Question about Homelite Mighty Lite Lawn Trimmer
How to replace fuel lines craftsman 316.292620
    Guru:
  • 479 Answers
Initially release any clips by squeezing with a pliers and pushing back along the line. Lines can be prised off using a snipe nose pliers or flat blade screw driver, pushing on the edge of the line. Don't pull the lines which can stretch them.Two fuel lines leave the tank of a two stroke engine. The primer bulb sucks gas from the tank via the line with the filter on the end, gas returns to the tank via the other line without the filter. When you replace a line, to check whether they haven't been mixed up, fill the tank but leave the line without the filter above the level of the gas. When you push the primer bulb, gas should eventually squirt out the line without the filter. If the lines are mixed up, air bubbles will flow out of the filter and no gas out the other line.
For a pictorial guide and more info on troubleshooting 2-stroke engines and carburetors, see my guide here:
String Trimmer Won Work 2 Stroke Engine and Carburetor Troubleshooting
Posted on May 26, 2014
How to replace fuel lines on model#358.791010
I had the same problem. If you replace the lines and you get them swapped, it just won't run. Nothing will be damaged. So then just swap them around. There are only two choices. Trial and error worked for me!
Aug 03, 2014 | Craftsman 25cc Gas Line Trimmer
Why does the fuel not stay in the primer bulb, when I prime the craftsman weedeater with sim-pul
Fuel lines probably need replacing. Have you been using ethanol? The alcohol eats the fuel lines on most 2 cycle motors up.
Jul 06, 2014 | Craftsman Convertible 25cc. Gas Line...
Craftsman edger 358.797450 I need to replace the fuel filter and lines
Craftsman require that you remove the Covers, disconnect the Fuel Line connecting the Fuel Tank and Carburator and the Filter is inbetween
Apr 04, 2013 | Craftsman Garden
I have a Craftsman 32cc blower/vac model #358.797251. Replaced fuel lines and primer bulb. Getting fuel but won't start
Check for spark and air filter in good shape. Make sure bulb side gasket is OK! No leaks! Good luck!
Oct 16, 2012 | Garden
Replace fuel and primer line on craftsman 358-798470EM string trimmer
Try searching Craftsman Weed Trimmer fuel line on this site for numerous responses to this problem.
Aug 07, 2010 | Craftsman Garden
Craftsman hedge trimmer fuel line replacementa craftsman
My Sovereign SHT 26 hedge trimmer has a damaged fuel pipe which needs replacing; please advise
Jun 12, 2010 | RTO Weed Eater Hedge Trimmer 20cc,...
Repairing fuel line on craftsman 32cc weed trimmer.
Cut the end of the line at a sharp angle. Spray WD-40 on the line and fuel tank hole. Slowly screw the line in the tank far enough so you can connect the fuel filter if you are replacing that line. If not just push the line into the tank if you have a two line system. Remember on the fuel primer, the long tip has the line going to the tank, and the short tip has the fuel line going to the carb.
Aug 24, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman trimmer won't prime
A new carburetor would be simplest solution. You could try disassembling the carb, cleaning and replacing diaphrams, but just replacing the carb would be my choice. What is the model # on the trimmer and I can tell you the part # of the carb you need.
May 24, 2009 | Craftsman 25cc Gas Line Trimmer
Homelite Mighty Lite Lawn Trimmer  Logo
105 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
