Question about Konica Minolta magicolor 5430 DL Laser Printer
How to repair Micom board of Vu LCD TV
I am not able to turn ON my TV after it had been switched off. This problem was occuring very frequently, which subsequently became the permanent problem. Now my tv does not gets powered on completely.
  • 2,509 Answers
If a board has been hot it is likely the electrolytic capacitors will need replacing. Look for bulges on the tops of the capacitors. That's where I would start if you don't have a qualified technician.
Posted on May 14, 2014
When tv is turned on you get poicture and sound but there are broken horizontal lines from top to bottom of screen. this occurs on all hdmi inputsincluding roku and dvd player.
How to fix lcd lines on Sharp tv screen, hdmi video board ...
? 3:43
https://www.youtube.com/watch?v=cHki4D0EwOo
May 24, 2014 - Uploaded by Tampatec
How to fix LCD lines on Sharp TV screen, hdmi video board easy ... Make Money From Your Broken Cracked LCD LED PLASMATV ... TV Repair Help for Vertical & Horizontal Lines on Your TV Screen ... Sharp Aquos LC-32 37 46 52DH65E 66E 77E - NoPic/Sound with ... Get video URL at current time.
comments on LCD Display Symptoms and causes. - YouTube
https://www.youtube.com/all_comments?v=DedJvyNm_s4
We have frequent outages causing the TV to turn on from standby mode when power returns. (These ..... Sharp LC-70LE650U 70-Inch Aquos TV TURNS ON WITH PERFECT PICTURE AND ..... It has thin horizontal lines on the top quarter of thescreen. ..... hey there, bought a 52lg60-ua had no image/picture but had sound.
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Jan 28, 2016 | Sharp aquos 52 in lcd 1080p aquos 52...
Wharfedale TV power problems
the problem occurs in ur main board...check all tge resistor in board...the faulty resistor will; allow high voltage to the main board and affect it
Oct 31, 2008 | Televison & Video
Ns LCD 26-09 TV not powering up
LCD TV repair - Samsung LW20M21CP not powering up ...
? 25:30
https://www.youtube.com/watch?v=zxqDLDNuCfw
Jul 8, 2013 - Uploaded by RetroGameModz
This is a documented repair of a Samsung LCD TV that I got for cheap. It was listed as not working, which is ...
Samsung LCD TV Repair - TV Won't Turn On - How to ...
? 8:23
https://www.youtube.com/watch?v=n54IurMvr6o
Apr 4, 2014 - Uploaded by ShopJimmy.com
Samsung LCD TV Repair - TV Won't Turn On - How to Replace ... or if you have standby and the TV will ...
MOST COMMON REPAIR FOR LCD - NO POWER - YouTube
Dec 02, 2015 | Insignia NS-LCD26-09 26 in. HD-Ready LCD...
Unplugged my 32LV67U to vacuum behind it and now it will not power up. Yellow LED keeps blinking and I waited several minutes but tv will not power up. Worked perfectly until I unplugged it. Called...
That wall outlet may have frequent surges so try another wall outlet see if it turns back on. If it turns on be sure to use a surge suppressor and never plug the TV directly into the wall outlet. The AC surges will kill the power supply of the TV in short time. See if there's a kill-switch near the ac adapter of the TV if there is turn it on.Get a surge protector/suppressor then try plugging it back in the wall. If still no power then the power board is already damaged, you can send the board too me and I'll repair it for you or seek your local repair center.
http://tvtechwork.webs.com/
Oct 18, 2010 | Toshiba Regza 32LV67U 32 in. LCD HDTV
My tv won't turn on...the red light indicates that it's plugged in, but everytime i press the power button, i get nothing! can someone help?!
If warranty no longer valid, the first printed circuit board I would investigate is the one with all the aluminum heat sinks on it!!! It's called the "switch mode power-supply" !!! Power supply detects a "fault condition" and goes into "shutdown mode" to save itself from catastrophic component failure!! e.g. smoke, sparks, fire. Same typical failure modes occur in CCFL back-lit lcd computer monitors. You will need to visit YOUTUBE for video clips of "lcd monitor disassembly" and "lcd monitor repair" and after that move up to CCFL lcd tv repair videos to know just what to "LOOK" for on the smps board. Good luck with your unit. 12fixlouie
Sep 20, 2010 | Broksonic CCVG-3276 32 in. LCD TV
RIGHT HALF OF MY TV SCREEN, INTERMITENTLY, LOOKS LIKE A VERTICAL BAR CODE WITH FREQUENT COLOR CHANGES IN THE BARS, PROBLEM IS OCCURING WITH INCREASING FREQUENCY AND DURATION. WHAT IS CAUSE FOR THIS...
It can be the T-CON board or the main board, worst case will be the LCD panel, this will involve very in-depth troubleshooting since you do not have the T-CON or main board to try out so it will not be DIY repair, you can buy a new T-CON board to rty out first since it is the cheaper than the main board. If the LCD panel is bad, then forget about fixing it. It may have to be repaired by the service center.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Aug 13, 2010 | Toshiba REGZA 47HL167 TV
Tevion 42 inch lcd flashing standby light and tv will not turn on
If you can checked LCD Inverter Board & Micom Board.Most of Inverter board is defective.
Jan 23, 2010 | Televison & Video
Problem with the video inputs....
Your problem is the MICOM board. It is a standup board the plugs into the main board. It is basically the "brains" of the tv. It does all of your video processing,video switching, etc. It is also a very expensive board (around $400).
Nov 30, 2008 | JVC AV-48WP30 48" Rear Projection...
Tv switches itself off then back on again
Hi.
If the tv set is still under warantee get it sorted before gtee runs out.
The problem is caused by cummunication error between ATV Micom and DTV Micom.
To correct this problem requires going in to service mode to make changes & updating the DTV firmware.
This will need to be done by a proffesional.
http://dysonmanuals.llc.nu/
Chris.
Jan 02, 2008 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Konica Minolta magicolor 5430 DL Laser Printer Logo
37 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
