpful.
Dec 30, 2009 | HP LaserJet 4600dn Color Printer
Pcl xl error subsystem: kernel error: illegal tag operator: ox1b position: 6
If you are using Windows 2003 Server and/or Windows XP Client machine and if you hace installed PCL 6 Driver than printer will print pcl xl error while printing.
To fix this problem user need to install PCL 5 Printer driver or Universal printer Drivers from the Link mentioned.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=1845552&prodTypeId=18972&prodSeriesId=1845551&swLang=8&taskId=135&swEnvOID=228
Jun 29, 2009 | HP LaserJet P2015 Printer
Just installed the 4200 pcl 6 drivers. On server
Press the green buttton, arrow down to Paper Handling, arrow down to tray 2 size and tray 2 type and verify they are set to "letter" and "plain".
Jun 24, 2009 | HP LaserJet 4200 Printer
Printer sends error message HP p2015
As mentioned above, install the universal PCL 5 drivers from HP website. This will fix the error.
Feb 23, 2009 | HP LaserJet P2015 Printer
Printing problem "PCL XL error"
Dear Sir
My printer is laserjet 1320
PCL XL error
Subsystem: KERNEL
Error: Illegal Tag
Operator: 0x1b
Position: 6
Pls. This problem solution give me.
May 29, 2008 | HP LaserJet 1320n Printer
Laserjet 1022n and Universal Print Driver
i solved this problem in my case with an compatilble standard driver from windows. An PCL Laserjet 5 / Laserjet 6 Driver.
And no problems occour.
On the clients and the server all iss fine.
Apr 07, 2008 | HP LaserJet 1022n Printer
TOSHIBA e-STUDIO16/20/25 PCL 6 Installation Problem Mac OS.
You will need to do it through a server LIKE WINDOWS 2003 SERVER , and set up a print server role on it, this allows multiple protocols to be understood ,, including windows, linux, mac, os2 freebsd etc...
Jan 17, 2008 | Office Equipment & Supplies
HP LaserJet P4014n Printer Logo
23 people viewed this question
Seeker5211
Seeker5211
