Question about Olympus E Cameras
Why is my compact flash write protected? - E Olympus Cameras
    Problem Solver:
  • 12 Answers
The write protection is usually enabled by flipping an extremely tiny switch on either the side of the card or the adapter you may be using. Write protection keeps your data safe from being over-written.
Posted on May 14, 2014
Pendrive write protection unable to remove
download Active kill disk from following link.
http://software.lsoft.net/KillDiskSuiteFree-Setup.exe
this will erase all data and protection files
Jul 14, 2014 | Transcend 8Gb Jetflash 300 Usb Flash Drive...
"PROTECT" message in display.
two cables of a speaker were touching each other.
this may be the problem
Dec 29, 2007 | JVC HX-D7 DVD Compact Stereo Audio / Video...
My jvc compact component system keeps flashing PROTECT and then it shuts off
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Mar 21, 2011 | JVC HX-D7 DVD Compact Stereo Audio / Video...
When I put into my camers Nikon D40 IT SAYS IT IS LOCKED?
I sure hope you mean an SD or an SDHC card, since the D40 doesn't take CF cards.
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Aug 17, 2010 | SanDisk ULTRA II 4GB Compact Flash Card...
"the media is write protected"
Look on the memory card, some have a tiny switch that write protects them.
Mar 04, 2010 | SanDisk ULTRA II 4GB Compact Flash Card...
Hello, i wan't to format the compact flash card of my korg d4.The display say:card error#204?
Some cards have a write protect feature. Make sure this is off. You might want to clear the card on a PC and try again.
Jul 05, 2009 | Music
My card won't work on my computer, what is wrong?
When you format the card, be sure to do it in the camera, as the camera firmware writes hidden files to the card.
When you insert the card into the card reader, be sure to set write-protect, so the contents cannot be corrupted.
I suspect what may have happened is that at some point there has been a conflict between files written to the card by the camera and the computer.
May 13, 2017 | SanDisk ULTRA II 4GB Compact Flash Card...
Locked files in my kingston 2gb compact flash
IF YOU PASSWORD PROTECT THE INFORMATION YOU WILL NEED THE PASSWORD TO ACCESS THE FILE UNLESS
THE FILES ARE CORRUPT THAN EVEN WITHA PASS WORD THE USB DEVICE WILL NOT ALOOW ACCESS TO THE INFORMATION THIS KEEP YOU FROM CORRUPTING THE HARD DRIVE OR WHAT EVERY DRIVE YOU WNAT TO COPY TO. JUST DELETE THE OLD ONE AND RECOPY THE FILES IF YOU CAN.
****************IMPORTANT*****************
LETS SAY THE DILE ON THE FLASH DRIVE ARE IMPORTANT AND YOU CANNOT GET ANOTHER COPY, THERE ARE PROGRAM THAT ARE FREE ANTI VIRUS PROGRAMS THAT WILL TRY AND FIX THE CORRUPTED FILE SO YOU CAN ACCESS THE FILES, BUT
IM NOT SURE WHAT COMPANYS HAVE THAT OPTION IN THERE PROGRAM, NORTANS DISK DOCTOR I THINKS HAS ONE, MAYBE EVEN THE COMPANY YOU BOUGHT YOUR FLASH DRIVE I MEAN THE VENDER MAY HAVE SOFTWARE TO FIX ISSUES ON THE FLASH DRIVE DEVICE
ROD
Jan 25, 2009 | Kingston flash memory card - 256 MB -...
Computer won't recognize san disk 4gb ultra
Since your card is password protected,computer will not recognize it..so remove the password and then try it will work..
_______________________________________________________
Thanks for using fixya technical support
Jun 17, 2008 | SanDisk ULTRA II 4GB Compact Flash Card...
Protect
The protect message indicates that a problem has been detected in the final output stage of the amplifier. The most common failure parts are the output transistors. Plan on a parts cost between $15-$40. Add in the local labor rate for the total repair cost.
Dan
May 28, 2008 | JVC HX-D7 DVD Compact Stereo Audio / Video...
Cameras Logo
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
