How do I skip unused inputs in the input selector for my LG?
I have an LG 47LH40. It used to skip the unused inputs but now I have to cycle through all the inputs before getting to the ones I am using. This was after the tv went to power only mode (which I fixed thanks to this site). Is there a setting for that on that model?
    Top Expert:
  • Televison & ... Master
  • 75,311 Answers
Refer its user mannual for details. Gopakumar Gopalan Google
Posted on May 14, 2014
jerryg50
  • 1689 Answers
SOURCE: Input setting
When you turn off the set, are you turning it off by running the power through a cable or satellite box? If you are shutting down the set from the AC mains side the set can lose all of its user set-up. In most TV models, the main power supply must have the AC mains connected.
The power supply goes in to a standby mode when the TV is turned off by its own power switch (not by the AC mains). The supply puts out enough power to keep the uPC and the user memory active.
If the set is properly turned off and it is losing its user set-up, it is possible that there is a fault in part of the uPC circuits. Depending on the model of set, there may be a lithium battery, or memory capacitor, or an EEPROM for keeping the user set-up memory.
Jerry G.
Posted on Apr 18, 2008
SOURCE: unusable signal prompt on video input
tv only gets 22 channels.
Posted on Oct 23, 2008
  • 11800 Answers
SOURCE: I want to omit the
No, this tv it's a very simple, basic one that doesn't have this option.
Posted on Oct 23, 2010
alexander404
  • 276 Answers
SOURCE: I want ot change my LG television Model 47LH40 to
1080p video resolution can only be achieved by a Blu-ray Disc. Satellite TV, broadcast TV, cable TV do not actually send out 1080p resolution. So unless you are using a Blu-ray movie, you will not be viewing 1080p. Your HDTV has a NATIVE screen resolution and the TV will SCALE all incoming video to its native resolution. Most people cannot tell the difference between 720p and 1080i. 1080p signal sources are slightly sharper. But if you have a HDTV that is 1080p capable and you give it a 1080p source (Blu-ray Disc) and use a HDMI cable to connect, you will get 1080p, you do not have to change the HDTV as it will automatically display 1080p.
Posted on Mar 25, 2011
SOURCE: i have a 26' led LG TV , and i am using a new set top box . when i am joining the tv from set top box and going in AV mode , its showing input blocked, i can not use set top box services. please h
Please provide a model number for this TV, I would have thought being an LED tv that you wouldn't be needing a set-top box as it would be digital already.
Posted on Apr 07, 2012
Change input on lg tv
Use input selector on remote.
Sep 06, 2017 | LG Televison & Video
CAN I GET WIRELESS INTERNET ON MY lg tv 47lh40ua I have a roku set top box, however i would like to be able to go to other sites than just what roku offer such as google or youtube? Thank you for your...
I'm partial to using a nettop computer with an HDMI port as a media center PC. Be sure to get a remote that has a keyboard and touchpad for couch-side input.
Apr 03, 2011 | LG 47LH40 47 in. LCD HDTV
I can not get the line in input to work. there is no L1 on the channel selector.
To record from the line input, there is a button on the VCR's remote called INPUT SELECT. Press this button to get your line input. You press it once to select and again to cycle thru the selections. If you have a L2 input, pressing the button again will go to this input and so on.
Aug 29, 2010 | Toshiba M655 VHS VCR
My harmony 550 always stops one input before the one I need on my TV. my tv has an input button that cycles thru all of the inputs. i've already checked that the inputs are listed properly on the setup...
On some TV's when you first press the input button it does not switch to the next input it just shows you the current input. It is the 2nd press that offten takes you to the next input in the list. This can cause problems with the Harmony. If your TV works this way then you will need to call Logitech and let them know about this issue. They can add the additional hit for you and then you can update your remote. If you are only using 2 inputs then A work around you can try is to tell the Harmony that there are more inputs, effectivly setting up Ghost inputs. You would put one ghost input after each input that you use. If there are 3 or more inputs then this trick will not work. The last work around is to remove unused inputs on your TV. Most TV will allow you to remove unused inputs. Then you can add one ghost input after each actual input: For example:
TV input1
Ghost1
DVD input2
Ghost2
VCR input 3
Ghost3
If I am missing some information just let me know.
I will do my best to help
Good Luck
Nov 30, 2009 | Logitech Harmony 550 Remote Control
Tv does not show pictuer screen says no vidio input how do i fix
You don't give much detail, however you might try selecting a different video input. There should be an input selector on the remote and the TV, which when pressed will cycle through all the available inputs. I hope this helps you.
Oct 23, 2009 | Televison & Video
KV-36XBR450 input selection problem
Go into the menu on the TV and go to the far right under setup. Select "video label" then select "program". A menu will come up listing the 7 inputs. Make sure that the input you are using for your PS3 is not set to "skip". While you're there, set any of the other outputs you're not using to "skip". Your TV/Video button will only cycle through the ones that aren't skipped. Have Fun!
Feb 01, 2009 | Sony KV-36XBR450 36" TV
No Audio
tienes que comprar cd para grabacion que diga audio digital si no no los quema
Jun 23, 2008 | LG ADR-620N CD Player
Unusable signal prompt on video input
be sure to cycle thru the input selections-- either w/Remote (input button), or channel +/- on the panel. my truflat 26" hd set has side/front/video1 video2 inputs, yours may have more or less. also, be sure you've plugged into an INPUT set, not an OUTPUT set. Does sound work otherwise on this set? If not, maybe interal speakers (menu setting) is set to off/not checked.
And on your PS3--goto the settings menu, sound outputs, make sure you select A/V connector and analog sound. The ps3 cable can become sloppy too, wiggle/check/reseat or try another cabe (usually video is touchy more than the sound though)
If you KNOW you've got the right input selected and the PS3 is setup properly, do you have another device with audio output to test on the TV? a notebook computer, walkman, cd player--anything that has rca outputs for sound--quick swap the cables to the new 'test' device-- if sound is OK with test device, either PS3 setting or cable is bad/wrong. if no sound from test device on TV either the tv is not using proper inputs, or is damaged, or the test device is not properly configured. If you have another input receiving device to test the ps3 output sound, like the LINE INPUT on a notebook computer, or a boombox with Aux inputs, test the PS3 sound output too.
Jun 08, 2008 | RCA TruFlat 27F520T 27" TV
Cannot select all cycles
You have a problem with the display board and may need to be replaced.
Feb 22, 2008 | LG DLE5932W Electric Dryer
Trouble getting a picture with a source selector
The input on your television monitor must be set to view the composite with the S video cable. You will not be able to view the component video unless you also have component video outputs going from the input selector to the television. After you have done that, you will also have to change your television input from "video 2" to whatever input you used for the component video hookup.
Dec 05, 2006 | Sony STR-DE685 Receiver
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
