Question about Garden
Ryobi rlt 30 cesa petrol strimmer will not start
It will not start iv put new ignition coil &plug but no spark
    Sergeant:
  • 340 Answers
Keith you have got to make sure the gap is right between the coil and the magnetic flywheel. Use a buisness card to set the gap and make sure the coil is on the right way.
Posted on May 18, 2014
  • 37 Answers
SOURCE: Ryobi model RCT2800B grass strimmer will not start
close your carb adjustment screw a bunch of turns... yours may even be missing.
Posted on Apr 19, 2009
  • 5 Answers
SOURCE: Starting problem with a Ryobi rlt30ces petrol strimmer
Hi
I have had the similar problem & spent a day stripping the unit down
(dismantled & re-assembled the carb, seemed OK fuel reaching & flooding the plug) I unscrewed the spark plug from the body, but left it connected to the lead and found that there was intermittent spark when pulling the cord. and tested it with a continuity meter - no signal/measurement. bought a new spark plug, meter reading showed signal/measurement, now starts every time. It may be that Ryobi has been installing rather cheap nasty plugs. So test the plug first by watching the spark when pulling cord, test with a meter, if no continuity, buy new plug....
Check also that little gauze air filter behind the roto choke is not blocked.
this solved it for me.
Please remember to give me a rating ...ta
Posted on Feb 05, 2009
SOURCE: have a ryobi rlt 30 cd and the spool wont spin fast enough
hgffggkgjgjgbTry taping the bottom on a hard surface;HARD!;;;;;;;bjjjjjjkjjjjm4454541joojojojlj That did the trick for me for some reason it doesn't grab and it gets lose were it won't spin fast bearly cutting a blade of grass.
Posted on Aug 15, 2009
  • 474 Answers
SOURCE: petrol strimmer good spark but wont start
if it ran fine then it quit it is more likely the pick up tube in the fuel tank
Posted on Sep 14, 2009
SOURCE: ryobi strimmer
i can not take the cover off to put the line back in
Posted on Oct 02, 2010
I have a 2 stroke ryobi brushcutter. No spark at a new plug. Ohm reading is 1.2 on the secondary coil,and 3.91 on the primary. Are these readings acceptable ?
Check the lead going from the ignition module to the plug. some are sealed and moulded, others the cable just screws onto a spike on the module. Then check the boot end, if it can be removed, make sure there is a good connection to the inner wire core in the cable. I cant find anywhere that gives you ohm readings of what the output should be tho.
Apr 25, 2016 | Ryobi Garden
Starting up Ryobi Petrol Strimmer
full choke on , push petrol bubble 5 times then pull starter cord., with luck it will kick in to life after a 20/30 secs put on half choke , run again for 30 secs the no ckoke.
The main problem with Ryobi products is that they flood very very easly. So the more time you try and pump petrol into the carb the more it will flood . If that happenes then choke off and switch off and then just pull starter cord for about 30 secs then switch on and it could start if not prime it again as above good luck
Dec 24, 2011 | Ryobi Garden
Petrol strimmer,, spark at plug,, petrol & 2
I have a flymo 430 petrol strimmer and cannot start it. ive cleaned the filter, put in new plug it went first time and then stopped and wont start again the plug seems to get wet all the time any ideas
Jul 03, 2011 | McCulloch Heavy Machinery
Ryobi strimmer petrol wont start
check spark plug. hT lead.
Jun 30, 2010 | Ryobi Garden
Ryobi RLT30CET difficulty starting and when running doesn't power up sufficiently to do job. Has 50:1 unleaded fuel The machine was bought 18 July 2009
Hi...Ryobi RLT-30CET...I have a newish strimmer which I dropped 2 ft. Changed the spark plug...as it seemed to have no spark. Now I think its flooded. How do I sort the flooding problem. and are there delicate parts that could break? many thanks...Phil
May 15, 2010 | Ryobi Garden
New Ryobi petrol c/saw wont start.
If it is brand new, sounds like you should return it for the retailer to have repaired.
Dec 05, 2009 | Ryobi 18-inch Electric Chainsaw Chain Saws
RLT30HT 30CC PETROL STRIMMER difficult to start
The plug that I have in my 720r is a Champion RDJ7Y. Can I suggest that you pull the old plug out and look to see which one you have? Also when you buy the new replacement it should already be gapped for what you need.
Jul 27, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Have a Ryobi CS30 Weedeater, will not start, it is about a year old, did not see a spark, just bought new plug.
If you still don't have a spark with the new plug, then you may have a kill switch wire grounding the motor, keeping it from starting. If it's not that, then you have a bad ignition module (coil).
Jim
Jun 07, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Hi
Jan 25, 2009 | Ryobi 15" Electric Factory Reconditioned...
Ryobi RLT30CES
I have one of these and I have to admit they are a bit of a bug*er to start. Following the instructions though on the sheet for trying to start it eventually should kick it off and then you should be away. I start mine by alternating between no choke and the half choke with about half a dozen pulls each. generally pull with the throttle held but try a few with it off every now and again. If you get to 10 mins without success, put it down, have a drink and a rest and go back in 30 mins and try again.
I wouldnt have thought a straight petrol mix would do it any harm though, if you had over mixed with oil then that could have been a differnt story.
May 25, 2008 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
123 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
