Question about Lowrance GPS
How do i get my gps funtion back on my lowrance LMS-334 ci gps
  • 13433 Answers
SOURCE: Lowrance LMS 335 C
Heres the update
http://www.lowrance.com/Products/Marine/Full-Size-SonarGPS-Chartplotter-Combos/LMS-335C-DF/Downloads/LMS-335C-DF-Software-Update/
Posted on Aug 04, 2008
Benimur
  • 6966 Answers
SOURCE: i need a manual!!
Pls try here. Incidentally, you might fin this likewise informative.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 02, 2008
SOURCE: lowrance 330c gps unit
A "soft reset" can be accomplished by pressing and hold "Pages" key and press and hold "PWR" key till USA map comes on , then release both. A "hard reset" requires press and hold both "Z in" and "Z out" buttons and press and hold "PWR" button releasing all three when USA map appears.
Posted on Oct 28, 2008
SOURCE: My Lowrance LMS-337c df keeps going crazy.
Have the same problem. Have you resoved it?
Posted on Jun 20, 2009
  • 508 Answers
SOURCE: My Lowrance Lms 240 comes up gps module not
http://www.lowrance.com/Downloads/Manuals/ try this site. Also nor being real familiar with these units since i have no use for a water unit, i am going to suggest that it may be the transducer or the cable linking it to your gps unit. That's the only idea i have and if it's right , would you let me know, or let me know either way, since information like this helps me learn what and where i went wrong. Thanks
Posted on Jun 12, 2010
Lowrance completely dead
my lowrance lms 337c df will not power up. I checked all the cables and poer and they are good . can you assist me
Aug 14, 2011 | Lowrance LMS-337CDF GPS Receiver
Lms 520c 5" Screen Color External Gps And 200 Khz Sonar System: I have a Lowrance LMS 520C on my boat. The GPS wi...
I have the same problem on my 520C.
I have no solution but I hope you have find some?
Best regards
Dan
May 07, 2010 | Lowrance Lms 520c 5" Screen Color External...
Hi,when i switch on my lms-332c the map does not come up on the screen.If I remove and replace the map card it works perfectly. Can I fix this? regards nigel
I am guessing that the card you are using is a NAVIONICS chart? There have been some Lowrance units that were made around the same time that have had problems recognizing a Navionics chart right from power up.
Make sure the LMS-332 has the latest firmware version which can be downloaded from http://www.lowrance.com/en/Products/Marine/Full-Size-SonarGPS-Chartplotter-Combos/LMS-332C/Downloads/LMS-332C-Software-Update/
If the update doesn't help, this is going to be a compatibility problem with the LMS-332 and that particular card. You will need to replace the card or upgrade to a newer unit...but probably can just get used to removing and replacing the card when you turn the unit on.
Jul 08, 2009 | Lowrance LMS 332c Mapping Sonar/GPS...
I have a lowrance LMS 332C GPS. After 5 years I
The LGC-2000 is bad would be the most likely cause, but if this started right after you changed the cables, Try connecting the NMEA 2000 network to a different power source than the main power. If you still have the original cables, and you didn't have the problem before, try using those again to make sure there isn't anything wrong with any of the new cables.
But most likely, the LGC-2000 is toast and you will want to contact Lowrance support to see about getting it repaired/replaced.
Jul 04, 2009 | Lowrance LMS-332C GPS Receiver
Lowrance lms 330
have a lowrance lms-330c the depth no. keep changing from hi no. to low no. can not stop it,,, will not show true depth,,, can you help?,,,where can i send it to get it fix?
May 29, 2009 | Lowrance LMS-330C GPS Receiver
Lowrance 330c screen says '' boot failed''
Try a hard reset:
1. Turn the LMS-330 off
2. Press and hold the ZIN, ZOUT, and PWR buttons
3. Release the three buttons once you see the "warning, do not rely..." message appear
If you get that far, the problem is solved. If you get boot failed again, try installing the latest update which can be downloaded from http://www.lowrance.com/en/Downloads/Product-Software-Updates/
If you still get boot failed, you will need to get the LMS-330 repaired/replaced. You can contact Lowrance support at 800-324-1356 or email them by going to http://www.lowrance.com/en/Support/Product-Support/Contact/
Mar 22, 2009 | Lowrance LMS-330C GPS Receiver
I need a manual!!
you can find the manual here,
www.lowrance.com/upload/Lowrance/Documents/Manuals/LMS339cDF_iGPS_0152-011_011206.pdf
Hope my info solves your problem,
Thanx for using fixya.....
Oct 02, 2008 | Lowrance LMS-332C GPS Receiver
Gps
I have a manual for this unit but i'm still using mine so not willing to sell it to you. I'm in Melbourne and you're welcome to borrow it for a week or so or i could probably photocopy/scan certain sections for you and email them if it helps. Let me know if you still need it by emailing me at joshklat@hotmail.com
Cheers,
Josh
May 21, 2008 | Lowrance LMS-337CDF GPS Receiver
GPS Logo
18 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Wbix
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
